DHT sensor IoT cloud - wrong readings
I've played with this for hours and I cannot see why the temperature reads 15.6 and the humidity reads 3304. I've also run the example DHT tester code using an Adafruit library and the readings are correct (31.6 degrees C and 51% humidity). Could the DHT library included with the automatically cloud generated file not be the correct one? Is it possible to select a different library?
Here is the code:
  Sketch generated by the Arduino IoT Cloud Thing "Untitled"
  https://create.arduino.cc/cloud/things/a62ce0ae-5b1b-4a35-a985-a0fb45e9f502
  Arduino IoT Cloud Variables description
  The following variables are automatically generated and updated when changes are made to the Thing
  float humidity;
  float temperature;
  Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
  which are called when their values are changed from the Dashboard.
  These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
#include "DHT.h"
#define DHTpin 2
#define DHTTYPE DHT22
DHT dht(DHTpin,DHTTYPE);
  // Initialize serial and wait for port to open:
  // This delay gives the chance to wait for a Serial Monitor without blocking if none is found
  delay(1500);
  // Defined in thingProperties.h
  initProperties();
  // Connect to Arduino IoT Cloud
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
     The following function allows you to obtain more information
     related to the state of network and IoT Cloud connection and errors
     the higher number the more granular information you’ll get.
     The default is 0 (only errors).
     Maximum is 4
  setDebugMessageLevel(2);
  ArduinoCloud.printDebugInfo();
  ArduinoCloud.update();
  // Your code here
  dht_sensor_getdata();
  Since Temperature is READ_WRITE variable, onTemperatureChange() is
  executed every time a new value is received from IoT Cloud.
void onTemperatureChange()  {
  // Add your code here to act upon Temperature change
  //float temp=dht.readTemperature();
  //Serial.print("Temperature ");
  //Serial.println(temp);
  //temperature=temp;
  Since Humidity is READ_WRITE variable, onHumidityChange() is
void onHumidityChange()  {
  // Add your code here to act upon Humidity change
void dht_sensor_getdata()
  float hm= dht.readHumidity();
  //Serial.print("Humidity ");
  //Serial.println(hm);
  humidity=hm;
  temperature=temp;
//    msg="Temperature = " + String (temperature)+"  Humidity = " + String(humidity);
It is possible. Please do this:
:exclamation: This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
  1. Click the following link to open the list of your Arduino Cloud Things in your web browser:
    https://app.arduino.cc/things
  2. Click on the Thing in the list.
    The "Setup" page for the Thing will open.
  3. Select the "Sketch" tab at the top of the page.
    The "Sketch" page for the Thing will open.
  4. Click the ✓ ("Verify") button on the sketch toolbar.
    A "verifying" operation will start.
  5. Wait for the operation to finish.
  6. Click the icon in the top right corner of the black console panel at the bottom of the page that looks like two pieces of paper:
    This will copy the contents of the console panel to the clipboard.
  7. Open a forum reply here by clicking the "Reply" button.
  8. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the compilation output correctly formatted.
    Code block icon on toolbar
  9. Press the Ctrl+V keyboard shortcut (Command+V for macOS users).
    This will paste the compilation output into the code block.
  10. Move the cursor outside of the code block markup before you add any additional text to your reply.
  11. Click the "Reply" button to post the output.
In case the output is longer than the forum software will allow to be added to a post, you can instead save it to a .txt file and then attach that file to a reply here:
  1. Open any text editor program.
  2. Paste the copied output into the text editor.
  3. Save the file in .txt format.
  4. Open a forum reply here by clicking the "Reply" button.
  5. Click the "Upload" icon (image) on the post composer toolbar:
    Upload icon on toolbar
    The "Open" dialog will open.
  6. Select the .txt file you saved from the "Open" dialog.
  7. Click the "Open" button.
    The dialog will close.
  8. Click the "Reply" button to publish the post.
Alternatively, instead of using the "Upload" icon on the post composer toolbar as described in steps (5) - (7) above, you can simply drag and drop the .txt file onto the post composer field to attach it.
