The image data are too large to hold in memory for an UNO so I used a MEGA and I removed the alpha channel data which are used for transparency. That could be replaced by declaring the color R=G=B=Zero as transparent and replacing it by the background, like here
where white is used instead of black. I also added a struct to provide data like width and height.
See here for the manually modified image file
constexpr byte pixil_frame[] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0x00, 0x00, 0x00, 0x00, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0xa7, 0xb5, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
const lv_img_dsc_t pixil-frame-0 = {
.header.cf = LV_IMG_CF_RGB565A8,
.header.always_zero = 0,
.header.reserved = 0,
.header.w = 32,
.header.h = 32,
.data_size = 3072,
.data = pixil-frame-0_map,
struct imageType {
int width = 32;
int height = 32;
long data_size = 3072;
} image;
Might not be exactly what you want but it is a start ...
