DFPlayer with USB thumbdrive (U-drive)
Maybe everybody knows this already?
The DFPlayer Mini is useable with a USB thumbdrive instead of a microSD.
That's what those USB+ (p14) and USB- (p15) pins are for.
Just wire up a USB socket (receptacle) - to plug your thumbdrive into - and it's ready to go.
I'm doing that with a NanoEvery now.
It's one of those "oh, it's that easy?" things, isn't it?
Pretty much.
I saved a French webpage address, which subsequently bit the dust, remembering that it made it look pretty complicated.
But the other day I figured I'd wire up a socket and see what happens.
This is my test sketch --
#include "DFRobotDFPlayerMini.h"
DFRobotDFPlayerMini player;
  Serial.begin(19200);
  Serial.println("uart0 up\r\n");
  Serial1.begin(9600);  // 0 = tx; 1 = rx
  delay(5000);
  if (player.begin(Serial1))
    Serial.println("OK");
    // Set volume to maximum (0 to 30).
    player.volume(25); //30 is very loud
    Serial.println("Connecting to DFPlayer Mini failed!");
  player.playFolder(1,1);
  delay(12000);
  player.playFolder(1,2);
  delay(12000);
  player.playFolder(1,3);
  delay(12000);
  player.playFolder(2,1);
  delay(12000);
  player.playFolder(2,2);
  delay(12000);
  player.playFolder(2,3);
  delay(12000);
  player.playFolder(3,1);
  delay(12000);
  player.playFolder(3,2);
  delay(12000);
  player.playFolder(3,3);
  delay(12000);
  player.pause();
  delay(10000);
I noticed that, with the test sketch above, when I started it cold it would miss the first play, just "dead air" for that 12sec. But if I clicked the Reset, it would execute as anticipated.
I made some changes to the setup() ─ adding the last 4 lines
  Serial1.begin(9600);  // tx 0; rx 1
  delay(2500);
  delay(2500);             // keep or cold start will miss first play
  player.playFolder(1,1);  // keep or cold start will miss first play
  player.pause();          // keep or cold start will miss first play
  player.volume(18); //30 is very loud
The other thing, after it got through the first play through, it would have the volume cranked all the way up.
Maybe it's the thumbdrive (it wouldn't blink as it does otherwise when a track plays) ?
Maybe it's the Every ? Maybe I should try it with "328 Registers" selected.
With the new setup(), it doesn't miss the first play and the volume doesn't change.