Yes, and I can provide instructions for doing that, but we should determine which library is being used currently before doing that.
Thank you ptillisch for your reply. I've refined the code a little to deal with a nan problem and I also tried to use serial.println statements to help with debuging but I cannot see where the result is displayed.
Start verifying
[...] ibraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_default_pkcs1_sign.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_default_pkcs1_vrfy.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_default_priv.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_default_privexp.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_default_pub.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_default_pubexp.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i15_keygen.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i15_modulus.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i15_oaep_decrypt.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i15_oaep_encrypt.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i15_pkcs1_sign.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i15_pkcs1_vrfy.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i15_priv.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i15_privexp.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i15_pub.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i15_pubexp.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i31_keygen.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i31_keygen_inner.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i31_modulus.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i31_oaep_decrypt.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i31_oaep_encrypt.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i31_pkcs1_sign.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i31_pkcs1_vrfy.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i31_priv.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i31_privexp.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i31_pub.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i31_pubexp.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i32_oaep_decrypt.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i32_oaep_encrypt.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i32_pkcs1_sign.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i32_pkcs1_vrfy.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i32_priv.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i32_pub.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i62_keygen.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i62_oaep_decrypt.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i62_oaep_encrypt.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i62_pkcs1_sign.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i62_pkcs1_vrfy.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i62_priv.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_i62_pub.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_oaep_pad.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_oaep_unpad.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_pkcs1_sig_pad.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_pkcs1_sig_unpad.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/rsa_ssl_decrypt.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/settings.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/sha1.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/sha2big.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/sha2small.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/skey_decoder.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_ccert_single_ec.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_ccert_single_rsa.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_client.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_client_default_rsapub.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_client_full.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_engine.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_engine_default_aescbc.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_engine_default_aesccm.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_engine_default_aesgcm.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_engine_default_chapol.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_engine_default_descbc.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_engine_default_ec.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_engine_default_ecdsa.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_engine_default_rsavrfy.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_hashes.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_hs_client.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_hs_server.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_io.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_keyexport.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_lru.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_rec_cbc.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_rec_ccm.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_rec_chapol.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_rec_gcm.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_scert_single_ec.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_scert_single_rsa.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_server.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_server_full_ec.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_server_full_rsa.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_server_mine2c.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_server_mine2g.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_server_minf2c.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_server_minf2g.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_server_minr2g.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_server_minu2g.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/ssl_server_minv2g.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/sysrng.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/x509_decoder.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/x509_knownkey.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/x509_minimal.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/x509_minimal_full.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/profile/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/profile/aiotc_profile.