Lies man die letzten beiden Zeilen VOR den Befehlen.
Zitat: "Um sie zur Kommunikation mit einem externen seriellen TTL-Gerät zu verwenden, verbinde den TX-Pin mit dem RX-Pin deines Geräts, den RX mit dem TX-Pin deines Geräts und die Masse deines Mega mit der Masse deines Geräts."
Das geht entweder Per Kabel oder bei SoftwareSerial auch per Software.
Wie hier schon vorgeschlagen kannst Du es mit I2C machen....
Code Master (Uno/Nano):
#include <Arduino.h>
#include <Wire.h>
/// global variable(s)
constexpr uint8_t I2C_SLAVE_ADDRESS {0x30};
constexpr size_t NUMBER_OF_BYTES {2};
uint8_t buffer[NUMBER_OF_BYTES] {0, 0};
uint16_t bufferToInt16(uint8_t *charBuf) {
uint16_t val = *charBuf;
val = (val << 8) | *(charBuf + 1);
return val;
/// @brief I2C Master: This is an I2C to Serial Converter.
/// Numbers are received from an I2C slave and displayed
/// on the serial console.
Wire.begin();
int idx = 0;
Wire.requestFrom(I2C_SLAVE_ADDRESS, NUMBER_OF_BYTES); // request NUMBER_OF_BYTES byte
// from slave device I2C_SLAVE_ADDRESS
while (Wire.available()) // slave may send less than requested
if (idx < NUMBER_OF_BYTES) {
buffer[idx++] = Wire.read(); // receive a byte as character
float voltage = bufferToInt16(buffer) / 1000.0;
Serial.println(voltage,3);
Code Slave (Attinyx5)
#include <TinyWireS.h> // https://github.com/rambo/TinyWire/tree/master/TinyWireS
constexpr uint8_t I2C_SLAVE_ADDR {0x30};
constexpr uint16_t VCC = 5151; // Measured in milliVolts!
constexpr float REFxRESOLUTION {1100 * 1023.0};
constexpr float VCCxREF {VCC * 1100.0};
constexpr float INTERIM_RESULT {VCCxREF / REFxRESOLUTION};
void initADC0() {
// Initialise ADC with REFS[2:0] is 0 = VCC as Ref, MUX[3:0] 1100 = Vbg as Input,
ADMUX = _BV(MUX3) | _BV(MUX2);
ADCSRA |= _BV(ADEN); // Enable
delay(5); // Wait until the reference has stabilized
// After activating the ADC, a "dummy readout" is recommended.
// In other words, a value is read and discarded to allow the ADC to "warm up"
while ((ADCSRA & _BV(ADSC))) { ; }
(void)ADCW; // Discard dummy readout..
uint16_t readInternalRef11() {
ADCSRA |= _BV(ADSC); // Start conversion
while ((ADCSRA & _BV(ADSC))) { ; } // measure
return static_cast<uint16_t>( INTERIM_RESULT * ADCW );
void dataRequest() {
uint16_t val = readInternalRef11();
TinyWireS.send((val >> 8)); // HIGH Byte
TinyWireS.send(val); // LOW Byte
initADC0(); // Set ADC to interal reference voltage as input (Vbg)
TinyWireS.begin(I2C_SLAVE_ADDR);
TinyWireS.onRequest(dataRequest);
void loop() {}
Ist jetzt minimal, für die Übertragung eines 16 Bit Wertes.
D:\Migel\OneDrive\Desktops\Migels PC\Desktop\Attiny85_Read\Attiny85_Read.ino: In function 'void dataRequest()':
Attiny85_Read:30:13: error: 'class USI_TWI_S' has no member named 'send'; did you mean 'read'?
read
Attiny85_Read:31:13: error: 'class USI_TWI_S' has no member named 'send'; did you mean 'read'?
read
Bibliothek TinyWireS-master in Version 1.0.0 im Ordner: D:\Migel\OneDrive\Dokumente\Arduino\libraries\TinyWireS-master wird verwendet
exit status 1
Bis zu dem Zeitpunkt wusste ich noch nicht mal das es mehrere unterschiedliche Libs gibt die alle gleich heißen.
Ich bin davon ausgegangen das der Beilspiel Sketch funktional ist, sorry
Im Übrigen scheint dies von diesem Thread auch nicht zu funktionieren. Der Adapter wurde anhand dieses Schaltbildes nachgebaut und das Flaschen damit funktioniert auch, aber NICHT das Auslesen am Ser Mon.
Es wurden die dort gezeigten Sketches verwendet und der Ser Mon wurde richtig eingestellt
Der Sketch funktioniert. Ich habe ihn ausprobiert, bevor ich ihn gepostet habe und extra den Link zur verwendeten Lib als Kommentar mit hineingeschrieben, damit klar ist, welche verwendet wurde…
