Hello,
I am trying to get meaningful information from a DHT11 sensor using an Arduino UNO board.
This should be a straight-forward little project but i am out of ideas about what i might be doing wrong, except that the DHT11 sensor might be broken. I tried another DHT11 sensor and same problem.
This is the library that i'm using: Arduino/libraries/DHTstable at master · RobTillaart/Arduino · GitHub
I'm using the example sketch: Arduino/dht11_test.ino at master · RobTillaart/Arduino · GitHub
I changed the digital pin to 7 based on my setup and also changed the default baud rate from 115200 to 9600:
// FILE: dht11_test.ino
// AUTHOR: Rob Tillaart
// VERSION: 0.1.01
// PURPOSE: DHT library test sketch for DHT11 && Arduino
// URL:
// Released to the public domain
#include <dht.h>
dht DHT;
#define DHT11_PIN 7
Serial.println("DHT TEST PROGRAM ");
Serial.print("LIBRARY VERSION: ");
Serial.println(DHT_LIB_VERSION);
Serial.println("Type,\tstatus,\tHumidity (%),\tTemperature (C)");
// READ DATA
Serial.print("DHT11, \t");
int chk = DHT.read11(DHT11_PIN);
switch (chk)
case DHTLIB_OK:
Serial.print("OK,\t");
case DHTLIB_ERROR_CHECKSUM:
Serial.print("Checksum error,\t");
case DHTLIB_ERROR_TIMEOUT:
Serial.print("Time out error,\t");
default:
Serial.print("Unknown error,\t");
// DISPLAY DATA
Serial.print(DHT.humidity, 1);
Serial.print(",\t");
Serial.println(DHT.temperature, 1);
delay(2000);
This is the current output from the Arduino IDE Serial Monitor:
DHT TEST PROGRAM
LIBRARY VERSION: 0.2.3 - dhtstable
Type, status, Humidity (%), Temperature (C)
DHT11, Time out error, -999.0, -999.0
This is my connection setup with R1 as a 10K Ohm pull up resistor:
