This is for displaying letters in a 16*16 LED matrix.The code only works for the first case, which is 1095. The switch case does not work when the Rcvalue is 1195,1295; it only checks for the first case and ends the switch case.
#define RCpin 10
int RCvalue;
#define MATRIX_WIDTH 16
#define MATRIX_HEIGHT 16
#define MATRIX_PIN 7 // Change this to match your data pin
Adafruit_NeoPixel matrix = Adafruit_NeoPixel(MATRIX_WIDTH * MATRIX_HEIGHT, MATRIX_PIN, NEO_GRB + NEO_KHZ800);
Serial.begin(9600); // Serial for debug
pinMode(RCpin, INPUT);
matrix.begin();
matrix.show();
displayLetter();
void displayLetter() {
RCvalue=pulseIn(RCpin, HIGH);
Serial.println(RCvalue);
switch(RCvalue)
case 1095:
byte m[MATRIX_HEIGHT][MATRIX_WIDTH] = {
{0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0},
{0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0},
{0, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 0},
{0, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 0},
{0, 1, 1, 1, 1, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 0},
{0, 1, 1, 1, 1, 1, 0, 0, 0, 0, 1, 1, 1, 1, 1, 0},
{0, 1, 1, 1, 1, 1, 1, 0, 0, 1, 1, 1, 1, 1, 1, 0},
{0, 1, 1, 1, 0, 1, 1, 1, 1, 1, 1, 0, 1, 1, 1, 0},
{0, 1, 1, 1, 0, 0, 1, 1, 1, 1, 0, 0, 1, 1, 1, 0},
{0, 1, 1, 1, 0, 0, 0, 1, 1, 0, 0, 0, 1, 1, 1, 0},
displayletter(m);
case 1195:
byte k[MATRIX_HEIGHT][MATRIX_WIDTH] = {
{0, 0, 0, 0, 1, 1, 1, 0, 0, 0, 0, 0, 1, 1, 1, 0},
{0, 0, 0, 0, 0, 1, 1, 1, 0, 0, 0, 0, 1, 1, 1, 0},
{0, 0, 0, 0, 0, 0, 1, 1, 1, 0, 0, 0, 1, 1, 1, 0},
{0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 0, 0, 1, 1, 1, 0},
{0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 0, 1, 1, 1, 0},
{0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 1, 1, 0},
{0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 1, 0},
{0, 0, 0, 1, 1, 1, 0, 0, 0, 0, 0, 0, 1, 1, 1, 0},
displayletter(k);
case 1295:
byte i[MATRIX_HEIGHT][MATRIX_WIDTH] = {
{0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0},
{0, 0, 0, 0, 0, 0, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0},
displayletter(i);
case 1395:
byte t[MATRIX_HEIGHT][MATRIX_WIDTH] = {
displayletter(t);
void displayletter(byte letter[MATRIX_HEIGHT][MATRIX_WIDTH]){
for (int y = 0; y < MATRIX_HEIGHT; y++) { //
for (int x = 0; x < MATRIX_WIDTH; x++) {
if (letter[y][x] == 1) {
int pixelNumber;
if (y % 2 == 0) {
// Even rows
pixelNumber = y * MATRIX_WIDTH + x;
// Odd rows
pixelNumber = y * MATRIX_WIDTH + (MATRIX_WIDTH - 1 - x);
matrix.setPixelColor(pixelNumber, matrix.Color(255, 0, 0)); // Set the color to red (you can change this)
matrix.show(); // Display the pattern
