Hi Everyone,
I have a very old tablet, that i no longer use, so i'm wondering if some parts from it can be reused with some arduino+raspberry projects.
Since it is a LCD unit + TouchScreen so it could have many uses.
Now what i'm not sure is what i need, i suppose that probably it need a specific controller in order to become usable with other devices (i suppose that if i'm going to use a raspberry it should probably be able to recognize it since android is still based on linux, so hopefully the kernel supports it).
And also there is another problem: i'm not able to identify the Display model, i looked everywhere on it's surface and can't find any identification code, the only code that i found was related to the touchscreen device DPT-N3788E-G/I but nothing that looks related to the display (i'm not sure if the display has just a metal wrapping around and some identification code is inside).
Is possible to identify somehow the display? The tablet is a maxell maxtab c8, of course i googled a lot about the display unit, but i didn't get any information, tried to looks also at kernel dmesg command, but wasn't able to spot any display model reference (it could be possible that i missed it, given the amount of log produced).
Do you think i will i be able to reuse it for other purposes (is a very nice display, and it will be a pity to have to throw it away)
