Hi!
I try to run Timer0 and Timer2 at different speeds on an Arduino Uno, but no matter what I set the bits to they count exactly at the same speed
My code:
volatile uint32_t cnt0, cnt2, c0, c2 = 0;
cli(); //stop interrupts while we setup the timers
/*1. First we reset the control register to make sure we start with everything disabled.*/
TCCR0A = 0; // Reset entire TCCR0A to 0
TCCR0B = 0; // Reset entire TCCR0B to 0
TCCR2A = 0; // Reset entire TCCR2A to 0
TCCR2B = 0; // Reset entire TCCR2B to 0
/*2. We set the prescalar to the desired value */
TCCR0B |= B00000001; //Set CS00 to 1 so we get no prescalar
TCCR2B |= B00000001; //Set CS01 to 1 so we get no prescalar
/*3. We enable compare match mode on register A */
TIMSK0 |= B00000010; //Set OCIE0A to 1 so we enable compare match A
TIMSK2 |= B00000010; //Set OCF2A to 1 so we enable compare match A
/*4. Set the value of register A */
OCR0A = 50;
OCR2A = 100;
sei(); //Enable back the interrupts
ISR(TIMER0_COMPA_vect){
TCNT0 = 0; //First, set the timer back to 0 so it resets for next interrupt
cnt0++;
ISR(TIMER2_COMPA_vect){
TCNT2 = 0; //First, set the timer back to 0 so it resets for next interrupt
cnt2++;
noInterrupts();
c0 = cnt0;
c2 = cnt2;
interrupts();
Serial.print(c0);
Serial.print(" ");
Serial.println(c2);
Here's your original sketch with the prescalers of both timers set to 1024. The counts are 2x
//TCCR0B |= B00000001; //Set CS00 to 1 so we get no prescalar
//TCCR2B |= B00000001; //Set CS01 to 1 so we get no prescalar
TCCR0B |= B00000101; //Set CS00 to 5 so we get prescalar 1024
TCCR2B |= B00000111; //Set CS01 to 5 so we get prescalar 1024
OCR0A = 50;
OCR2A = 100;
cnt0++;
cnt2++;
noInterrupts();
c0 = cnt0;
c2 = cnt2;
interrupts();
Serial.print(c0);
Serial.print(" ");
Serial.println(c2);
Thank you for your replies! I should have mentioned this in my original question but In the end I wish to do audio manipulation. Specifically a very subtle audio pitch shift using one timer to read the ADC and the second to output to a DAC at a slightly slower speed. So one timer would ideally run at 44100 Hz or something in that ballpark and the other at 98,2% of this speed. A prescaler of 1024 gives too slow results. Even a prescaler of 8 gives too slow results I believe although I have a bit of trouble doing the math . So should I be using different chip all together?
Of course you should. The Uno processor is very old, and very under powered for real world audio applications. Also some processors have a built in DAC, which the Uno lacks.
Yeah I guessed as much, but I'm new to the whole port manipulation thing and I find it kinda interesting so I thought I start at the UNO. Also it is kind of cheap and I have them laying around. So I guess an ESP32 or Pico might be the way to go... I'm really sorry if I wasted anybody's time but your feedback was not lost on me!
In the past, while creating complementary waveforms for both channels of TC1 in Mode-14, I found due to @cattledog's courtesy that the TC1 should had been STARTED (connection of clkTC1) once all the necessary initializations are done! The same thing could be followed for TC0 and TC2.
Thank you for your feedback! I have been considering Teensies if the Arduino route would not work out, but since I’m developing a product to be sold, I’m looking for a board that is less expensive. Perhaps I could release a premium version w/ flac like audio quality at a higher price point and use Teensies for that!