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/utility/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/utility/Cert.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/utility/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/utility/CryptoUtil.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/utility/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/utility/SHA256.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/utility/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/utility/eccX08_sign_asn1.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/utility/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/utility/eccX08_vrfy_asn1.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/utility/ota/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/utility/ota/FlashSHA256.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/utility/ota/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/utility/ota/OTA-esp32.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/utility/ota/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/utility/ota/OTA-nano-rp2040.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/utility/ota/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/utility/ota/OTA-portenta-h7.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/utility/ota/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/utility/ota/OTA-samd.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/utility/ota/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/utility/ota/OTA-unor4.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/utility/ota/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/utility/ota/OTA.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/utility/time/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/utility/time/NTPUtils.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/utility/time/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/utility/time/RTCMillis.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/utility/time/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/utility/time/TimeService.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/utility/watchdog/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/utility/watchdog/Watchdog.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduino_connectionhandler_0_8_1/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduino_connectionhandler_0_8_1/Arduino_CatM1ConnectionHandler.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduino_connectionhandler_0_8_1/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduino_connectionhandler_0_8_1/Arduino_ConnectionHandler.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduino_connectionhandler_0_8_1/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduino_connectionhandler_0_8_1/Arduino_EthernetConnectionHandler.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduino_connectionhandler_0_8_1/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduino_connectionhandler_0_8_1/Arduino_GSMConnectionHandler.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduino_connectionhandler_0_8_1/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduino_connectionhandler_0_8_1/Arduino_LoRaConnectionHandler.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduino_connectionhandler_0_8_1/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduino_connectionhandler_0_8_1/Arduino_NBConnectionHandler.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduino_connectionhandler_0_8_1/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduino_connectionhandler_0_8_1/Arduino_WiFiConnectionHandler.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduino_debugutils_1_4_0/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduino_debugutils_1_4_0/Arduino_DebugUtils.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/WiFiS3/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/WiFiS3/Modem.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/WiFiS3/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/WiFiS3/StringHelpers.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/WiFiS3/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/WiFiS3/WiFi.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/WiFiS3/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/WiFiS3/WiFiClient.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/WiFiS3/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/WiFiS3/WiFiFileSystem.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/WiFiS3/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/WiFiS3/WiFiSSLClient.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/WiFiS3/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/WiFiS3/WiFiServer.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/WiFiS3/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/WiFiS3/WiFiUdp.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinomqttclient_0_1_7/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinomqttclient_0_1_7/MqttClient.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs "/tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/DHT sensor library/objs.a" "/tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/DHT sensor library/DHT.cpp.o"
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs "/tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/DHT sensor library/objs.a" "/tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/DHT sensor library/DHT_U.cpp.o"
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/OTAUpdate/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/OTAUpdate/OTAUpdate.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/RTC/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/RTC/RTC.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/adafruit_unified_sensor_1_1_14/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/adafruit_unified_sensor_1_1_14/Adafruit_Sensor.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/core/tmp_gen_c_files/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/core/tmp_gen_c_files/common_data.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/core/tmp_gen_c_files/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/core/tmp_gen_c_files/main.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/core/tmp_gen_c_files/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/core/tmp_gen_c_files/pin_data.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/core/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/core/variant.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -Wl,--gc-sections --specs=nosys.specs -w -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -o /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/Temp_and_Humidity_jan28a.ino.elf -L/tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79 -L/home/builder/.arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4 -T/home/builder/.arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/fsp.ld -Wl,--whole-archive /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/sketch/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/cbor/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/cbor/lib/tinycbor/src/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/property/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/bearssl/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/profile/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/tls/utility/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/utility/ota/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/utility/time/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinoiotcloud_1_13_0/utility/watchdog/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduino_connectionhandler_0_8_1/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduino_debugutils_1_4_0/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/WiFiS3/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/arduinomqttclient_0_1_7/objs.a "/tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/DHT sensor library/objs.a" /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/OTAUpdate/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/RTC/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/libraries/adafruit_unified_sensor_1_1_14/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/core/tmp_gen_c_files/objs.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/core/objs.a -Wl,--no-whole-archive -Wl,--whole-archive -Wl,--start-group /home/builder/.arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/libs/libfsp.a /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/../core/arduino_renesas_uno_unor4wifi_7e7888df26f0d93d01d8c4e2c8fd9bc1/core.a -Wl,--no-whole-archive --specs=nano.specs -lstdc++ -lsupc++ -lm -lc -lgcc -lnosys -Wl,--end-group -Wl,-Map,/tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/Temp_and_Humidity_jan28a.ino.map
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-objcopy -O binary -j .text -j .data /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/Temp_and_Humidity_jan28a.ino.elf /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/Temp_and_Humidity_jan28a.ino.bin
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-objcopy -O ihex -j .text -j .data /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/Temp_and_Humidity_jan28a.ino.elf /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/Temp_and_Humidity_jan28a.ino.hex
Multiple libraries were found for "DHT.h"
  Used: /mnt/create-efs/webide/9c/2e/9c2e862273688a0a97da95cf033a2e11:2tafotoxs/libraries_v2/DHT sensor library
  Not used: /home/builder/opt/libraries/esp826611_1_0_16
  Not used: /home/builder/opt/libraries/dht11esp8266examples_1_0_10
  Not used: /home/builder/opt/libraries/dht118266_1_0_16
  Not used: /home/builder/opt/libraries/grove_temperature_and_humidity_sensor_2_0_1
  Not used: /home/builder/opt/libraries/servodht11_1_0_10
  Not used: /home/builder/opt/libraries/dht_kxn_3_4_4
  Not used: /home/builder/opt/libraries/dht11esp8266_1_0_10
  Not used: /home/builder/opt/libraries/ukit_explore_1_2_28
  Not used: /home/builder/opt/libraries/dht_sensor_library_1_4_6
  Not used: /home/builder/opt/libraries/nanoplayboard_0_1_1
Multiple libraries were found for "RTC.h"
  Used: /home/builder/.arduino15/packages/arduino/hardware/renesas_uno/1.0.5/libraries/RTC
  Not used: /home/builder/opt/libraries/m5core2_0_1_8
  Not used: /home/builder/opt/libraries/m5station_0_0_1
  Not used: /home/builder/opt/libraries/m5stickc_0_2_9
  Not used: /home/builder/opt/libraries/m5stickcplus_0_1_0
Multiple libraries were found for "Adafruit_Sensor.h"
  Used: /home/builder/opt/libraries/adafruit_unified_sensor_1_1_14
  Not used: /home/builder/opt/libraries/arduav_1_4_2
Using library ArduinoIoTCloud at version 1.13.0 in folder: /home/builder/opt/libraries/arduinoiotcloud_1_13_0
Using library Arduino_ConnectionHandler at version 0.8.1 in folder: /home/builder/opt/libraries/arduino_connectionhandler_0_8_1
Using library Arduino_DebugUtils at version 1.4.0 in folder: /home/builder/opt/libraries/arduino_debugutils_1_4_0
Using library WiFiS3 at version 0.0.0 in folder: /home/builder/.arduino15/packages/arduino/hardware/renesas_uno/1.0.5/libraries/WiFiS3
Using library ArduinoMqttClient at version 0.1.7 in folder: /home/builder/opt/libraries/arduinomqttclient_0_1_7
Using library DHT sensor library at version 1.4.6 in folder: /mnt/create-efs/webide/9c/2e/9c2e862273688a0a97da95cf033a2e11:2tafotoxs/libraries_v2/DHT sensor library
Using library OTAUpdate at version 0.0.1 in folder: /home/builder/.arduino15/packages/arduino/hardware/renesas_uno/1.0.5/libraries/OTAUpdate
Using library RTC at version 1.0 in folder: /home/builder/.arduino15/packages/arduino/hardware/renesas_uno/1.0.5/libraries/RTC
Using library Adafruit Unified Sensor at version 1.1.14 in folder: /home/builder/opt/libraries/adafruit_unified_sensor_1_1_14
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-size -A /tmp/arduino-build-A751702083D7A3AEF7A900B8732B9A79/Temp_and_Humidity_jan28a.ino.elf
Sketch uses 103776 bytes (39%) of program storage space. Maximum is 262144 bytes.
Global variables use 9776 bytes (29%) of dynamic memory, leaving 22992 bytes for local variables. Maximum is 32768 bytes.
Used library              Version Path
ArduinoIoTCloud           1.13.0  /home/builder/opt/libraries/arduinoiotcloud_1_13_0
Arduino_ConnectionHandler 0.8.1   /home/builder/opt/libraries/arduino_connectionhandler_0_8_1
Arduino_DebugUtils        1.4.0   /home/builder/opt/libraries/arduino_debugutils_1_4_0
WiFiS3                    0.0.0   /home/builder/.arduino15/packages/arduino/hardware/renesas_uno/1.0.5/libraries/WiFiS3
ArduinoMqttClient         0.1.7   /home/builder/opt/libraries/arduinomqttclient_0_1_7
DHT sensor library        1.4.6   /mnt/create-efs/webide/9c/2e/9c2e862273688a0a97da95cf033a2e11:2tafotoxs/libraries_v2/DHT sensor library
OTAUpdate                 0.0.1   /home/builder/.arduino15/packages/arduino/hardware/renesas_uno/1.0.5/libraries/OTAUpdate
RTC                       1.0     /home/builder/.arduino15/packages/arduino/hardware/renesas_uno/1.0.5/libraries/RTC
Adafruit Unified Sensor   1.1.14  /home/builder/opt/libraries/adafruit_unified_sensor_1_1_14
Used platform       Version Path
arduino:renesas_uno 1.0.5   /home/builder/.arduino15/packages/arduino/hardware/renesas_uno/1.0.5
I'm using a DHT22 sensor on the cloud with no problems.
