dew heater kit for telescope
hi everyone, i am so green to electronic but hey i'm going to give it a go, i was just wondering if i could get a little help.
i'm trying to make a dew heater controller for my telescope this is what i found on the net
https://www.jaycar.com.au/diy-telescope-dew-heater
but i cant really see where all those wires are going to, any help would be appreciated.
Each individual component and it's wiring is shown in separate schematics with the correct pins identified. What don't you understand?
Do you have all the component in hand?
Paul
well i am pretty green at this , have all components, i dont know how to read schematics.
for example; DHT11 is the thermostat, gnd well i know where that is on the uno board because it says it, as for D3 and SV it hasn't got that on the board
edluqa:
My Arduino board has those. Bet yours does to.
Paul
PS. See, you can read schematics!
So is this correct
5V (5 Volts), not "SV".
Great tutorial on how to read schematic diagrams.
Hi
Welcome to the forum.
Jaycar image.
I hope you realize you will have to solder those connections.
Tom... :slight_smile:
Soldiering is the easy bit.
Any advise for putting it together tom?
As an Australian I am very disappointing with the standard of the instructions for that project.
I fact I would say it has no instructions, just a "here is what it looks like and here are the components".
I am going to say it, Even A Fritzy Diagram would have helped.
I have contacted JayCar via their contact page expressing my disappointment.
I will see what I can do for you.
Tom.... :slight_smile:
Hi tom it does have schematics
But what i cant follow is the the proto board
edluqa:
DIY Telescope Dew Heater | Jaycar Electronics
I would expect a schematic, not a scattering of diagrams.. lol
Tom.. :slight_smile:
TomGeorge:
I think the intent was to show each device/circuit can and should be implemented and tested individually.
Paul
TomGeorge:
Thanks heaps Tom
Lee
I wouldn't recommend the DHT11 for dew point: this implies you expect the humidity to go to (near) 100%, and the DHT11 measure no more than 80% or so. You'll need at least the DHT22, or even better a BME280.
I was just wondering, you guys sound pretty smart, well smater then me anyways, would you be able to check the code for me.
edluqa:
most definitely
please read :
How to use this Forum
item #7
to learn how to post code
it is a sticky post at the top of every forum
This may help with your layout,
Hi dave-in-nj,
this the code
Telescope_Dew_Heater.ino (10.1 KB)
today im going to attempt to put it all together :smiley:
TomGeorge:
Hi tom where the GDS is do i need to soilder the holes together?
Working down, 3, 2, 2
