DHT22 sometimes read, sometimes not
I have a very simple program, with just a DHT22 conected to 5V and a 10K resistor at the data pin...
Look at my program and the serial print:
#include <DHT.h>
DHT dht(2, DHT22);
  dht.begin();
  delay(3000);
  float h = dht.readHumidity();
  float t = dht.readTemperature();
  // check if returns are valid, if they are NaN (not a number) then something went wrong!
  if (isnan(t) || isnan(h)) {
    Serial.println(F("Failed to read from DHT"));
  else {
    Serial.print(F("Humidity: "));
    Serial.print(h);
    Serial.print(F(" %\t"));
    Serial.print(F("Temperature: "));
    Serial.print(t);
    Serial.println(F(" C"));
The serial print:
Humidity: 57.90 % Temperature: 22.40 C
Humidity: 58.00 % Temperature: 22.40 C
Can somebody tell me whats is going on ?
Thanks
Luiz
I have turned DEBUG ON... and this is the print...
Received:
2, 49, 0, E0, 2B =? 12B
Humidity: 58.50 % Temperature: 22.40 C
Received:
2, 4C, 0, E0, 2E =? 12E
Humidity: 58.80 % Temperature: 22.40 C
Received:
2, 4E, 0, E0, 30 =? 130
Humidity: 59.00 % Temperature: 22.40 C
Received:
2, 4D, 0, 60, 2F =? AF
Checksum failure!
Received:
Received:
2, 4B, 0, E0, 2D =? 12D
Humidity: 58.70 % Temperature: 22.40 C
Received:
2, 4B, 0, 60, 2D =? AD
Checksum failure!
Received:
2, 4A, 0, E0, 2C =? 12C
Humidity: 58.60 % Temperature: 22.40 C
Received:
Received:
2, 4A, 0, 60, 2C =? AC
Checksum failure!
Received:
Received:
Received:
Checksum failure!
Received:
2, 4C, 0, 60, 2E =? AE
Checksum failure!
do you have a pull up resistor on the data line?
what length is the line?
Yes, i have a 10k resistor for pull-up in data pin..
The line is really smal. i have a DHT22 directly to the protoboard, conected with jumpers of 10cm directly to the arduino UNO board...
bad connections can do this
I think that the problem is solved...
I was using this LIB: GitHub - adafruit/DHT-sensor-library: Arduino library for DHT11, DHT22, etc Temperature & Humidity Sensors
Then i founded this thread: Class for DHT11, DHT21 and DHT22 (temperature & humidity) - Libraries - Arduino Forum
So I tried this LIB: Arduino/libraries/DHTstable at master · RobTillaart/Arduino · GitHub
And it works perfectly...
Thanks 'robtillaart' for your work...
Luiz
You're welcome
Still important to check your wires as knut_ny said :wink:
lczancanella:
Luiz
Hi there... its an old post but Im having the same problem, did you change anything to the code when loading the new library, or used the same code?
Thanks,
