Buonasera a tutti, io ho comprato il display BYZESTY ESP32, il Modello è WDY-ESP32Display-ZLBY (ESP32-2432S028). Appena tolto dalla confezione l'ho acceso e funzionava, mostrava i grafici, pulsanti e calendari. Poi ho provato a inserire io un codice ma in seguito è rimasto sempre nero. Ecco il codice che ho caricato sul display:
#include <SPI.h>
#include <TFT_eSPI.h>
#include <XPT2046_Touchscreen.h>
TFT_eSPI tft = TFT_eSPI();
// Touchscreen pins
#define XPT2046_IRQ 36 // T_IRQ
#define XPT2046_MOSI 32 // T_DIN
#define XPT2046_MISO 39 // T_OUT
#define XPT2046_CLK 25 // T_CLK
#define XPT2046_CS 33 // T_CS
SPIClass touchscreenSPI = SPIClass(VSPI);
XPT2046_Touchscreen touchscreen(XPT2046_CS, XPT2046_IRQ);
#define SCREEN_WIDTH 320
#define SCREEN_HEIGHT 240
#define FONT_SIZE 2
// Touchscreen coordinates: (x, y) and pressure (z)
int x, y, z;
// Print Touchscreen info about X, Y and Pressure (Z) on the Serial Monitor
void printTouchToSerial(int touchX, int touchY, int touchZ) {
Serial.print("X = ");
Serial.print(touchX);
Serial.print(" | Y = ");
Serial.print(touchY);
Serial.print(" | Pressure = ");
Serial.print(touchZ);
// Print Touchscreen info about X, Y and Pressure (Z) on the TFT Display
void printTouchToDisplay(int touchX, int touchY, int touchZ) {
// Clear TFT screen
tft.fillScreen(TFT_WHITE);
tft.setTextColor(TFT_BLACK, TFT_WHITE);
int centerX = SCREEN_WIDTH / 2;
int textY = 80;
String tempText = "X = " + String(touchX);
tft.drawCentreString(tempText, centerX, textY, FONT_SIZE);
textY += 20;
tempText = "Y = " + String(touchY);
textY += 20;
tempText = "Pressure = " + String(touchZ);
// Start the SPI for the touchscreen and init the touchscreen
touchscreenSPI.begin(XPT2046_CLK, XPT2046_MISO, XPT2046_MOSI, XPT2046_CS);
touchscreen.begin(touchscreenSPI);
// Set the Touchscreen rotation in landscape mode
// Note: in some displays, the touchscreen might be upside down, so you might need to set the rotation to 3: touchscreen.setRotation(3);
touchscreen.setRotation(1);
// Start the tft display
tft.init();
// Set the TFT display rotation in landscape mode
tft.setRotation(1);
// Clear the screen before writing to it
// Set X and Y coordinates for center of display
int centerY = SCREEN_HEIGHT / 2;
tft.drawCentreString("Hello, world!", centerX, 30, FONT_SIZE);
tft.drawCentreString("Touch screen to test", centerX, centerY, FONT_SIZE);
// Checks if Touchscreen was touched, and prints X, Y and Pressure (Z) info on the TFT display and Serial Monitor
if (touchscreen.tirqTouched() && touchscreen.touched()) {
// Get Touchscreen points
TS_Point p = touchscreen.getPoint();
// Calibrate Touchscreen points with map function to the correct width and height
x = map(p.x, 200, 3700, 1, SCREEN_WIDTH);
y = map(p.y, 240, 3800, 1, SCREEN_HEIGHT);
z = p.z;
printTouchToSerial(x, y, z);
printTouchToDisplay(x, y, z);
delay(100);
Le foto del Display BYZESTY ESP32:
