When I launch RC 9.2 it is very sluggish & tanks upwards of a minute plus to launch, when I looked in the Windows Event Logs I see the following DistributedCOM warning.
The application-specific permission settings do not grant Local Activation permission for the COM Server application with CLSID ** {2593F8B9-4EAF-457C-B68A-50F6B8EA6B54}
** and APPID ** {15C20B67-12E7-4BB6-92BB-7AFF07997402}
** to the user DELL\user SID (S-1-5-21-2828522791-1489950809-1163912447-1001) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
This error is not necessarily related to the Arduino IDE
Determining whether it is related to the Arduino IDE is extremely difficult
Modifying the security permission is extremely difficult
So I think we would be better to focus the troubleshooting effort in other directions for now.
I'm going to ask you to post some additional information that might help us to identify the problem.
Please do this:
Start Windows "File Explorer".
Open the Arduino IDE installation folder.
(usually C:\Program Files\Arduino IDE or C:\Users\<user name>\AppData\Local\Programs\Arduino IDE).
In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
From the context menu, click "Open PowerShell window here".
PowerShell will now open with the current directory set to the Arduino IDE installation folder.
Type the following command:
& ".\Arduino IDE"
Press the Enter key.
Debug output should now be printed to the PowerShell window as the Arduino IDE starts (or fails to start).
Wait for the Arduino IDE to finish starting.
Switch back to the PowerShell window if the Arduino IDE window took the focus.
Right click on the title bar of the PowerShell window.
This will open a context menu.
Select Edit > Select All from the context menu.
This will select all the text in the PowerShell window.
Press Ctrl+C.
This will copy the contents of the PowerShell window to the clipboard.
Open a forum reply here by clicking the Reply button.
Click the </> icon on the post composer toolbar.
This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
Press Ctrl+V.
This will paste the output into the code block.
Move the cursor outside of the code block markup before you add any additional text to your reply.
Click the Reply button to post the output.
Please let me know if you have any questions or problems while following those instructions.
Hi Please find the requested debug information attached. I've now installed Version: 2.0.0-rc9.2.nightly-20220819 & start-up is much quicker, however I still see the DistributedCOM message in the Windows Event Log on start-up
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE"
Starting backend process. PID: 18204
Using browser-only version of superagent in non-browser environment
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
root INFO Configuration directory URI: 'file:///c%3A/Users/scafell/.theia'
root INFO Backend Object.initialize: 7.2 ms [Finished 2.336 s after backend start]
root INFO Backend Object.configure: 5.2 ms [Finished 2.336 s after backend start]
root INFO Backend MessagingContribution.onStart: 2.6 ms [Finished 2.337 s after backend start]
root INFO Backend OSBackendApplicationContribution.configure: 0.6 ms [Finished 2.422 s after backend start]
root INFO Backend DefaultWorkspaceServer.onStart: 0.5 ms [Finished 2.422 s after backend start]
root INFO Backend LocalizationBackendContribution.configure: 1.0 ms [Finished 2.423 s after backend start]
root INFO Backend TaskBackendApplicationContribution.onStart: 0.7 ms [Finished 2.423 s after backend start]
root WARN Backend LocalizationBackendContribution.initialize took longer than the expected maximum 50 milliseconds: 85.6 ms [Finished 2.423 s after backend start]
root INFO Backend ElectronTokenBackendContribution.configure: 2.2 ms [Finished 2.425 s after backend start]
root INFO Backend ConfigServiceImpl.onStart: 2.9 ms [Finished 2.426 s after backend start]
root INFO Backend PluginDeployerContribution.initialize: 1.2 ms [Finished 2.426 s after backend start]
root INFO Backend ArduinoDaemonImpl.onStart: 0.8 ms [Finished 2.428 s after backend start]
root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.3 ms [Finished 2.428 s after backend start]
daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
root INFO Backend NodeFileUploadService.configure: 3.2 ms [Finished 2.430 s after backend start]
discovery-log INFO start
discovery-log INFO start new deferred
root INFO Backend BoardDiscovery.onStart: 0.9 ms [Finished 2.431 s after backend start]
root INFO Backend FileDownloadEndpoint.configure: 1.0 ms [Finished 2.433 s after backend start]
root INFO Backend AuthenticationServiceImpl.onStart: 0.9 ms [Finished 2.434 s after backend start]
root INFO Backend PluginApiContribution.configure: 0.9 ms [Finished 2.435 s after backend start]
root INFO Backend HostedPluginReader.configure: 0.3 ms [Finished 2.436 s after backend start]
root INFO Backend PlotterBackendContribution.configure: 1.4 ms [Finished 2.438 s after backend start]
root INFO Theia app listening on http://localhost:50955.
