Displaying files on a TFT 3.5 inch screen using the SD card
I am using a TFT 3.5 inch screen with an Arduino Mega. I have utilised the Mcufriend_kbv library in order to test the display!
The images are displaying just fine but they are presented in a slide show format. Is there any way to display the images by individual filename? I cannot find any specific example attached in the library to display a single image.
Your post was MOVED to its current location as it is more suitable.
Could you take a few moments to Learn How To Use The Forum
  • Your OS and version can be valuable information, please include it along with extra security you are using.
  • Always list the version of the IDE you are using and the board version if applicable.
  • Use quote or add error messages as an attachment NOT a picture.
  • How to insert an image into your post. ( Thanks @sterretje )
  • Add your sketch where applicable but please use CODE TAGS ( </> )
  • Add a SCHEMATIC were needed even if it is hand drawn
  • Add working links to any specific hardware as needed (NOT links to similar items)
  • Remember that the people trying to help cannot see your problem so give as much information as you can
COMMON ISSUES
  • Ensure you have FULLY inserted the USB cables.
  • Check you have a COMMON GROUND where required. ( Thanks @Perry)
  • Where possible use USB 2.0 ports or a USB 2.0 POWERED HUB to rule out USB 3.0 issues.
  • Try other computers where possible.
  • Try other USB leads where possible.
  • You may not have the correct driver installed. CH340/341 or CP2102 or FT232 VCP Drivers - FTDI
  • There may be a problem with the board check or remove your wiring first.
  • Remove any items connected to pins 0 and 1.
COMPUTER RELATED
  • Close any other serial programs before opening the IDE.
  • Ensure you turn off any additional security / antivirus just to test.
  • There may be a problem with the PC try RESTARTING it.
  • You may be selecting the wrong COM port.
  • Avoid cloud/network based installations where possible OR ensure your Network/Cloud software is RUNNING.
  • Clear your browsers CACHE.
  • Close the IDE before using any other serial programs.
  • Preferably install IDE’s as ADMINISTRATOR or your OS equivalent
ARDUINO SPECIFIC BOARDS
  • CH340/341 based clones do not report useful information to the “get board info” button.
  • NANO (Old Types) some require you to use the OLD BOOTLOADER option.
  • NANO (ALL Types) See the specific sections lower in the forum.
  • NANO (NEW Types) Install your board CORE’s.
  • Unless using EXTERNAL PROGRAMMERS please leave the IDE selection at default “AVRISP mkII”.
  • Boards using a MICRO usb connector need a cable that is both DATA and CHARGE. Many are CHARGE ONLY.
CREATE editor install locations.
  • On macOs ~/Applications/ArduinoCreateAgent-1.1/ArduinoCreateAgent.app/Contents/MacOS/config.ini
  • On Linux ~/ArduinoCreateAgent-1.1/config.ini
  • On Windows C:\Users[your user]\AppData\Roaming\ArduinoCreateAgent-1.1
Performing the above actions may help resolve your problem without further help.
Language problem ?
Try a language closer to your native language:
Thanks to all those who helped and added to this list.
// MCUFRIEND UNO shields have microSD on pins 10, 11, 12, 13
// The official <SD.h> library only works on the hardware SPI pins
// e.g. 11, 12, 13 on a Uno
// e.g. 50, 51, 52 on a Mega2560
// e.g. 74, 75, 76 on a Due
// if you are not using a UNO,  you must use Software SPI:
// install v1.0.1 of the <SdFat.h> library with the Arduino Library Manager.
