DHT22 values fine but no float (comma) values
I am using an Arduino Nano, with DHT22 and the Adafruit ssd1306 OLED screen.
Everything works almost 100% the way I'd like, but I get no decimal (comma) values, only whole values like 16 and not 16.30 or 24.60 or the likes...
This is the code I'm using.. I have the tempC, tempF and humi variables set up as "float" so I don't (yet) understand why I don't get those fractions:
//DHT sensor
#include "DHT.h"
#include <DHT_U.h>
#define DHT22Pin 2
#define DHTType DHT22
//OLED
#include  <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
DHT  HT(DHT22Pin,DHTType);
float humi;
float tempC;
float tempF;
//OLED  define
#define SCREEN_WIDTH 128 //OLED display width, in pixels
#define SCREEN_HEIGHT  64 //OLED display height, in pixels
//SSD1306 display connected  to I2C (SDA, SCL pins)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT,  &Wire, -1);
  //For DHT22
  HT.begin();
  //Necessary code for OLED I2C
  if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C))  { // Address 0x3D for 128x64
    Serial.println(F("SSD1306 allocation failed"));
    for(;;);
  display.display(); //Displays the starting logo
  display.clearDisplay();
 delay(2000);
 humi =  HT.readHumidity();
 tempC = HT.readTemperature();
 tempF = HT.readTemperature(true);
  oledDisplayHeader();
 //configures the position of the readings. (charactersize, x axis value, y axis value, reading, symbol)
oledDisplay(2,90,28,humi,"%");
 oledDisplay(2,-10,44,tempF,"F");
  oledDisplay(2,-10,16,tempC,"C");
 display.display();
void  oledDisplayHeader(){
  //configures position and qualities of headers
 display.setTextSize(1);
 display.setTextColor(WHITE);
  display.setCursor(0, 0);
 display.print("Temperature");
 display.setCursor(80,  0);
 display.print("Humidity");
void oledDisplay(int size, int x,int  y, float value, String unit){
 int charLen=18;
 int xo=x+charLen*3.2;
  int xunit=x+charLen*3.6;
 int xval = x;
 display.setTextSize(size);
 if (unit=="%"){
   display.setCursor(x, y);
   display.print(value,0);
   display.print(unit);
   if (value>99){
    xval=x;
   }  else {
    xval=x+charLen;
   display.setCursor(xval, y);
   display.drawCircle(xo, y+2, 2, WHITE);  // print degree symbols
   display.setCursor(xunit,  y);
I know the topic sounds similar to others, but others did not answer my question.
Hopefully someone will point out what I should change, thanks in advance :slight_smile:
Thanks Delta! I will try that.
You helped me on the right path, thanks Delta! I also then had to shrink the text size of the values themselves, to 1 instead of 2, to fit the degrees sign and "%" and fractions in their own lines.
