digitalWrite to rp2040 RGB LEDs?
Is it possible to call digitalWrite() to write to one of the LEDs connected to the NINA, from inside an interrupt callback?
The reason I ask is because when I tried that, it bricked my nano rp2040.
Also, why can't I do something like digitalWrite(LEDB, 1); ? Why should that give me a compile error?
what the error?
/Users/neil/devel/rp2040_clock/interrupt_test/interrupt_test.ino: In function 'void setup()':
interrupt_test:67:23: error: call to 'NinaPin::operator int' declared with attribute error: Change me to a #define
try to add macro in the first lines of sketch (before setup())
#define led LEDB
and use it instead of LEDB in the digitalWrite
digitalWrite(led,1);
That still gives the same error.
Have you #included the WiFiNINA library ?
See Nano RP2040 Connect RGB LED Tutorial - Learn Embedded Systems
Yes. It works if I do digitalWrite(LEDB, HIGH); but not if I put 1 instead of 'HIGH'. That's my question. Why can't I just put a number there?
Perhaps your question could have been a little more specific
How is HIGH defined for the RP2040 ?
If I print it out using Serial.println(), it prints 1. But I don't know where to look to find the macro that defines it.
Here's a simplified sketch that shows the problem:
#include <WiFiNINA.h>
  pinMode(LEDB, OUTPUT);
  digitalWrite(LEDB, HIGH); // This compiles okay.
  digitalWrite(LEDB, 1);    // This throws a compile error.
Printing it is good enough and a value of 1 is no surprise
Please post the full error message
I already posted it in #3 above. Here it is again:
Sorry, I missed it
There was talk a while ago about making the second parameter to digitalWrite() a #define with enum values which would have prevented the use of
digitalWrite(ledPin, !digitalRead(ledPin));
which would have prevented that code being used to flip the state of an output pin
See Return pinMode, digitalWrite, digitalRead to working with numbers, not enums · Issue #168 · SpenceKonde/megaTinyCore · GitHub
I wonder if something like this has crept into the RP2040 implementation
You have to cast as follows
digitalWrite(LEDB, (PinStatus) 1);    // This throws a compile error without (PinStatus) cast
The reason is digitalWrite function for NinaPins, such as LEDx is defined as
void digitalWrite(NinaPin pin, PinStatus value)
PinStatus is defined as
Okay, I decided to go with this, which seems to work:
#define control_led(p, v) (v == 0 ? (digitalWrite(p, LOW)) : (digitalWrite(p, HIGH)))
Now to find out why I can't write to those pins inside an interrupt callback.
@khoih-prog thanks for the details
So, as I speculated, the same idiotic implementation as was nearly done for the main Arduino boards
the RGB LED is on the Nina module. the digitalWrite for RGB pins is overloaded to call WiFiNINA functions which communicate with the NINA module over SPI. this of course will not work in interrupt.
but it can't brick you board.
When I say bricked... what I meant was that it would no longer accept uploads from the computer. I could see that something was running, because the orange LED was blinking, though it wasn't blinking in the normal way. I was able to recover it by grounding the REC pin and pressing reset.
