This really isn't specific to the rover, I just can't see where I went wrong in the sketch. It's using a L293 motor driver.
When I load this sketch, one motor goes forward and one goes backwards, as it should:
/* Copy and paste the code below into the Arduino software */
int E1 = 6; //M1 Speed Control
int E2 = 5; //M2 Speed Control
int M1 = 8; //M1 Direction Control
int M2 = 7; //M2 Direction Control
pinMode(13, OUTPUT);
int i;
for(i=5;i<=8;i++)
pinMode(i, OUTPUT);
digitalWrite(13, HIGH);
int leftspeed = 255; //255 is maximum speed
int rightspeed = 255;
analogWrite (E1,255);
digitalWrite(M1,LOW);
analogWrite (E2,255);
digitalWrite(M2,HIGH);
delay(100);
However, when I load this sketch, it gets to the part where it outputs "turn" to the serial monitor, however both motors move forward for 3 seconds, even though i'm sending HIGH to M2. Any ideas?
int leftspeed = 240;
int ultraSoundpin = 7;
unsigned long ultrasoundDuration;
pinMode(ultraSoundpin, OUTPUT);
pinMode(E1, OUTPUT);
pinMode(E2, OUTPUT);
pinMode(M1, OUTPUT);
pinMode(M2, OUTPUT);
// send a low, wait 2 microseconds, send a high then wait 10 microseconds
digitalWrite(ultraSoundpin, LOW);
delayMicroseconds(2);
digitalWrite(ultraSoundpin, HIGH);
delayMicroseconds(10);
// switch pin to input
pinMode(ultraSoundpin, INPUT);
// wait for a pulse to come in as high
ultrasoundDuration = pulseIn(ultraSoundpin, HIGH);
if(ultrasoundDuration > 1200){
analogWrite(E1,leftspeed);
analogWrite(E2,rightspeed);
digitalWrite(M2,LOW);
}else{
Serial.print("stop");
analogWrite(E1,0);
analogWrite(E2,0);
Serial.print("turn");
delay(3000);
analogWrite(E1,0);
analogWrite(E2,0);
// output
//Serial.print(ultrasoundDuration);
//Serial.print("\t");
//Serial.print(ultrasoundDuration/58, DEC);
//Serial.print(" cm");
//Serial.println();