root INFO Finished starting backend application: 10.5 ms [Finished 2.445 s after backend start]
root WARN The local plugin referenced by local-dir:/c%3A/Users/scafell/.arduinoIDE/plugins does not exist.
root WARN The local plugin referenced by local-dir:/c%3A/Users/scafell/.arduinoIDE/extensions does not exist.
root WARN The local plugin referenced by local-dir:C:\Users\scafell\.arduinoProIDE\plugins does not exist.
Restoring workspace roots: c:\Users\scafell\Documents\Arduino\ECM_Water_Level_Monitor_SensorMeanAverage_PeriodicCal_2_Status_
root INFO PluginTheiaDirectoryHandler: accepting plugin with path
root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@0.3.10" with engines:
root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.5" with engines:
root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.69.0" with engines:
root ERROR ---- !!!SLOW!!! DURATION: loadCliConfig took 321.157 ms. Args: [] ----
root INFO Resolve plugins list: 2862.9 ms [Finished 5.296 s after backend start]
root INFO Deployed backend plugin "cortex-debug@0.3.10" from "C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension": 15.5 ms [Finished 5.312 s after backend start]
root INFO Deployed backend plugin "vscode-arduino-tools@0.0.2-beta.5" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 11.1 ms [Finished 5.323 s after backend start]
root INFO Deployed backend plugin "cpp@1.52.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 28.6 ms [Finished 5.352 s after backend start]
root INFO Deployed backend plugin "json@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 7.8 ms [Finished 5.359 s after backend start]
root INFO Deployed backend plugin "json-language-features@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 2.7 ms [Finished 5.362 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-cs@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 233.3 ms [Finished 5.595 s after backend start]
daemon INFO {"level":"info","msg":"Using config file: c:\\Users\\scafell\\.arduinoIDE\\arduino-cli.yaml","time":"2022-08-19T13:14:30+01:00"}
{"level":"info","msg":"arduino-cli.exe version git-snapshot","time":"2022-08-19T13:14:30+01:00"}
{"level":"info","msg":"Executing `arduino-cli daemon`","time":"2022-08-19T13:14:30+01:00"}
{"IP":"127.0.0.1","Port":"64898"}
daemon INFO Daemon is running.
root INFO Deployed backend plugin "vscode-language-pack-de@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 316.4 ms [Finished 5.912 s after backend start]
daemon INFO {"level":"info","msg":"Loading hardware from: c:\\Users\\scafell\\AppData\\Local\\Arduino15\\packages","time":"2022-08-19T13:14:31+01:00"}
root INFO Deployed backend plugin "vscode-language-pack-es@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 314.3 ms [Finished 6.226 s after backend start]
daemon INFO {"level":"info","msg":"Loading package arduino from: C:\\Users\\scafell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware","time":"2022-08-19T13:14:31+01:00"}
{"level":"info","msg":"Adding monitor tool","protocol":"serial","time":"2022-08-19T13:14:31+01:00","tool":"builtin:serial-monitor"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"arduino:avr","Installed":"1.8.5","Latest":"1.8.5","Name":"Arduino AVR Boards"},"time":"2022-08-19T13:14:31+01:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\scafell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2022-08-19T13:14:31+01:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\scafell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2022-08-19T13:14:31+01:00"}
{"level":"info","msg":"Loaded tool","time":"2022-08-19T13:14:31+01:00","tool":{"version":"1.3.0","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-08-19T13:14:31+01:00","tool":{"version":"7.3.0-atmel3.6.1-arduino7","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-08-19T13:14:31+01:00","tool":{"version":"6.3.0-arduino17","systems":null}}
{"level":"info","msg":"Loading package builtin from: C:\\Users\\scafell\\AppData\\Local\\Arduino15\\packages\\builtin","time":"2022-08-19T13:14:31+01:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\scafell\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2022-08-19T13:14:31+01:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\scafell\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2022-08-19T13:14:31+01:00"}
