Dht11 with pulse rate sensor
Hi everyone I am currently facing challenges regarding combining the DHT11 code with the Pulse sensor ,they can not run at the same
time can you kindly assist me ,even when I add a Servo motor, have decide to comment out the Servo for it gives me an error please have a look on my code.
#include <SoftwareSerial.h>
//#include <Servo.h> // include library
#include <dht.h>  // Include library
#include <LiquidCrystal_I2C.h> //Liquid Crystal Display with I2C
LiquidCrystal_I2C lcd(0x27, 16, 2);
#define USE_ARDUINO_INTERRUPTS true
#include <PulseSensorPlayground.h>     // Includes the PulseSensorPlayground Library.
//Servo myflag;  // create servo object to control a servo
// twelve servo objects can be created on most boards
//Alert reciever's phone number with country code
const String PHONE_1 = "+27737838775";
const String PHONE_2 = ""; //optional
const String PHONE_3 = ""; //optional
PulseSensorPlayground pulseSensor;  // Creates an instance of the PulseSensorPlayground object called "pulseSensor"3
#define rxPin 2
#define txPin 3
SoftwareSerial sim800L(rxPin,txPin);
// Creates a DHT object
dht DHT;
#define outPin 7  // Defines pin number to which the sensor is connected
const int PIN_SPEAKER = 12;    // speaker on pin2 makes a beep with heartbeat
const int OUTPUT_TYPE = SERIAL_PLOTTER;
const int PULSE_INPUT = A0;
const int PULSE_BLINK = 13;    // Pin 13 is the on-board LED
const int PULSE_FADE = 5;
const int THRESHOLD = 550;   // Adjust this number to avoid noise when idle
int RelayBuzzer = 8;
int pos = 0;    // variable to store the servo position
//#define buzzer_pin 4
  //Begin serial communication: Arduino IDE (Serial Monitor)
  lcd.init();   // LCD screen
  lcd.backlight();
  // Configure the PulseSensor manager.
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("PulseSensor");
  // Configure the PulseSensor object, by assigning our variables to it.
  pulseSensor.analogInput(PULSE_INPUT);
  pulseSensor.blinkOnPulse(PULSE_BLINK);
  pulseSensor.fadeOnPulse(PULSE_FADE);
  pulseSensor.setSerial(Serial);
  pulseSensor.setOutputType(OUTPUT_TYPE);
  pulseSensor.setThreshold(THRESHOLD);
  lcd.backlight();
  //Begin serial communication: SIM800L
  sim800L.begin(9600);
    pinMode(RelayBuzzer,OUTPUT);
  //myflag.attach(9);  // attaches the servo on pin 9 to the servo object
   //pinMode(Buzzer,OUTPUT);
  Serial.println("Initializing...");
  //Once the handshake test is successful, it will back to OK
  sim800L.println("AT");
  sim800L.println("AT+CMGF=1");
   if (!pulseSensor.begin())
    for(;;) {
      // Flash the led to show things didn't work.
      digitalWrite(PULSE_BLINK, LOW);
      delay(50);
      digitalWrite(PULSE_BLINK, HIGH);
      delay(50);
  while(sim800L.available())
  Serial.println(sim800L.readString());
 int myBPM = pulseSensor.getBeatsPerMinute();  // Calls function on our pulseSensor object that returns BPM as an "int".
  delay(20);
  // write the latest sample to Serial.
  pulseSensor.outputSample();
  if (pulseSensor.sawStartOfBeat())
 pulseSensor.outputBeat();
 tone(PIN_SPEAKER,900,300);// tone(pin,frequency)
 digitalWrite(RelayBuzzer,LOW);
 Serial.println("♥  A HeartBeat Happened ! "); // If test is "true", print a message "a heartbeat happened".
 Serial.print("BPM: ");                        // Print phrase "BPM: "
 Serial.println(myBPM);
 lcd.clear();
 lcd.setCursor(0,0);
 lcd.print("HeartBeat");
 lcd.setCursor(0,1);
 lcd.print("BPM: ");
 lcd.setCursor(4,1);
 lcd.print(myBPM); // Print the value inside of myBPM.
else if(pulseSensor.isInsideBeat() == false)
   ///digitalWrite(RelayBuzzer,HIGH);
   noTone(PIN_SPEAKER);
  if( myBPM >= 120 || myBPM <= 30  )
     send_multi_sms();
     make_multi_call();
  //The fire is detected, trigger Alarm and send sms
 /*void DHT_11()
   int readData = DHT.read11(outPin);
  float t = DHT.temperature;  // Read temperature
  float h = DHT.humidity;   // Read humidity
  lcd.setCursor(4,1);
  lcd.print("Temp= ");
  lcd.print(t);
  lcd.print("°C |");
  delay(2000);
  lcd.setCursor(4,1);
  lcd.print("Hum = ");
  lcd.print(h);
  lcd.println("% ");
  lcd.println("");
  delay(2000); // wait two seconds
void send_multi_sms()
  if(PHONE_1 != ""){
    Serial.print("Phone 1: ");
    send_sms("Emergency on the Patient ", PHONE_1);
  if(PHONE_2 != ""){
    Serial.print("Phone 2: ");
    send_sms("Emergency on the Patient ", PHONE_2);
  if(PHONE_3 != ""){
    Serial.print("Phone 3: ");
    send_sms("Emergency on the Patient ", PHONE_3);
void make_multi_call()
  if(PHONE_1 != ""){
    make_call(PHONE_1);
  if(PHONE_2 != ""){
    make_call(PHONE_2);
  if(PHONE_3 != ""){
    make_call(PHONE_3);
void send_sms(String text, String phone)
{  // lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("sending sms....");
    delay(50);
    sim800L.print("AT+CMGF=1\r");
    sim800L.print("AT+CMGS=\""+phone+"\"\r");
    sim800L.print(text);
    delay(100);
    sim800L.write(0x1A); //ascii code for ctrl-26 //Serial2.println((char)26); //ascii code for ctrl-26
    delay(5000);
void make_call(String phone)
{  // lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("calling....");
    sim800L.println("ATD"+phone+";");
    delay(20000); //20 sec delay
    sim800L.println("ATH");
    delay(1000); //1 sec delay
This is interesting as the DHT sensor isn't read in this sketch. Why do you think they cannot run together?
Remove all delay() call from your sketch!
