DHT11 does not go over 2.5 C
Initially DHT11 gives me around 1.50 C and 10% humidity. When I put my finger on sensor, these values go up. The problem is that after 2.50 C jumps at 1C and after 27% jumps at 1% and continue to go up.
A wiring diagram and code would help us debug your problem.
plus of sensor is connected at 5V
minus of sensor is connected at GND
OUT is connected at PIN 2
The code is the next one:
#include <DHT.h>
#define DHTPIN 2
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
  dht.begin();
  float humidity = dht.readHumidity();
  float temperature = dht.readTemperature();
  if (isnan(humidity) || isnan(temperature)) {
    Serial.println("Error: Failed to read from sensor!");
    delay(2000);
    return;
  Serial.print("Humidity: ");
  Serial.print(humidity);
  Serial.println(" %");
  Serial.print("Temperature: ");
  Serial.print(temperature);
  Serial.println(" °C");
  delay(6000);
Your code is not posted correctly
In the IDE click on Edit, then Copy for Forum, that will copy your code for the forum.
Then come back here and do a paste. You will see a difference on how the code is posted.
#include <DHT.h>
#define DHTPIN 2
  dht.begin();
    delay(2000);
    return;
  delay(6000);
I don't see anything wrong with the wiring or the code.
The DHT11 module may be faulty