{"level":"info","msg":"Loaded tool","time":"2022-08-19T13:14:31+01:00","tool":{"version":"5.8-arduino11","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-08-19T13:14:31+01:00","tool":{"version":"0.9.2","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-08-19T13:14:31+01:00","tool":{"version":"1.0.2","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-08-19T13:14:31+01:00","tool":{"version":"1.0.5","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-08-19T13:14:31+01:00","tool":{"version":"1.1.0","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-08-19T13:14:31+01:00","tool":{"version":"1.2.1","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-08-19T13:14:31+01:00","tool":{"version":"1.3.0-rc1","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-08-19T13:14:31+01:00","tool":{"version":"1.3.1","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-08-19T13:14:31+01:00","tool":{"version":"1.3.2","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-08-19T13:14:31+01:00","tool":{"version":"0.9.1","systems":null}}
{"index":"c:\\Users\\scafell\\AppData\\Local\\Arduino15\\package_index.json","level":"info","msg":"Checking signature","signatureFile":"c:\\Users\\scafell\\AppData\\Local\\Arduino15\\package_index.json.sig","time":"2022-08-19T13:14:31+01:00","trusted":true}
{"dir":"C:\\Users\\scafell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-08-19T13:14:31+01:00"}
root INFO Deployed backend plugin "vscode-language-pack-fr@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 208.5 ms [Finished 6.435 s after backend start]
daemon INFO {"dir":"c:\\Users\\scafell\\Documents\\Arduino\\libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2022-08-19T13:14:31+01:00"}
root INFO Deployed backend plugin "vscode-language-pack-it@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 187.5 ms [Finished 6.622 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-ja@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 176.0 ms [Finished 6.798 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-nl@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 58.1 ms [Finished 6.856 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-pt-BR@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 243.0 ms [Finished 7.100 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-ru@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 245.5 ms [Finished 7.345 s after backend start]
discovery-log INFO start request start watch
discovery-log INFO start requested start watch
discovery-log INFO start resolved watching
daemon INFO {"level":"info","msg":"starting discovery builtin:mdns-discovery process","time":"2022-08-19T13:14:32+01:00"}
root INFO Deployed backend plugin "vscode-language-pack-tr@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 212.9 ms [Finished 7.558 s after backend start]
daemon INFO {"level":"info","msg":"starting discovery builtin:serial-discovery process","time":"2022-08-19T13:14:32+01:00"}
{"level":"info","msg":"started discovery builtin:mdns-discovery process","time":"2022-08-19T13:14:32+01:00"}
{"level":"info","msg":"sending command HELLO 1 \"arduino-cli git-snapshot\" to discovery builtin:mdns-discovery","time":"2022-08-19T13:14:32+01:00"}
{"level":"info","msg":"started discovery builtin:serial-discovery process","time":"2022-08-19T13:14:32+01:00"}
{"level":"info","msg":"sending command HELLO 1 \"arduino-cli git-snapshot\" to discovery builtin:serial-discovery","time":"2022-08-19T13:14:32+01:00"}
{"level":"info","msg":"from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1","time":"2022-08-19T13:14:32+01:00"}
{"level":"info","msg":"sending command START_SYNC to discovery builtin:mdns-discovery","time":"2022-08-19T13:14:32+01:00"}
{"level":"info","msg":"from discovery builtin:mdns-discovery received message type: start_sync, message: OK","time":"2022-08-19T13:14:32+01:00"}
{"level":"info","msg":"from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1","time":"2022-08-19T13:14:32+01:00"}
{"level":"info","msg":"sending command START_SYNC to discovery builtin:serial-discovery","time":"2022-08-19T13:14:32+01:00"}
{"level":"info","msg":"from discovery builtin:serial-discovery received message type: start_sync, message: OK","time":"2022-08-19T13:14:32+01:00"}
root INFO Deployed backend plugin "vscode-language-pack-zh-hans@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 261.6 ms [Finished 7.820 s after backend start]
root INFO Deploy plugins list: 2862.9 ms [Finished 7.839 s after backend start]
root WARN Frontend s.configure took longer than the expected maximum 100 milliseconds: 976.0 ms [Finished 5.449 s after frontend start]
app-state-change >>> new app state <started_contributions was received from sender <1>. current window ID: 1
app-state-change <<< new app state is <started_contributions> for window <1>
root INFO Start frontend contributions: 1549.6 ms [Finished 5.799 s after frontend start]
root INFO Changed application state from 'init' to 'started_contributions'.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8] Waiting for backend deployment: 86.8 ms [Finished 5.880 s after frontend start]
root INFO [hosted-plugin: 1248] PLUGIN_HOST(1248) starting instance
root WARN Mismatching sketch file <Espresso_Machine_Water_Tank_Level_Monitor_Sleep_Test.ino> and sketch folder name <Sketch Archive>. Skipping
root WARN Mismatching sketch file <Espresso_Machine_Water_Tank_Level_Monitor_RUNTIME_Test.ino> and sketch folder name <Sketch Archive>. Skipping
root WARN Mismatching sketch file <Espresso_Machine_Water_Tank_Level_Monitor_DEBUG.ino> and sketch folder name <Espresso_Machine_Water_Tank_Level_Monitor_DEBUG_2>. Skipping
root WARN Mismatching sketch file <Espresso_Machine_Water_Tank_Level_Monitor_DEBUG.ino> and sketch folder name <Espresso_Machine_Water_Tank_Level_Monitor_DEBUG_3>. Skipping
root WARN Mismatching sketch file <Espresso_Machine_Water_Tank_Level_Monitor_RUNTIME.ino> and sketch folder name <Espresso_Machine_Water_Tank_Level_Monitor_RUNTIME_2>. Skipping
root WARN Mismatching sketch file <Espresso_Machine_Water_Tank_Level_Monitor_RUNTIME.ino> and sketch folder name <Espresso_Machine_Water_Tank_Level_Monitor_RUNTIME_3>. Skipping
root WARN Mismatching sketch file <Espresso_Machine_Water_Tank_Level_Monitor_RUNTIME.ino> and sketch folder name <Espresso_Machine_Water_Tank_Level_Monitor_RUNTIME_4>. Skipping
root WARN Mismatching sketch file <Espresso_Machine_Water_Tank_Level_Monitor_RUNTIME.ino> and sketch folder name <Espresso_Machine_Water_Tank_Level_Monitor_RUNTIME_7>. Skipping
root WARN Mismatching sketch file <ECM_Water_Level_Monitor_PeriodicCal_SensorMeanAverage_NoCal.ino> and sketch folder name <ECM_Water_Level_Monitor_PeriodicCal_SensorMeanAverage_NoCal_1>. Skipping
root WARN Mismatching sketch file <ECM_Water_Level_Monitor_PeriodicCal_SensorMeanAverage_NoPeriodicCal_Beta.ino> and sketch folder name <ECM_Water_Level_Monitor_SensorMeanAverage_NoPeriodicCal_Beta>. Skipping
root ERROR ---- !!!SLOW!!! DURATION: getSketchesNew took 816.286 ms. Args: [{"uri":"file:///c%3A/Users/scafell/Documents/Arduino"}] ----
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8] Sync of 16 plugins: 1449.3 ms [Finished 7.329 s after frontend start]
daemon INFO {"level":"info","msg":"Updating libraries index","time":"2022-08-19T13:14:42+01:00"}
daemon INFO {"level":"info","msg":"URL: https://downloads.arduino.cc/packages/package_index.tar.bz2","time":"2022-08-19T13:14:42+01:00"}
{"level":"info","msg":"Updating index","time":"2022-08-19T13:14:42+01:00","url":{"Scheme":"https","Opaque":"","User":null,"Host":"downloads.arduino.cc","Path":"/packages/package_index.tar.bz2","RawPath":"","ForceQuery":false,"RawQuery":"","Fragment":"","RawFragment":""}}
root INFO core-client-provider [platform-index]
root INFO core-client-provider [library-index]
daemon INFO {"level":"info","msg":"Loading hardware from: c:\\Users\\scafell\\AppData\\Local\\Arduino15\\packages","time":"2022-08-19T13:14:44+01:00"}
daemon INFO {"level":"info","msg":"Loading package arduino from: C:\\Users\\scafell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware","time":"2022-08-19T13:14:44+01:00"}
daemon INFO {"level":"info","msg":"Adding monitor tool","protocol":"serial","time":"2022-08-19T13:14:44+01:00","tool":"builtin:serial-monitor"}
