I found a display from Nokia C1-01. Can I "modify it" to use it with Arduino Uno?
Thanks for help!
It could be a ST7735 in a vertical position, since the C1-01's screen has a 120x160 pixel array.
You have to identify the pinout, if you come across a flexible cable with metal terminals it is possible to carry out some wiring with small wires, but if the end is a flexible PCB, the wiring will not be so easy.
I better suggest a TFT like these:
If you still want to explore your cell:
Nokia LCD
TFTLCDCyg:
It could be a ST7735 in a vertical position, since the C1-01's screen has a 120x160 pixel array.You have to identify the pinout, if you come across a flexible cable with metal terminals it is possible to carry out some wiring with small wires, but if the end is a flexible PCB, the wiring will not be so easy.
Nokia LCD
I just recently found the phone and I don't know what to keep from it. Maybe I can use the display with Uno I sayed
Thanks for your help about what display is it.