// edit the src/SdFatConfig.h file to #define ENABLE_SOFTWARE_SPI_CLASS 1
// copy all your BMP files to the root directory on the microSD with your PC
// (or another directory)
#include <SPI.h>             // f.k. for Arduino-1.5.2
#define USE_SDFAT
#include <SdFat.h>           // Use the SdFat library
SdFatSoftSpi<50, 51, 52> SD; //Bit-Bang on the Shield pins
#include <Adafruit_GFX.h>    // Hardware-specific library
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
#define SD_CS     53
#define NAMEMATCH ""         // "" matches any name
//#define NAMEMATCH "tiger"    // *tiger*.bmp
#define PALETTEDEPTH   8     // support 256-colour Palette
char namebuf[32] = "/";   //BMP files in root directory
//char namebuf[32] = "/bitmaps/";  //BMP directory e.g. files in /bitmaps/*.bmp
File root;
int pathlen;
    uint16_t ID;
    Serial.print("Show BMP files on TFT with ID:0x");
    ID = tft.readID();
    Serial.println(ID, HEX);
    if (ID == 0x0D3D3) ID = 0x9481;
    tft.begin(ID);
    tft.fillScreen(0x001F);
    tft.setTextColor(0xFFFF, 0x0000);
    bool good = SD.begin(SD_CS);
    if (!good) {
        Serial.print(F("cannot start SD"));
        while (1);
    root = SD.open(namebuf);
    pathlen = strlen(namebuf);
    char *nm = namebuf + pathlen;
    File f = root.openNextFile();
    uint8_t ret;
    uint32_t start;
    if (f != NULL) {
#ifdef USE_SDFAT
        f.getName(nm, 32 - pathlen);
#else
        strcpy(nm, (char *)f.name());
#endif
        f.close();
        strlwr(nm);
        if (strstr(nm, ".bmp") != NULL && strstr(nm, NAMEMATCH) != NULL) {
            Serial.print(namebuf);
            Serial.print(F(" - "));
            tft.fillScreen(0);
            start = millis();
            ret = showBMP(namebuf, 5, 5);
            switch (ret) {
                case 0:
                    Serial.print(millis() - start);
                    Serial.println(F("ms"));
                    delay(5000);
                case 1:
                    Serial.println(F("bad position"));
                case 2:
                    Serial.println(F("bad BMP ID"));
                case 3:
                    Serial.println(F("wrong number of planes"));
                case 4:
                    Serial.println(F("unsupported BMP format"));
                case 5:
                    Serial.println(F("unsupported palette"));
                default:
                    Serial.println(F("unknown"));
    else root.rewindDirectory();
#define BMPIMAGEOFFSET 54
#define BUFFPIXEL      20
uint16_t read16(File& f) {
    uint16_t result;         // read little-endian
    f.read(&result, sizeof(result));
    return result;
uint32_t read32(File& f) {
    uint32_t result;
    return result;
uint8_t showBMP(char *nm, int x, int y)
    File bmpFile;
    int bmpWidth, bmpHeight;    // W+H in pixels
    uint8_t bmpDepth;           // Bit depth (currently must be 24, 16, 8, 4, 1)
    uint32_t bmpImageoffset;    // Start of image data in file
    uint32_t rowSize;           // Not always = bmpWidth; may have padding
    uint8_t sdbuffer[3 * BUFFPIXEL];    // pixel in buffer (R+G+B per pixel)
    uint16_t lcdbuffer[(1 << PALETTEDEPTH) + BUFFPIXEL], *palette = NULL;
    uint8_t bitmask, bitshift;
    boolean flip = true;        // BMP is stored bottom-to-top
    int w, h, row, col, lcdbufsiz = (1 << PALETTEDEPTH) + BUFFPIXEL, buffidx;
    uint32_t pos;               // seek position
    boolean is565 = false;      //
    uint16_t bmpID;
    uint16_t n;                 // blocks read
    uint8_t ret;
    if ((x >= tft.width()) || (y >= tft.height()))
        return 1;               // off screen
    bmpFile = SD.open(nm);      // Parse BMP header
    bmpID = read16(bmpFile);    // BMP signature
    (void) read32(bmpFile);     // Read & ignore file size
    (void) read32(bmpFile);     // Read & ignore creator bytes
    bmpImageoffset = read32(bmpFile);       // Start of image data
    (void) read32(bmpFile);     // Read & ignore DIB header size
    bmpWidth = read32(bmpFile);
    bmpHeight = read32(bmpFile);
    n = read16(bmpFile);        // # planes -- must be '1'
    bmpDepth = read16(bmpFile); // bits per pixel
    pos = read32(bmpFile);      // format
    if (bmpID != 0x4D42) ret = 2; // bad ID
    else if (n != 1) ret = 3;   // too many planes
    else if (pos != 0 && pos != 3) ret = 4; // format: 0 = uncompressed, 3 = 565
    else if (bmpDepth < 16 && bmpDepth > PALETTEDEPTH) ret = 5; // palette
    else {
        bool first = true;
        is565 = (pos == 3);               // ?already in 16-bit format
        // BMP rows are padded (if needed) to 4-byte boundary
        rowSize = (bmpWidth * bmpDepth / 8 + 3) & ~3;
        if (bmpHeight < 0) {              // If negative, image is in top-down order.
            bmpHeight = -bmpHeight;
            flip = false;
        w = bmpWidth;
        h = bmpHeight;
        if ((x + w) >= tft.width())       // Crop area to be loaded
            w = tft.width() - x;
        if ((y + h) >= tft.height())      //
            h = tft.height() - y;
        if (bmpDepth <= PALETTEDEPTH) {   // these modes have separate palette
            //bmpFile.seek(BMPIMAGEOFFSET); //palette is always @ 54
            bmpFile.seek(bmpImageoffset - (4<<bmpDepth)); //54 for regular, diff for colorsimportant
            bitmask = 0xFF;
            if (bmpDepth < 8)
                bitmask >>= bmpDepth;
            bitshift = 8 - bmpDepth;
            n = 1 << bmpDepth;
            lcdbufsiz -= n;
            palette = lcdbuffer + lcdbufsiz;
            for (col = 0; col < n; col++) {
                pos = read32(bmpFile);    //map palette to 5-6-5
                palette[col] = ((pos & 0x0000F8) >> 3) | ((pos & 0x00FC00) >> 5) | ((pos & 0xF80000) >> 8);
        // Set TFT address window to clipped image bounds
        tft.setAddrWindow(x, y, x + w - 1, y + h - 1);
        for (row = 0; row < h; row++) { // For each scanline...
            // Seek to start of scan line.  It might seem labor-
            // intensive to be doing this on every line, but this
            // method covers a lot of gritty details like cropping
            // and scanline padding.  Also, the seek only takes
            // place if the file position actually needs to change
            // (avoids a lot of cluster math in SD library).
            uint8_t r, g, b, *sdptr;
            int lcdidx, lcdleft;
            if (flip)   // Bitmap is stored bottom-to-top order (normal BMP)
                pos = bmpImageoffset + (bmpHeight - 1 - row) * rowSize;
            else        // Bitmap is stored top-to-bottom
                pos = bmpImageoffset + row * rowSize;
            if (bmpFile.position() != pos) { // Need seek?
                bmpFile.seek(pos);
                buffidx = sizeof(sdbuffer); // Force buffer reload
            for (col = 0; col < w; ) {  //pixels in row
                lcdleft = w - col;
                if (lcdleft > lcdbufsiz) lcdleft = lcdbufsiz;
                for (lcdidx = 0; lcdidx < lcdleft; lcdidx++) { // buffer at a time
                    uint16_t color;
                    // Time to read more pixel data?
                    if (buffidx >= sizeof(sdbuffer)) { // Indeed
                        bmpFile.read(sdbuffer, sizeof(sdbuffer));
                        buffidx = 0; // Set index to beginning
                        r = 0;
                    switch (bmpDepth) {          // Convert pixel from BMP to TFT format
                        case 24:
                            b = sdbuffer[buffidx++];
                            g = sdbuffer[buffidx++];
                            r = sdbuffer[buffidx++];
                            color = tft.color565(r, g, b);
                        case 16:
                            if (is565)
                                color = (r << 8) | (b);
                                color = (r << 9) | ((b & 0xE0) << 1) | (b & 0x1F);
                        case 1:
                        case 4:
                        case 8:
                            if (r == 0)
                                b = sdbuffer[buffidx++], r = 8;
                            color = palette[(b >> bitshift) & bitmask];
                            r -= bmpDepth;
                            b <<= bmpDepth;
                    lcdbuffer[lcdidx] = color;
                tft.pushColors(lcdbuffer, lcdidx, first);
                first = false;
                col += lcdidx;
            }           // end cols
        }               // end rows
        tft.setAddrWindow(0, 0, tft.width() - 1, tft.height() - 1); //restore full screen
        ret = 0;        // good render
    bmpFile.close();
    return (ret);
This is the code that I have been using to display the images from the SD Card. However, I cannot upload individual files. I have been using Arduino Mega2560 to run the TFT screen
The example in #3 refers to
However the current SdFat.h library version has changed. There is a new example with advice for SdFat v2.x.x on GitHub https://github.com/prenticedavid/MCUFRIEND_kbv/tree/master/examples/showBMP_not_Uno
Regarding individual files.
            ret = showBMP("yourfile.bmp", x, y);
David.
Thanks for the the help David. I was having a lot trouble trying while running the individual files. This has solved my problem, thanks again!
I was working with this library and loading the images on the TFT Screen. Is there any way to increase/decrease the rendering speed of the images on the TFT screen? I want to increase the loading time of the images.
I was looking at the entire code, but could not figure out anything. Can anyone please help me out?
// e.g. 11, 12, 13 on a Uno  (or STM32 Nucleo)
#include <SD.h>             // Use the official SD library on hardware pins
MCUFRIEND_kbv tft;
#if defined(ESP32)
#define SD_CS     10
#else
#define SD_CS     10
#endif
//#define NAMEMATCH "tiger"   // tiger.bmp
#define PALETTEDEPTH   0     // do not support Palette modes
//#define PALETTEDEPTH   8     // support 256-colour Palette
File root;
int pathlen;
    tft.setRotation(1);
    uint16_t ID;
    ID = tft.readID();
    tft.begin(ID);
    if (!good) {
        while (1);
    uint8_t ret;
    uint32_t start;
    if (f != NULL) {
#ifdef USE_SDFAT
#else
#endif
        f.close();
        strlwr(nm);
            tft.fillScreen(0);
            start = millis();
            switch (ret) {
                case 0:
                    delay(5000);
                case 1:
                case 2:
                case 3:
                case 4:
                case 5:
                default:
    f.read((uint8_t*)&result, sizeof(result));
    return result;
    uint32_t result;
    return result;
    File bmpFile;
    uint16_t bmpID;
    uint8_t ret;
    else {
        bool first = true;
            flip = false;
        w = bmpWidth;
        h = bmpHeight;
            bitmask = 0xFF;
            if (bmpDepth < 8)
            n = 1 << bmpDepth;
            lcdbufsiz -= n;
                bmpFile.seek(pos);
                lcdleft = w - col;
                    uint16_t color;
                        r = 0;
                        case 24:
                        case 16:
                            if (is565)
                        case 1:
                        case 4:
                        case 8:
                            if (r == 0)
                            r -= bmpDepth;
                            b <<= bmpDepth;
                first = false;
                col += lcdidx;
            }           // end cols
        }               // end rows
    bmpFile.close();
    return (ret);
Just add some delays.
  1. Save the example to a new name in your User Sketch directory.
  2. Strip out any conditional code e.g. #ifdef USE_SDFAT
  3. You are probably only using 24-bit color
  4. Strip out any unused format stuff.
  5. e.g. palette is unused
  6. e.g. bmpDepth is always 24
  7. compile, run.
  8. rinse and repeat. i.e. back to (4)
It is wise to remove "unused" sections of code in small stages.
Personally, I print "difficult" code on paper.
I can sit down with a nice cup of tea (away from the PC). Mark "unused" sections with a pencil.
Pencil, paper and tea-bags are the best tools for understanding code.
David.
Okay thanks! I will look into that and get back to you.
Your help is highly appreciated!
Is there any way to run gif animations on the TFT 3.5 inch screen? I was going through different tutorials but the majority of them were using ESP boards (due to higher internal memory).
Is it possible to run animations on this TFT screen using the Arduino Mega, while the animated images (individual frames) are fetched from the SD Card?
I am having pretty hard time solving these problems on my own. Thanks in advance!
Yes, you can run an Animated GIF on a Mega but it will be pretty slow. Faster from PROGMEM than SD Card but still impractical.
GIF is happier with ARM or ESP. But simple cartoon animations should work on the Mega.
David.
Okay, thanks for the insight. Much appreciated!
Hi there, I am stuck again in another problem. This time I want to run a game and the catch is that I want the image to load only once. I am trying to develop a game with some RFID Tags. The game is that an image of the letter pops on the screen and the player has to show the correct RFID card. If the player shows a wrong card, the game stays on that letter only till the person does not tap the right card.
But, the problem is that I want the showBMP function to show the image once only. However, when the incorrect() function is executed, the image renders all over again. The problem is that the rendering is so slow that it becomes very boring to play again. I will attach the code for the game.
