Displaying potentiometer values to one decimal place
Hello,
I want to lcd.print the output of a potentiometer to one decimal place. The following code displays the 1-5 range I would like, I would just like it to be expressed with one decimal place added.
My apologies for the simple question and likely awkward code, I am new to programming. In searching online and studying examples I have found some answers say to use float and some say it is not the best way.
#include <LiquidCrystal.h> // include the library code
#define meterPin 5
#define potentiometerPin A1
LiquidCrystal lcd(13, 12, 11, 10, 9, 8); // initialize the library with the numbers of the interface pins
  pinMode(meterPin, OUTPUT);
  lcd.begin(16, 2); // set up the LCD's number of columns and rows
  int potentiometerValue = analogRead(potentiometerPin);
  int meterPower = map(potentiometerValue, 0, 1020, 0, 255); //the power range of the meter
  int lcdRange = map(potentiometerValue, 0, 1020, 0, 5);  // the 1-5 range of the display on the LCD
  lcd.setCursor(6, 0); // set the cursor to column 6, line 0
  lcd.print(lcdRange); // print out the value on LCD Display
  lcd.setCursor(8, 0); // set the cursor to column 8, line 0
  lcd.print("MJ");
  analogWrite(meterPin, meterPower);
  delay(100);
  lcd.clear();
"int" is an abbreviation of "integer".
Integers have no fractional decimals.
For the above values if you want more resolution then you can map the integer range from the pot to a float range. Then you can print whatever resolution value that you want to.
Thank you for taking the time to reply. I guess it's back to the drawing board and work with float.
Or simply multiply your working range by 10, and keep using integers.
You'll need a float. I'm not sure if you can "force" map() to return a float but if you define ldcRange as a float then lcdRange = 5 * PotentiometerValue / 1020 should work.
But, I've forgotten some of those rules so you might have to use lcdRange = (float)5 * PotentiometerValue.
You'll also have to figure-out how to print just one decimal place.
This is working but creates two decimal places.
float Percentage = (analogRead(potentiometerPin) / 1020.0) * 5;
float PercentageRound = Percentage + 0.005;
  lcd.setCursor(0, 0); // set the cursor to column 0, line 0
  lcd.print(PercentageRound); // print out the value on LCD Display
  delay(100);
  lcd.clear();
By default you will see 2 decimal places printed
Try
lcd.print(PercentageRound, 1); //print 1 decimal place
instead
Thank you UKHeliBob, that worked. :grinning:
Sorry for the newbie question, but may I ask, in the following line of code, what the purpose of + 0.005 is?
No, not necessarily.
Instead of mapping to, say a range of 0 to 5, map to a range of 0 to 50.
Printing can be taken care of by division and modulus.
Now I have to try to get back to also being able to control my meter which worked in the original code that I posted.
Why has that changed?
The value that drives the meter is derived directly from the potentiometer value.
I would know that int is a keyword and not integer and accordingly I don't feel comfort to relate int with integer though the relation could be established.
I'm sure you know what you meant
Yes, thank you, I got it. It was easier than I was thinking it was going to be. Just inexperience.
Thanks to everyone that helped, below is the code that works for my project. It's probably awkward but I can learn from and try to improve it. :grinning:
#define meterPin 5
int meterPower = (analogRead(potentiometerPin) / 1020.0) * 255; //the power range of the meter
  lcd.setCursor(5, 0); // set the cursor to column 5, line 0
  lcd.print(PercentageRound, 1); //print 1 decimal place // print out the value on LCD Display
  lcd.setCursor(9, 0); // set the cursor to column 9, line 0
  lcd.print("MJ");
  delay(100);
  lcd.clear();
I wouldn't call 0-5 percentage. 0-100% would be.
Why 1020. A 10-bit A/D goes to 1023.
Seems like a "fix" for the lower end of the scale.
Try
int percentage = map(analogRead(potentiometerPin), 0, 1024, 0, 51); // 0-50
and then
lcd.print(percentage / 10, 1); // divide by 10 and display with one decimal place
I would have used
int meterPower = analogRead(potentiometerPin) >> 2; // 0-255 (10-bit to 8-bit)
Why clear the LCD after displaying 0.1 seconds. Does your brain work that fast?
You normally clear just before you write new data.
And, clearing the whole display takes time, so the display flickers.
It would be better to just overwrite the old data.
with maybe one or two spaces, to clear longer old data.
But that's a lot faster than clearing the whole screen.
Leo..
Hi Wawa,
Thank you for taking the time to help me with the code. This is a great opportunity for me to learn from the errors caused by my lack of experience. I like to learn by doing as well as lessons and tutorials so I know I make mistakes. It really helps to be corrected.
