Different color for error's and warning's
Searching here and there about this and trying to find where to put my own theme, my guess is that I have to ask it here.
macOS using IDE Version: 2.3.6
Date: 2025-04-09T11:22:51.016Z
CLI Version: 1.2.0
Trying and with the topics here.
How can I change the error and warning colors in the compiler output?
For example, I’d like to change the warning color to orange so I can better distinguish it from errors. Is that possible?
Additionally, where should I place downloaded themes?
Some websites say to put them in the themes folder inside Arduino.app/Contents/Java/, but there’s no Java folder in my installation.
Other pages mention a themes or plugins folder inside ~/.arduinoIDE/, but those don’t exist — and creating them manually doesn’t work either. Then there’s no option available in the “Theme” dropdown menu in the Preferences window.
I think you need to create the themes or plugins folder inside the hiddden ~/.arduinoIDE folder.
Perhaps if you posted a theme file the rest of us could experiment with it and update you if we have good luck.
Hi @ipadawan.
That information is for Arduino IDE 1.x. Arduino IDE 2.x has a completely different theme system, so any information you find about Arduino IDE 1.x themes is not relevant.
A community member shared some information about using 3rd party themes, and creating custom themes for Arduino IDE 2.x here:
You should install themes under a folder named plugins.
It should definitely work if you follow the instructions provided in the post I linked above. If you follow those and still encounter a problem, provide a detailed description of what you did and what didn't work in a reply here on this forum topic and we'll try to help with that.
Please note that Arduino IDE 2.x does not support Arduino IDE 1.x themes, so if you installed an Arduino IDE 1.x theme, then it is normal and expected that Arduino IDE 2.x did not recognize it.
