Is it possible to use one delay for an if, and then another for the else? And can this be done without using any external delays?
I have tried to do it in this code, but it ended up printing constantly with "no" delay for 12 hours:
#include <DHT.h>
#include <SoftwareSerial.h>
#include <SDS011.h>
#include <TinyGPS++.h>
#include <SD.h>
// Klargjør for temperatur og fuktighet
#define DHTPIN 9
DHT dht22(DHTPIN, DHT22);
// Klargjør led-lysene rød og grønn
#define LED_RED A1
#define LED_GREEN A0
// Klargjør gps modul
#define GPS_RX 7
#define GPS_TX 6
SoftwareSerial gpsCom(GPS_RX, GPS_TX);
TinyGPSPlus gps;
// Klargjør PM modul
#define PM_TX 2
#define PM_RX 3
SDS011 sds;
#define SD_CS_PIN 10
File file;
int counter = -1;
int counter2 = 0;
pinMode(SD_CS_PIN, OUTPUT);
SD.begin(SD_CS_PIN);
gpsCom.begin(9600);
sds.begin(PM_TX, PM_RX);
char filename [] = "Airbit-1.txt";
if (SD.exists(filename)) {
file = SD.open(filename, O_WRITE | O_APPEND);
file.println("--------------------");
file.println("Filen ble åpnet på nytt.");
file = SD.open(filename, O_CREAT | O_WRITE);
file.println("Dette er starten av filen.");
file.flush();
gpsCom.listen();
bool gpsEncodeComplete = false;
do{
if(!gpsCom.available()) {
continue;
gpsEncodeComplete = gps.encode(gpsCom.read());
if (!gpsEncodeComplete){
continue;
}while (!gpsEncodeComplete); {
bool gpsValid = gps.location.isValid();
bool gpsUpdated = gps.location.isValid();
bool isUseful = gpsValid && gpsUpdated;
// nullstill temperatur og fuktighet
float temperature = 0;
float humidity = 0;
temperature = dht22.readTemperature();
humidity = dht22.readHumidity();
float pm25, pm10;
int error;
do{
error = sds.read(&pm25, &pm10);
} while (error != 0);
if (!isUseful) {
file.print("NoGPS");
file.print(", ");
file.print(counter);
file.print(", ");
file.print(temperature);
file.print(", ");
file.print(humidity);
file.print("%");
file.print(", ");
file.print(pm25);
file.print(", ");
file.print(pm10);
file.println(" ");
file.flush();
delay(2000);
} else if (gps.time.hour() >=5 && gps.time.hour() <=17) {
file.print(gps.date.day());
file.print(".");
file.print(gps.date.month());
file.print(".");
file.print(gps.date.year());
file.print(" ");
file.print(gps.time.hour());
file.print(":");
file.print(gps.time.minute());
file.print(", ");
file.print(counter2);
file.print(", ");
file.print(", ");
file.print("%");
file.print(", ");
file.print(pm25);
file.print(", ");
file.print(pm10);
file.println(" ");
file.flush();
counter2 = counter2 + 1;
delay(900000);
file.print("GPSWait");
file.print(", ");
file.print(", ");
file.print(", ");
file.print("%");
file.print(", ");
file.print(pm25);
file.print(", ");
file.print(pm10);
file.println(" ");
file.flush();
delay(900000);
counter = counter + 1;
