Hi Guys I'm trying to replace my Diode with a new board. I'm using my spare board that I got from my 3018 cnc pro.
I'm trying to disable the z limit switch but I got stuck on the upload and keep getting this error message. do I have to change the board "Arduino Uno" ? I also don't know the exact model of the board.
just a beginner here and just watching YouTube
tutorial.
FQBN: arduino:avr:uno
Using board 'uno' from platform in folder: C:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\sketch\grblUpload.ino.cpp -o nul
Alternatives for grbl.h: [grbl]
ResolveLibrary(grbl.h)
-> candidates: [grbl]
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -IC:\Users\user\Documents\Arduino\libraries\grbl C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\sketch\grblUpload.ino.cpp -o nul
Using cached library dependencies for file: C:\Users\user\Documents\Arduino\libraries\grbl\coolant_control.c
Using cached library dependencies for file: C:\Users\user\Documents\Arduino\libraries\grbl\eeprom.c
Using cached library dependencies for file: C:\Users\user\Documents\Arduino\libraries\grbl\gcode.c
Using cached library dependencies for file: C:\Users\user\Documents\Arduino\libraries\grbl\jog.c
Using cached library dependencies for file: C:\Users\user\Documents\Arduino\libraries\grbl\limits.c
Using cached library dependencies for file: C:\Users\user\Documents\Arduino\libraries\grbl\main.c
Using cached library dependencies for file: C:\Users\user\Documents\Arduino\libraries\grbl\motion_control.c
Using cached library dependencies for file: C:\Users\user\Documents\Arduino\libraries\grbl\nuts_bolts.c
Using cached library dependencies for file: C:\Users\user\Documents\Arduino\libraries\grbl\planner.c
Using cached library dependencies for file: C:\Users\user\Documents\Arduino\libraries\grbl\print.c
Using cached library dependencies for file: C:\Users\user\Documents\Arduino\libraries\grbl\probe.c
Using cached library dependencies for file: C:\Users\user\Documents\Arduino\libraries\grbl\protocol.c
Using cached library dependencies for file: C:\Users\user\Documents\Arduino\libraries\grbl\report.c
Using cached library dependencies for file: C:\Users\user\Documents\Arduino\libraries\grbl\serial.c
Using cached library dependencies for file: C:\Users\user\Documents\Arduino\libraries\grbl\settings.c
Using cached library dependencies for file: C:\Users\user\Documents\Arduino\libraries\grbl\spindle_control.c
Using cached library dependencies for file: C:\Users\user\Documents\Arduino\libraries\grbl\stepper.c
Using cached library dependencies for file: C:\Users\user\Documents\Arduino\libraries\grbl\system.c
Generating function prototypes...
C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -IC:\Users\user\Documents\Arduino\libraries\grbl C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\sketch\grblUpload.ino.cpp -o C:\Users\user\AppData\Local\Temp\2047231439\sketch_merged.cpp
C:\Users\user\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\user\AppData\Local\Temp\2047231439\sketch_merged.cpp
Compiling sketch...
"C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino" "-IC:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard" "-IC:\Users\user\Documents\Arduino\libraries\grbl" "C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\sketch\grblUpload.ino.cpp" -o "C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\sketch\grblUpload.ino.cpp.o"
Compiling libraries...
Compiling library "grbl"
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\eeprom.c.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\limits.c.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\gcode.c.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\jog.c.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\main.c.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\motion_control.c.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\coolant_control.c.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\nuts_bolts.c.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\probe.c.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\print.c.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\protocol.c.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\planner.c.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\report.c.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\serial.c.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\settings.c.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\spindle_control.c.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\stepper.c.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\system.c.o
Compiling core...
Using precompiled core: C:\Users\user\AppData\Local\Temp\arduino\cores\arduino_avr_uno_dd72fbfee32d61057c6f123c402e8c36\core.a
Linking everything together...
"C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076/grblUpload.ino.elf" "C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\sketch\grblUpload.ino.cpp.o" "C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\coolant_control.c.o" "C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\eeprom.c.o" "C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\gcode.c.o" "C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\jog.c.o" "C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\limits.c.o" "C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\main.c.o" "C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\motion_control.c.o" "C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\nuts_bolts.c.o" "C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\planner.c.o" "C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\print.c.o" "C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\probe.c.o" "C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\protocol.c.o" "C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\report.c.o" "C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\serial.c.o" "C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\settings.c.o" "C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\spindle_control.c.o" "C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\stepper.c.o" "C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076\libraries\grbl\system.c.o" "C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076/..\..\cores\arduino_avr_uno_dd72fbfee32d61057c6f123c402e8c36\core.a" "-LC:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076" -lm
"C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076/grblUpload.ino.elf" "C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076/grblUpload.ino.eep"
"C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076/grblUpload.ino.elf" "C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076/grblUpload.ino.hex"
Using library grbl in folder: C:\Users\user\Documents\Arduino\libraries\grbl (legacy)
"C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\Users\user\AppData\Local\Temp\arduino\sketches\B3CAD0E741F08092F1BFEC729E5E9076/grblUpload.ino.elf"
Sketch uses 29762 bytes (92%) of program storage space. Maximum is 32256 bytes.
Global variables use 1633 bytes (79%) of dynamic memory, leaving 415 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x0a
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x6c
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x2e
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x31
Failed uploading: uploading error: exit status 1
