Hello people! I want to make an animation with a 7 segment display.
I've a problem when I want to turn on a display, digitalWrite() method doesn't work.
Here's my circuit design:
And here's my code:
// variables
byte pins[] = { 1, 2, 3, 4, 5, 6, 7 };
const byte Segments[] =
0b11000000, // 0
0b11001111, // 1
0b10100100, // 2
0b10000110, // 3
0b10001011, // 4
0b10010010, // 5
0b10010000, // 6
0b11000111, // 7
0b10000000, // 8
0b10000011, // 9
for(int i = 0; i < sizeof(pins); i++)
pinMode(pins[i], OUTPUT);
for(int i = 0; i < sizeof(Segments); i++)
SetDisplay(Segments[i]);
void SetDisplay(byte shownNumber){
byte segments = Segments[shownNumber];
for (int i = 0; i < sizeof(segments); i++){
digitalWrite(pins[i], segments & (0x40 >> i));
Is the display a common anode display?
Is that writing a LOW to the segments that you want lit?
A Serial print there might shed some light ( pun intended).
You will need a Serial.begin(baud) in setup to use the serial port.
Don't use pin 1 for a segment. It is the serial TX pin.
Real, or simulated hardware?
I forget that we have to ask that, nowadays.
red_car
November 20, 2021, 12:14am
5
Isn't the size always going to be 1 byte?
And your picture show you are using pin 1 of the UNO, this is the Tx pin of the UNO that is used with pin 0 to program your code.
I would suggest you use these pins and reconfigure your circuit.
byte pins[] = { 2, 3, 4, 5, 6, 7, 8 };
Tom...
Yes, it is a common anode display.
Then, I want to write a HIGH statement.
Lastly, I'll change pin 1 for another.
Thanks @groundFungus !
MarkT
November 20, 2021, 5:28pm
9
You got the wrong size:
sizeof() returns strictly the compile-time size in bytes of a variable or type.
BTW thanks for posting code and circuit up-front, makes this an easy solution (I hope)!
If it is a common anode display, you must write a LOW to light a segment.
`sizeof (segments)' is 1 so this only goes through one of the seven bits. Try:
for (int i = 0; i < 7; i++){
red_car
November 21, 2021, 12:51am
14
Have you READ posts #5 , #9 , #13 ... ?
There is no delay anywhere, it is going to look like all segments are on but dimmed when you get it working
You're right. Thanks for your code, I copied it for another post. I didn't know some binary operators, interesting.
Yes, you're right. The size is always going to be 1.
I've just add it and it works better.
system
Closed
May 20, 2022, 3:38pm
20
