Hi, i have a problem with digitalWrite HIGH-LOW commands. My problem is basicly LOW and HIGH commands work opposite.
For example:
digitalWrite(relay1, LOW);
Make relay active and if i use high command, it deactives.
For example:
Hi @peregrin3
Everything is a matter of reference.
In order to explain it better, post a schematic of your project.
It can even be done freehand.
RV mineirin
#define can be used the make things more understandable.
#define relayON LOW
#define relayOFF HIGH
digitalWrite(relay1, relayOFF);
digitalWrite(relay1, relayON);
Thanks for answers, I dont mind using low command instead of high, the thing i wonder is if it suddenly start working normal so my project will be a mess, but if its sourced by relays then it will be okay i guess
It can't change the way that it works without rewiring the relay module.
@peregrin3, your topic has been moved to a more suitable location on the forum.
