Digital Barometric Pressure Sensor 2SMPB-02E (SPI library)
Hello,
we are trying to use 2SMPB-02E sensor (Digital Barometric Pressure Sensor) in our project. We would like to use the SPI interface, but the only Arduino library we have found for this sensor (GitHub - omron-devhub/2smpb02e-grove-arduino) is one that seems to only support the I2C interface.
Does anyone know any other library for this sensor that takes advantage of the SPI interface - preferably using unrestricted Arduino pins?
Search for a sensor that comes with an Arduino library and examples or ask your supplier.
A lack of a library probably saved you from destroying the sensor. Since there is no schematic I assumed you connected directly to the Arduino. You can use any pins you like if you use bit banging software.
