I am making a robot arm with a master-slave controlling system and was wondering if there is an advantage to using this:
as opposed to this:
Thanks
as opposed to this:
Thanks
One is intelligent (PCA9685), and the other one seems to be a "connectors only" shield.
A command writen to the PCA9685 is executed after that independent of the Arduino.
The Arduino is free to do other things (untill the next command).
Maybe better to use a breakout board instead of a shield if you plan to use more than 16 servos.
Multiple boards (with different addresses) can use the same two I2C lines.
Leo..
Wawa:
One is intelligent (PCA9685), and the other one seems to be a "connectors only" shield.A command writen to the PCA9685 is executed after that independent of the Arduino.
The Arduino is free to do other things (untill the next command).Maybe better to use a breakout board instead of a shield if you plan to use more than 16 servos.
Multiple boards (with different addresses) can use the same two I2C lines.Leo..
The Arduino will only need to control the servos, no other tasks. Will there be a difference in performance? I will be controlling no more than 8 servos.
