DigiKeyboard for QWERTY unavailable
Hello there :wave: I am in need of installing a package called "Digikeyboard" for programming ATTiny85 by Digispark. As it seems there is only packages for AZERTY & Belgian AZERTY layout. How can I get it for QWERTY layout keyboard system??
I already installed ATTinyCore board manager in my Arduino IDE (version : 2.2.1) & all the necessary drivers installed in my pc for the working of the board. Am I missing anything??
Try to find the files on github. I have no experience with DigiSparks but this link (GitHub - digistump/DigisparkArduinoIntegration: DEPRECATED - REPLACED BY: https://github.com/digistump/DigistumpArduino) might contain what you need. Download and add as zip library (not tried).
this are addons for a library. download lib itself from github. it is definitely QWERTY
or type correct name in lib manager and not forget to select the right board
First of all I can't install Digistump AVR boards from the board manager in the IDE as it doen't show up when I searched after adding url preference. I think this might be the problem. I believe that board manager has a built in support for Digikeyboards commands. I will keep digging to encounter this issue. If anybody knows kindly leave a comment!!
Arduino LLC is a company sells boards under Arduino Trademark and is not responsible for any other boards in the world even if they using AVR chip too.
ArduinoIDE allow adding .JSON file in preferences to be able to download and install other boards in this IDE.
