system
1
Hi!
Im putting together a weather station for calculating Dew point (among other things) and uploading it to Wunderground.
But im having trouble finding a way to calc dew point. I found the below formula.
But since Wunderground needs the value in fahrenheit, and I get my temp in fahrenheit, it feels silly to convert back and fourth.
In short: Is there a similar formula for calculating dew point in Fahrenheit?
H = (log10(RH)-2.0)/0.4343+(17.62t)/(243.12+t);
td = 243.12H/(17.62-H);
RH = Humidity in %
t=temperature in celcius
td= dew point temperature in celsius
Thank you!
Convert the temperature from Fahrenheit to Celsius and use the formula you have.
you can fill in the celsius to fahrenheit formula at every place of the dewpoint formula and try to simplify it.
tc = ((tf-32)*5.0/9.0);
so the formulas become...
H = (log10(RH)-2.0)/0.4343+(17.62* ((tf-32)*5.0/9.0) )/(243.12 + ((tf-32)5.0/9.0) );
simplify ==> so the formulas become...
H = (log10(RH)-2.0)/0.4343+(9.79 * (tf-32) )/(243.12 + ((tf-32)0.555555) );
so in terms of number of math operations it adds 3 operations. That is exactly the amount of converting C->F.
The conversion on the outputside tdC -> tdF takes one additional operation
tdF = (243.12H/(17.62-H) * 9/5) + 3;
tdF = 437.4*H/17.62-H) + 32;
so only one additional operator.
FOrmulas not tested, but you should get the idea.
