Display lcd oled i2c + tm1637 now work
I tried combining an Oled LCD and a TM1637. The code cannot display the display on the LCD. Where did it go wrong?
#include <ESP8266WiFi.h>
#include <ESPAsyncWebServer.h>
#include <Wire.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_GFX.h>
#include <TM1637Display.h>
#include <TimeLib.h>
#include <FS.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
// Define the connections pins
#define CLK D6
#define DIO D5
// Create a display object of type TM1637Display
TM1637Display displayled = TM1637Display(CLK, DIO);
// Create an array that turns all segments ON
const uint8_t allON[] = {0xff, 0xff, 0xff, 0xff};
// Create an array that turns all segments OFF
const uint8_t allOFF[] = {0x00, 0x00, 0x00, 0x00};
unsigned long clockMillis = 0;
unsigned long interval = 1000;
unsigned long sensorMillis1 = 0;
const long sensorInterval1 = 1000;
// Initialize Web Server on port 80
AsyncWebServer server(80);
// Function to handle GET request to /getnow
void handleGetNow(AsyncWebServerRequest *request) {
  if (request->hasParam("hour") && request->hasParam("minute")) {
    int h = request->getParam("hour")->value().toInt();
    int m = request->getParam("minute")->value().toInt();
    setTime(h, m, 0, day(), month(), year());
    // Display time on TM1637
    displayTime(h, m);
  request->send(200, "text/plain", "Time updated");
// Function to display time on TM1637
void displayTime(int hour, int minute) {
  int displayTime = hour * 100 + minute;
  displayled.showNumberDecEx(displayTime, 0b01000000, true, 4, 0);
  // Setup WiFi as Access Point
  WiFi.softAP("ESP8266_Time_Setter");
  // Initialize SPIFFS
  if (!SPIFFS.begin()) {
    Serial.println("An Error has occurred while mounting SPIFFS");
    return;
  if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3C for 128x32
    Serial.println(F("SSD1306 allocation failed"));
    for(;;); // Don't proceed, loop forever
  // Set the brightness to 7 (0=dimmest 7=brightest)
  displayled.setBrightness(7);
  // Set all segments ON
  displayled.setSegments(allON);
  displayled.clear();
  display.fillRect(0, 0, SCREEN_WIDTH, SCREEN_HEIGHT, BLACK);
  display.display();
  // Initialize time to 00:00:00
  setTime(0, 0, 0, 1, 1, 1970);
  // Serve static files
  server.serveStatic("/", SPIFFS, "/").setDefaultFile("index.html");
  server.on("/getnow", HTTP_GET, handleGetNow);
  server.begin();
  Serial.println("HTTP server started");
const unsigned char epd_bitmap_temperature [] PROGMEM = {
    0xff, 0xf8, 0xf8, 0xf8, 0xf2, 0x78, 0xf7, 0x78, 0xf5, 0x78, 0xf5, 0x78, 0xf5, 0x78, 0xe8, 0xb8,
    0xe8, 0xb8, 0xe8, 0xb8, 0xf7, 0x78, 0xfd, 0xf8, 0xff, 0xf8
const unsigned char epd_bitmap_barometer [] PROGMEM = {
    0xff, 0xf8, 0xf0, 0x78, 0xe0, 0x38, 0xe7, 0x38, 0xc2, 0x18, 0xc2, 0x18, 0xe0, 0x38, 0xe0, 0x38,
    0xf8, 0xf8, 0xf8, 0xf8, 0x80, 0x08, 0x80, 0x08, 0xff, 0xf8
const unsigned char epd_bitmap_height [] PROGMEM = {
    0xff, 0xf8, 0xfd, 0xf8, 0xf8, 0xf8, 0xfd, 0xf8, 0xfd, 0xf8, 0xfd, 0xf8, 0xfd, 0xf8, 0xfd, 0xf8,
    0xfd, 0xf8, 0xfd, 0xf8, 0xf8, 0xf8, 0xfd, 0xf8, 0xff, 0xf8
  if (millis() - clockMillis >= interval) {
    clockMillis = millis();
    if (timeStatus() == timeNotSet) {
      // Manually increment time by one second if time has not been set
      adjustTime(1);
    int h = hour();
    int m = minute();
    displayTime(h, m);
  display.setTextSize(1);
  display.setTextColor(WHITE);
  String displayHeader = "PORTABLE WEATHER";
  int16_t x1, y1;
  uint16_t w, h;
  display.getTextBounds(displayHeader, 0, 0, &x1, &y1, &w, &h);
  display.setCursor((SCREEN_WIDTH - w) / 2, 0); // Center the text
  display.println(displayHeader);
  display.display();
  if(millis() - sensorMillis1 >= sensorInterval1) {
    sensorMillis1 = millis();
    // Hapus hanya area sensor dari layar
    display.fillRect(0, 16, SCREEN_WIDTH, SCREEN_HEIGHT - 16, BLACK);
    display.drawBitmap(0, 16, epd_bitmap_temperature, 13, 13, 1);
    display.setCursor(20, 18);
    display.print("50");
    display.println(" *C");
    display.drawBitmap(0, 32, epd_bitmap_barometer, 13, 13, 1);
    display.setCursor(20, 34);
    display.println(" hPa");
    display.drawBitmap(0, 48, epd_bitmap_height, 13, 13, 1);
    display.setCursor(20, 50);
    display.println(" m");
    display.display(); // Show data
Please, post the pictures of your OLED Display and TM1637 Display. Also, mention the Arduino (UNO or NANO or else) you are using.
WEMOS D1 MINI
  1. The Oled LCD won't work when I connect the TM1637
  2. OLed LCD works successfully then I press get now on the and Oled LCD website nothing appears even though the clock on the TM1637 changes
<!DOCTYPE html>
<html>
<head>
  <title>ESP8266 Time Setter</title>
  <script>
    function getCurrentTime() {
      const now = new Date();
      const hour = now.getHours();
      const minute = now.getMinutes();
      const xhttp = new XMLHttpRequest();
      xhttp.open('GET', `/getnow?hour=${hour}&minute=${minute}`, true);
      xhttp.send();
  </script>
</head>
<body>
  <h1>Get Current Time</h1>
  <button onclick="getCurrentTime()">Get Now</button>
</body>
</html>
Thanks for the reply. I don't have WEMOS D1 MINI; so, I can't help in trouble shooting/debugging.
don't you have an esp32 too or another esp8266?