I do seem to recall it was fussy when I transferred my project to the cloud, but I'm unsure if the dht was the cause or the sht or bme I'm also running. In any case you might try download the whole sketch and install different librarys in IDE. I've use the adafruit unified sensor library, and even though I don't #include it, if I uninstall the library the sketch won't compile or work without it.
But all readings are good.
Thank you for your reply arneko.
The same DHT library by Adafruit version 1.4.2 works perfectly in the IDE. The board I'm using is the UNO R4 WiFi.
You can see which library is being used to compile your sketch here:
You can compile that sketch and then examine the contents of the console panel after the compilation finishes to verify that the same library ("DHT sensor library") and library version (1.4.6) is being used when compiling the working sketch.
Is there a specific reason you are using the outdated version 1.4.2 of the library in Arduino IDE instead of the latest version of the library 1.4.6?
If there is a reason for using 1.4.2, it is possible to configure your sketch on Arduino Cloud to use version 1.4.2 of the library.
If you aren't sure whether the differences in the library versions is the cause of the different results, you can try using the Arduino IDE Library Manager to update your local installation of the "DHT sensor library" to 1.4.6, then upload the working sketch to your board again to check whether it continues to work as expected.
Thank you again ptillisch for your reply.
I've been going around in circles for two days now and have become frustrated with this project and as a result I've given you incorrect information. The DHT library version that I had already installed in the off line IDE is 1.4.6 which is the same version that is automatically used in the cloud generated code without me having to install any DHT library. The verify listing that I posted does show that the DHT library version is 1.4.6.
The automatically generated cloud code does not work for me. It either reads nan (not a number) from the sensor or if it does read a number it is wildly incorrect. The temperature is less that half the correct temperature and the humidity is around 3,330 percent. If I hard code a number for temperature and humidity then the dashboard gauges display those values.
I'm really at my wit's end with this. I've spent hours searching the forum and the Internet in general for clues but I'm still not any wiser. Could the problem possibly be due the the UNO R4 WiFi board that I'm using?
I forgot to mention that the DHTtester example code does run correctly from the cloud IDE as well as the off line IDE. So that probably means that the board is cloud compatible and that the problem seems to be with the automatically generated cloud code.
Success!
After thinking about arneko saying that he'd used adafruit's unified DHT library I thought I'd give that a go and that was the answer.
There's a lot of outdated stuff on the Internet. Is there a repository of recent working IoT examples somewhere?
Congratulations on finding a solution! I'm glad it is working now. Thank you for taking the time to post an update with your findings.
Probably not exactly what you are looking for, but Arduino does maintain a collection of "Templates" for Arduino Cloud IoT projects:
https://app.arduino.cc/templates
Thank you again ptillisch. There's a lot of information available from the templates page and I see that I cannot import the things but I can see what's need from the template document. I might upgrade after all.
You are welcome. I think the templates are a nice feature. The "Cloud Blink" template is a great way to get a basic "hello world" type of Arduino Cloud IoT project up and running very quickly with the minimum amount of difficulty.
The Templates feature is usable even with the "Free" plan, but importing a template creates a new Arduino Cloud Thing. So you will not be able to import a template if you have already created the maximum number of Things allowed by your plan (which is two in the case of the "Free" plan). If you delete one of your existing Things, you will find that you are now able to import a template.
And of course if you upgrade your Arduino Cloud plan then you will have the ability to create more Things and then you will also find that importing templates is enabled.
