#include <LCDWIKI_GUI.h> //Core graphics library
#include <LCDWIKI_KBV.h> //Hardware-specific library
//the definiens of 8bit mode as follow:
//if the IC model is known or the modules is unreadable,you can use this constructed function
//LCDWIKI_KBV mylcd(ILI9341,A3,A2,A1,A0,A4); //model,cs,cd,wr,rd,reset
//LCDWIKI_KBV mylcd(ILI9325,A3,A2,A1,A0,A4); //model,cs,cd,wr,rd,reset
//LCDWIKI_KBV mylcd(ILI9328,A3,A2,A1,A0,A4); //model,cs,cd,wr,rd,reset
//LCDWIKI_KBV mylcd(HX8357D,A3,A2,A1,A0,A4); //model,cs,cd,wr,rd,reset
//LCDWIKI_KBV mylcd(HX8347G,A3,A2,A1,A0,A4); //model,cs,cd,wr,rd,reset
//LCDWIKI_KBV mylcd(HX8347I,A3,A2,A1,A0,A4); //model,cs,cd,wr,rd,reset
LCDWIKI_KBV mylcd(ILI9486,A3,A2,A1,A0,A4); //model,cs,cd,wr,rd,reset
//LCDWIKI_KBV mylcd(ST7735S,A3,A2,A1,A0,A4); //model,cs,cd,wr,rd,reset
//if the IC model is not known and the modules is readable,you can use this constructed function
//LCDWIKI_KBV mylcd(240,320,A3,A2,A1,A0,A4);//width,height,cs,cd,wr,rd,reset
//LCDWIKI_KBV mylcd(320,480,A3,A2,A1,A0,A4);//width,height,cs,cd,wr,rd,reset
//the definiens of 16bit mode as follow:
//LCDWIKI_KBV mylcd(ILI9341,40,38,39,44,41); //model,cs,cd,wr,rd,reset
//LCDWIKI_KBV mylcd(ILI9325,40,38,39,44,41); //model,cs,cd,wr,rd,reset
//LCDWIKI_KBV mylcd(ILI9328,40,38,39,44,41); //model,cs,cd,wr,rd,reset
//LCDWIKI_KBV mylcd(HX8357D,40,38,39,44,41); //model,cs,cd,wr,rd,reset
//LCDWIKI_KBV mylcd(HX8347G,40,38,39,44,41); //model,cs,cd,wr,rd,reset
//LCDWIKI_KBV mylcd(HX8347I,40,38,39,44,41); //model,cs,cd,wr,rd,reset
//LCDWIKI_KBV mylcd(ILI9486,40,38,39,44,41); //model,cs,cd,wr,rd,reset
//LCDWIKI_KBV mylcd(ILI9488,40,38,39,44,41); //model,cs,cd,wr,rd,reset
//LCDWIKI_KBV mylcd(ILI9481,40,38,39,44,41); //model,cs,cd,wr,rd,reset
//LCDWIKI_KBV mylcd(ST7735S,40,38,39,44,41); //model,cs,cd,wr,rd,reset
//LCDWIKI_KBV mylcd(240,320,40,38,39,44,41);//width,height,cs,cd,wr,rd,reset for
//LCDWIKI_KBV mylcd(320,480,40,38,39,44,41);//width,height,cs,cd,wr,rd,reset
//define some colour values
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
mylcd.Init_LCD();
mylcd.Fill_Screen(BLACK);
mylcd.Set_Text_Mode(0);
//display 1 times string
mylcd.Fill_Screen(0x0000);
mylcd.Set_Text_colour(RED);
mylcd.Set_Text_Back_colour(BLACK);
mylcd.Set_Text_Size(1);
mylcd.Print_String("Hello World!", 0, 0);
mylcd.Print_Number_Float(01234.56789, 2, 0, 8, '.', 0, ' ');
mylcd.Print_Number_Int(0xDEADBEF, 0, 16, 0, ' ',16);
//mylcd.Print_String("DEADBEF", 0, 16);
//display 2 times string
mylcd.Set_Text_colour(GREEN);
mylcd.Set_Text_Size(2);
mylcd.Print_String("Hello World!", 0, 40);
mylcd.Print_Number_Float(01234.56789, 2, 0, 56, '.', 0, ' ');
mylcd.Print_Number_Int(0xDEADBEF, 0, 72, 0, ' ',16);
//mylcd.Print_String("DEADBEEF", 0, 72);
//display 3 times string
mylcd.Set_Text_colour(BLUE);
mylcd.Set_Text_Size(3);
mylcd.Print_String("Hello World!", 0, 104);
mylcd.Print_Number_Float(01234.56789, 2, 0, 128, '.', 0, ' ');
mylcd.Print_Number_Int(0xDEADBEF, 0, 152, 0, ' ',16);
// mylcd.Print_String("DEADBEEF", 0, 152);
//display 4 times string
mylcd.Set_Text_colour(WHITE);
mylcd.Set_Text_Size(4);
mylcd.Print_String("Hello!", 0, 192);
//display 5 times string
mylcd.Set_Text_colour(YELLOW);
mylcd.Set_Text_Size(5);
mylcd.Print_String("Hello!", 0, 224);
//display 6 times string
mylcd.Set_Text_Size(6);
mylcd.Print_String("Hello!", 0, 266);
delay(3000);
The code, which my Arduino runs, is above. I have executed the steps above too. Serial monitor don't show anything.
I am installing the MCUFRIEND_kbv library and I' ll update the thead
