digitalWrite works on a test sketch but not my working sketch
Hello
I have adapted a few sketches in the past but this is my first "complicated" one. I am having problems with the digital write on my working sketch but it works OK on a test sketch.
I have an Uno with a network shield fitted ( that is another problem I will probably come back to you about ) and a LCD screen.
I also have three external sensors going through voltage dividers supplying a voltage between 0 and 4.6V.
This is my simple test sketch that works - turns the output on and off ( no external signal etc. ):
const int solenoid = 19;
void setup()   {
  pinMode(solenoid, OUTPUT);
  digitalWrite(solenoid, LOW);
   digitalWrite(solenoid, HIGH);
   Serial.println("Solenoid on");
   Serial.print("Solenoid read state = ");
   Serial.println(bitRead(PORTD,solenoid));
   delay(5000);
   Serial.println("Solenoid off");
   delay(5000);
   Serial.println("_________________________________");
This is my working code - some of the code is quite neat as a guy at work helped me clean it up:
Currently the signal to the relay is off all the time and the Serial.println(bitRead(PORTD,solenoid)); confirms that. I assume the signal to set the pin to high is being recived as solenoidState is being set to 1 in the loop.
Any help with this would be gratefully recived as I haave spent a few days trying to get it to work :confused:
#include "ST7565.h"
// Solenoid activation settings
float pressureLowPoint=1.5;
float pressureHighPoint=5;
// number of analog samples to take per reading
#define NUM_SAMPLES 10
const static int sensorPins[] = {A2, A3, A4};
const static char * sensorNames[] = {"Pressure", "H20", "O2"};
const static char * sensorUnits[] = {"mb", "ppm", "ppm"};
const static float sensorOffsets[] = {-28,0,0};
const static float sensorMultipliers[] = {10.7,111.36,222.72};
const static int upperLimits[] = {10, 10, 10};
const static int nSensors = sizeof(sensorPins)/sizeof(int);
int sums[nSensors];              // sum of samples taken
float voltages[nSensors];        // calculated voltage
float readings[nSensors];        // scaled readings
#define EACH_SENSOR for(int i=0; i<nSensors; i++)
// Screen settings
ST7565 glcd(9, 8, 7, 6, 5);
// PWM PINS FOR THE Backlight
int redPin = 4;
int greenPin = 3;
int bluePin = 2;
//uncomment this line if using a Common Anode LED
#define COMMON_ANODE
// Solenoid relay on analogue A5
int solenoidState = 0;
void setup()   {
  // Backlight colour pins
  pinMode(redPin, OUTPUT);
  pinMode(greenPin, OUTPUT);
  pinMode(bluePin, OUTPUT);
  // initialize and set the contrast
  glcd.begin(0x20);
  const char * teststr = sensorNames[0];
 // Calculate the sensor name length
int strlen(char * str, int maxlen = 256){
  int n=0;
  while(str[n] != '\0') n++;
  return n;
    // Take a number of analog samples and add them up
    EACH_SENSOR sums[i] = 0;
    for (int n_samples=0; n_samples < NUM_SAMPLES; n_samples++) {
       EACH_SENSOR sums[i] += analogRead(sensorPins[i]);
       delay(200);
    // calculate the voltage
    // use 5.0 for a 5.0V ADC reference voltage
    // 5.015V is the calibrated reference voltage
    EACH_SENSOR voltages[i] = ((float)sums[i] / (float)NUM_SAMPLES * 4.97) / 1024.0;
    // send voltage for display on Serial Monitor
    // voltage multiplied by 11 when using voltage divider that
    // divides by 11. 11.132 is the calibrated voltage divide
    // value
    // Calculate the volt to pressure value
    EACH_SENSOR readings[i]=(voltages[i] * sensorMultipliers[i] ) + sensorOffsets[i];
    EACH_SENSOR{
      // Send the values to the serial display
      Serial.println ();
      Serial.print(sensorNames[i]);
      Serial.print(" :");
      Serial.print(voltages[i] * 1);
      Serial.println (" V");
      Serial.print(readings[i]);
      Serial.println (sensorUnits[i]);
      Serial.println ();
      // If under pressure open the solenoid in mb?
      // Serial.print ( "readings = ");
      // Serial.println (readings[0]);
      if (readings[0]<=pressureLowPoint){
        solenoidState = 1;
      else if(readings[0]>pressureHighPoint){
        solenoidState = 0;
    Serial.println(solenoidState);
  // Display the pin state from the regester
  Serial.println(bitRead(PORTD,solenoid)); //Reads bit 3 of register PORTD which contains the current state (high/low) of pin 3.
  boolean alarm = false;
  glcd.clear();
  EACH_SENSOR{
    // Convert value of pressure to a character to write to the screen WILL HAVE LEADING ZEROS to allow for -20mb
    // Was b[4] but changed to b[4] to allow for 1000ppm - UNTESTED
    char b[5];   //declaring character array moust be 1 character longer than the actual number to allow for the NULL character
    String str;  //declaring string
    str=String((int) round(readings[i]) ); //converting integer into a string
    //str=String(counter++); //converting integer into a string
    str.toCharArray(b,5); //passing the value of the string to the character array
    // Draw string on the screen
    int row = 3*i;
    glcd.drawstring(0, row, (char *) sensorNames[i]);
    glcd.drawstring(strlen(sensorNames[i])*6, row, ": ");
    glcd.drawstring(65, row, b);
    glcd.drawstring(90, row, (char *) sensorUnits[i]);
    // Change the backlight display to red on an alarm - could have two colours one for a bit over and one for a lot over?
    if(readings[i] > upperLimits[i]) alarm=true;
  if (alarm){
    setColor(255, 0, 0);
  else {
    setColor(255, 255, 255);
  glcd.display();
// Function to set the backlight colour
void setColor(int red, int green, int blue)
#ifdef COMMON_ANODE
red = 255 - red;
green = 255 - green;
blue = 255 - blue;
#endif
analogWrite(redPin, red);
analogWrite(greenPin, green);
analogWrite(bluePin, blue);
void setup()   {
  glcd.begin(0x20);
This is your setup() function. The teststr pointer is useless, since it immediately goes out of scope.
  int n=0;
  return n;
There exists a perfectly good, professionally written strlen() function that does not do stupid shit like set the mode of a pin or set the value of a pin. Why does yours? Why does it do it AFTER the unconditional return?
I have been struggling with this for over a month and to progress things I dropped the network part to concentrate on getting the relay to work.
Some of the code was cleaned up by a co worker and from memory strlen() did not work as from memory he said it was failing on compile?
I have just read you post again and I see what you mean - I have moved the
to the wrong place in the code.
I have moved the...to the wrong place in the code.
Why would you do that? You should move it to the right place in the code.
You need a smarter coworker.
Thank you Paul; it seems to work OK now.
Good point but I have been working on it for over a month now; getting nowhere using the arduino text editor which is not very user friendly and had basically lost the will to live!
Do you still have a problem that you need help with? Blaming your problems on the IDE is not helpful.
I have another couple of problems still as I want a larger font on the LCD screen and I want to get the network card to talk to Python; but they can wait for another day.
This problem seems to be fixed and I will connect everything up again later and test it out properly.
Thanks again
