How do I modify this program to also display the data received in the packet on the OLED display? I can't seem to find the correct library for both LoRa communications and OLED display.
#include "LoRaWan_APP.h"
#include "Arduino.h"
#define RF_FREQUENCY 915000000 // Hz
#define TX_OUTPUT_POWER 14 // dBm
#define LORA_BANDWIDTH 0 // [0: 125 kHz, 1: 250 kHz, 2: 500 kHz]
#define LORA_SPREADING_FACTOR 7 // [SF7..SF12]
#define LORA_CODINGRATE 1 // [1: 4/5, 2: 4/6, 3: 4/7, 4: 4/8]
#define LORA_PREAMBLE_LENGTH 8 // Same for Tx and Rx
#define LORA_SYMBOL_TIMEOUT 0 // Symbols
#define LORA_FIX_LENGTH_PAYLOAD_ON false
#define LORA_IQ_INVERSION_ON false
#define RX_TIMEOUT_VALUE 1000
#define BUFFER_SIZE 30 // Define the payload size here
// Message structure with header
struct __attribute__((packed)) RadioMessage {
uint32_t header; // 4 byte header
uint8_t state; // 1 byte
uint16_t batteryVoltage; // 2 bytes
uint8_t version; // 1 byte
uint8_t checksum; // 1 byte
}; // Total: 9 bytes
static RadioEvents_t RadioEvents;
RadioMessage receivedMsg;
int16_t rssi, rxSize;
bool lora_idle = true;
uint8_t rxpacket[BUFFER_SIZE];
void OnRxDone(uint8_t *payload, uint16_t size, int16_t rssiValue, int8_t snr) {
rssi = rssiValue;
rxSize = size;
Serial.printf("\nReceived packet size: %d bytes\n", size);
Serial.printf("RadioMessage structure size: %d bytes\n", sizeof(RadioMessage));
// Print raw bytes for debugging
Serial.println("Raw received bytes (hex):");
for(int i = 0; i < size; i++) {
Serial.printf("0x%02X ", payload[i]);
if(size == sizeof(RadioMessage)) {
memcpy(&receivedMsg, payload, sizeof(RadioMessage));
Serial.println("\n----------------------------------------");
Serial.println("Received LoRa Message:");
Serial.printf("Header: 0x%08lX\n", receivedMsg.header); // Print header as hex
Serial.printf("State: %d\n", receivedMsg.state);
Serial.printf("Battery Voltage: %d mV\n", receivedMsg.batteryVoltage);
Serial.printf("Version: %d\n", receivedMsg.version);
Serial.printf("Checksum: 0x%02X\n", receivedMsg.checksum);
Serial.printf("RSSI: %d dBm\n", rssi);
Serial.printf("SNR: %d dB\n", snr);
Serial.println("----------------------------------------\n");
// Optional: Print header bytes individually
uint8_t* headerBytes = (uint8_t*)&receivedMsg.header;
Serial.println("Header bytes individually:");
for(int i = 0; i < 4; i++) {
Serial.printf("Header byte %d: 0x%02X\n", i, headerBytes[i]);
Serial.printf("Error: Received %d bytes, expected %d bytes\n",
size, sizeof(RadioMessage));
Radio.Sleep();
lora_idle = true;
Mcu.begin(HELTEC_BOARD, SLOW_CLK_TPYE);
rssi = 0;
RadioEvents.RxDone = OnRxDone;
Radio.Init(&RadioEvents);
Radio.SetChannel(RF_FREQUENCY);
Radio.SetRxConfig(MODEM_LORA, LORA_BANDWIDTH, LORA_SPREADING_FACTOR,
LORA_CODINGRATE, 0, LORA_PREAMBLE_LENGTH,
LORA_SYMBOL_TIMEOUT, LORA_FIX_LENGTH_PAYLOAD_ON,
0, true, 0, 0, LORA_IQ_INVERSION_ON, true);
Serial.println("LoRa Receiver initialized");
if(lora_idle) {
lora_idle = false;
Serial.println("into RX mode");
Radio.Rx(0);
Radio.IrqProcess();