#define USE_SDFAT
#define SD_CS     53
File root;
int pathlen;
uint8_t ret;
uint32_t start;
#include "Arduino.h"
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
#include <Fonts/FreeMono12pt7b.h>
#define BLACK   0x0000
#define BLUE    0x001F
#define RED     0xF800
#define GREEN   0x07E0
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
String id = "initial";
String A = "0B002453423E";
String B = "1E005BEEC962";
String C = "1E005BE8268B";
String D = "1D00ADC7E691";
String E = "1E005C32DEAE";
String F = "1E005C487F75";
String G = "1E005BC9BC30";
String H = "1D00AE8786B2";
String I = "1D00AF453CCB";
String J = "1D00AF6570A7";
String K = "1D00AE96A481";
String L = "1D00AE086FD4";
String M = "1D00AD74A96D";
String N = "1D00AF349016";
String O = "1D00AEA9B3A9";
String P = "1D00AE8FB38F";
String Q = "1D00AD835665";
String R = "1D00AD924664";
String S = "1D00AEC53C4A";
String T = "1D00AE44AC5B";
String U = "1D00AECCC0BF";
String V = "1E005CC4AD2B";
String W = "1E005CAF2EC3";
String X = "1E005CC8810B";
String Y = "1E005BC3B432";
String Z = "1E005CC038BA";
MCUFRIEND_kbv tft;
SoftwareSerial mySoftwareSerial(23, 22); // RX, TX
DFRobotDFPlayerMini myDFPlayer;
int lcount = 1;
int LFlag = 1;
int LED1 = 47;
int LED2 = 46;
String re;                    //Crucial Declaration (As we have to hold the value in some place)
  mySoftwareSerial.begin(9600);
  Serial1.begin(9600);
  Serial2.begin(9600);
  Serial3.begin(9600);
  Serial.println("READY");
  myDFPlayer.begin(Serial3);
  //myDFPlayer.setTimeOut(500);
  myDFPlayer.volume(25);
  //myDFPlayer.play(4);
  //pinMode(LedPin, OUTPUT);
  uint16_t ID=tft.readID();
  tft.begin(ID);
    ID = tft.readID();
    tft.begin(ID);
    if (!good) {
        while (1);
  //int t = 100;        //Delay before starting the Audio module; Long Playback crashes in between
  //int t1 = 10000;        //Delay for the screen before tftFill()
  int img_time = 5000;
  int counter = 1;
  id = "initial";
  tft.fillScreen(WHITE);
  Serial.println("Out of the Loop?");
  Serial.println(lcount);
  ret = showBMP("B.bmp",0,0);
                //Printing letter 'B'                                       //Do I need to add some kind of counter in the beginning?
    if (lcount == 1) {
      Serial.println("Entered the loop");
      re = Serial1.readString();
      while (re == "") {
        ret = showBMP("B.bmp", 0, 0);
        Serial.println("ABCD");
        Serial.println(re);                                                   //How to get out of the while loop???
        if (re == B) {
            correct();        //Function has been formed!
       else if (re != B && re != "") {
          incorrect();
        //Letter B Loading; Need to hold the image for a few seconds; While loop required?
                //Printing Letter 'Z'
    if (lcount == 2) {
       Serial.println("Successfully Entered another loop");
       while(re == "") {
        ret = showBMP("Z.bmp",0,0);
        Serial.println(re);
        if (re == Z) {
          else if (re != Z && re != "") {                 //id == initial; I Need some kind of exception ; ReadString() has been specified not Read()
            incorrect();
                //Printing Letter 'X'
    if (lcount == 3) {
       Serial.println("Looping Successfully!,3");
       while(re == "") {
        ret = showBMP("X.bmp",5,5);
          if (re == X) {
          else if (re != X && re != "") {                                                   //id == initial; I Need some kind of exception ; ReadString() has been specified not Read()
            incorrect();
void correct() {
        digitalWrite(LED1, HIGH);
        Serial.println("CORRECT ANSWER");
        myDFPlayer.play(1);                       //Audio --> This is the correct answer!
        delay(2000);
        digitalWrite(LED1, LOW);
        LFlag = 1;
        lcount += 1;                                                          //Incorrect Coding --> (lcount += lcount) does not increment by 1 except the first iteration [Lol!]
void incorrect() {
       digitalWrite(LED2, HIGH);
       Serial.println("INCORRECT ANSWER");
       myDFPlayer.play(2);                 //Audio --> This is the incorrect answer!
       delay(5000);
       digitalWrite(LED2, LOW);
          //LCD Screen Function
    return result;
    uint32_t result;
    return result;
    File bmpFile;
    uint16_t bmpID;
    uint8_t ret;
    else {
        bool first = true;
            flip = false;
        w = bmpWidth;
        h = bmpHeight;
            bitmask = 0xFF;
            if (bmpDepth < 8)
            n = 1 << bmpDepth;
            lcdbufsiz -= n;
                bmpFile.seek(pos);
                lcdleft = w - col;
                    uint16_t color;
                        r = 0;
                        case 24:
                first = false;
                col += lcdidx;
            }           // end cols
        }               // end rows
    bmpFile.close();
    return (ret);
type or paste code here
