Digital Volume with CD4067 + ATtiny85
Here’s a small project I did to add a Digital Stereo Volume on my Car-Stereo using 2x CD406, 1x ATtiny85 and just one touch-sensitive button: single click = volume down, double click + hold = volume up.
I adapted the following circuit: http://english.cxem.net/izmer/measured3-2.jpg
And here’s the code for the ATtiny85. It uses the libs and explanations from the Beat707 BigTime code.
https://github.com/Beat707/Beat707-BigTime
// Arduino Stereo Volume - by WilliamK @ Wusik.com & Beat707.com - October 04 2011 - V 1.0.0 //
#include <EEPROM.h>
  The system uses a Touch Pin (Capacitive Touch) to do the following: single click = volume down / double click = volume up (also supports "holding & repeat" for both actions).
  We use two C4067 multiplexers chips (we had those in our old-stock) with different resistors on each input and a ATtiny85 to controll the system.
  ATtiny85 pins:
    8 = 5V
    4 = Ground
    3 = Touch Sensor
    5 = C4067 S0
    6 = C4067 S1
    7 = C4067 S2
    2 = C4067 S3
  4067 pins:
    1 = Output
    24 = 5V
    12 = Ground
    10 = S0
    11 = S1
    14 = S2
    13 = S3
    15 = Ground
    9 = Input 0 (no volume)
    8 = Input 1 (Volume 1)
    7 = Input 2 (Volume 2)
    6 = Input 3 (Volume 3)
    5 = Input 4 (Volume 4)
    4 = Input 5 (Volume 5)
    3 = Input 6 (Volume 6)
    2 = Input 7 (Volume 7)
#define outPinSel0 PINB0  // Output pin for the S0 4067 Multiplexer - Pin 5 on the ATtiny85
#define outPinSel1 PINB1  // Output pin for the S1 4067 Multiplexer - Pin 6 on the ATtiny85
#define outPinSel2 PINB2  // Output pin for the S2 4067 Multiplexer - Pin 7 on the ATtiny85
#define outPinSel3 PINB3  // Output pin for the S3 4067 Multiplexer - Pin 2 on the ATtiny85
#define touchPin PINB4    // Pin 3 on the ATtiny85
#define doubleClick 200   // Time for the Double Click in ms (Volume Up)
int def2, num1, num2, num3, def = 0;
uint8_t isOn = false;
uint8_t prevIsOn = false;
unsigned long lastMillis = millis();
uint8_t prevButton = 0;
uint8_t curButton = 0;
uint8_t wasButtonLow = 1;
uint8_t volumeSelector = 0;
uint8_t isDoubleClick = 0;
void setVolumeOutputTo4067Chip()
  digitalWrite(outPinSel0, bitRead(volumeSelector,0));
  digitalWrite(outPinSel1, bitRead(volumeSelector,1));
  digitalWrite(outPinSel2, bitRead(volumeSelector,2));
  digitalWrite(outPinSel3, bitRead(volumeSelector,3));
  pinMode(outPinSel0, OUTPUT);
  pinMode(outPinSel1, OUTPUT);
  pinMode(outPinSel2, OUTPUT);
  pinMode(outPinSel3, OUTPUT);
  pinMode(touchPin, INPUT);
  /*digitalWrite(outPinSel0, HIGH);
  digitalWrite(outPinSel1, HIGH);
  digitalWrite(outPinSel2, HIGH);
  digitalWrite(outPinSel3, HIGH);
  delay(250);*/
  digitalWrite(outPinSel0, LOW);
  digitalWrite(outPinSel1, LOW);
  digitalWrite(outPinSel2, LOW);
  digitalWrite(outPinSel3, LOW);
  prevButton = getcap(1<<touchPin);
  curButton = getcap(1<<touchPin);
  if (curButton != prevButton)
    prevButton = curButton;
    if (wasButtonLow == 1 && curButton > 1)
      wasButtonLow = isDoubleClick = 0;
      // Detect Double Click //
      delay(doubleClick);
      if (getcap(1<<touchPin) <= 1)
        delay(doubleClick);
        if (getcap(1<<touchPin) > 1) isDoubleClick = 1;
      if (isDoubleClick) { if (volumeSelector < 8) volumeSelector++; } else  { if (volumeSelector > 0) volumeSelector--; }
      setVolumeOutputTo4067Chip();
      if (getcap(1<<touchPin) > 1) delay(400);
      while (1)
        if (getcap(1<<touchPin) <= 1) break;
        delay(400);
    if (curButton <= 1) wasButtonLow = 1;
char getcap(char pin)
  char i = 0;
  DDRB &= ~pin;          // input
  PORTB |= pin;          // pullup on
  for(i = 0; i < 2; i++)
    if( (PINB & pin) ) break;
  PORTB &= ~pin;         // low level
  DDRB |= pin;           // discharge
  return i;
