digitalRead not working correctly
Hey guys,
The digital read appears to be random. it changes from high to low whenever it contects with a wire, which is not connected to an energy source. I debugged it with a serialconnection and it indeed showed a random stream of 0 and 1's while only plain wire was connected. I have used different digital inputs but the bug remained.
Anyone knows what might be wrong?
Thanks in advance,
PixelMaster
There's nothing wrong, your pin is floating.
That's what we call an antenna.
Yes this happens, it is called a floating input and it seems to surprise beginners. You must connect a digital input to something and not leave it unconnected. Look at pull up resistors.
AWOL: There's nothing wrong, your pin is floating.
Whats that?
It isn't part of a complete circuit.
PixelMaster: Hey guys,
Thanks in advance,
PixelMaster
As several have stated you are reading a 'floating' input. To put it simple, I would ask you what would be your expections on reading a input pin that has nothing wired to it (or even a wire which is not wired to anything but the input pin)? If you said it should read LOW that would be in error. The correct answer is that a input pin that is floating is not a legally defined input state and will randomly read either high or low as circuit noise determines. The input pin must be electrically be wired to a voltage source that is either 0vdc (low) or +5vdc (high) to operate correctly.
Lefty
Nothing is wrong, read this:-
http://www.thebox.myzen.co.uk/Tutorial/Inputs.html
So if I connect the the pin to a ground it will work? (just making sure I have that correct)
PixelMaster: So if I connect the the pin to a ground it will work? (just making sure I have that correct)
http://www.cmiyc.com/tutorials/arduino-pull-ups/
Videos of what your pin is doing, along with an explanation of how to use the internal pull-ups to keep the pin from floating.
Thanks for the Help :) I fixed it