daemon INFO {"level":"info","msg":"Loaded platform","platform":{"ID":"arduino:avr","Installed":"1.8.5","Latest":"1.8.5","Name":"Arduino AVR Boards"},"time":"2022-08-19T13:14:44+01:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\scafell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2022-08-19T13:14:44+01:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\scafell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2022-08-19T13:14:44+01:00"}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-08-19T13:14:44+01:00","tool":{"version":"1.3.0","systems":null}}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-08-19T13:14:44+01:00","tool":{"version":"7.3.0-atmel3.6.1-arduino7","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-08-19T13:14:44+01:00","tool":{"version":"6.3.0-arduino17","systems":null}}
daemon INFO {"level":"info","msg":"Loading package builtin from: C:\\Users\\scafell\\AppData\\Local\\Arduino15\\packages\\builtin","time":"2022-08-19T13:14:44+01:00"}
daemon INFO {"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\scafell\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2022-08-19T13:14:44+01:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\scafell\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2022-08-19T13:14:44+01:00"}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-08-19T13:14:44+01:00","tool":{"version":"5.8-arduino11","systems":null}}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-08-19T13:14:44+01:00","tool":{"version":"0.9.2","systems":null}}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-08-19T13:14:44+01:00","tool":{"version":"1.0.2","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-08-19T13:14:44+01:00","tool":{"version":"1.0.5","systems":null}}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-08-19T13:14:44+01:00","tool":{"version":"1.1.0","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-08-19T13:14:44+01:00","tool":{"version":"1.2.1","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-08-19T13:14:44+01:00","tool":{"version":"1.3.0-rc1","systems":null}}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-08-19T13:14:44+01:00","tool":{"version":"1.3.1","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-08-19T13:14:44+01:00","tool":{"version":"1.3.2","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-08-19T13:14:44+01:00","tool":{"version":"0.9.1","systems":null}}
daemon INFO {"index":"c:\\Users\\scafell\\AppData\\Local\\Arduino15\\package_index.json","level":"info","msg":"Checking signature","signatureFile":"c:\\Users\\scafell\\AppData\\Local\\Arduino15\\package_index.json.sig","time":"2022-08-19T13:14:44+01:00","trusted":true}
daemon INFO {"dir":"C:\\Users\\scafell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-08-19T13:14:44+01:00"}
daemon INFO {"dir":"c:\\Users\\scafell\\Documents\\Arduino\\libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2022-08-19T13:14:44+01:00"}
discovery-log INFO restarting before stop
discovery-log INFO stop
discovery-log INFO >>> Stopping boards watcher...
discovery-log INFO Canceling boards watcher...
discovery-log INFO disposing requesting cancel
discovery-log INFO disposing canceled
discovery-log INFO error received
discovery-log INFO cancel error received!
discovery-log INFO stop received event: either end or cancel
discovery-log INFO stop stopped
discovery-log INFO received end
discovery-log INFO restarting after stop
daemon INFO {"level":"info","msg":"boards watcher stream closed","time":"2022-08-19T13:14:45+01:00"}
daemon INFO {"level":"info","msg":"starting discovery builtin:mdns-discovery process","time":"2022-08-19T13:14:45+01:00"}
{"level":"info","msg":"starting discovery builtin:serial-discovery process","time":"2022-08-19T13:14:45+01:00"}
daemon INFO {"level":"info","msg":"started discovery builtin:mdns-discovery process","time":"2022-08-19T13:14:45+01:00"}
daemon INFO {"level":"info","msg":"sending command HELLO 1 \"arduino-cli git-snapshot\" to discovery builtin:mdns-discovery","time":"2022-08-19T13:14:45+01:00"}
daemon INFO {"level":"info","msg":"started discovery builtin:serial-discovery process","time":"2022-08-19T13:14:45+01:00"}
{"level":"info","msg":"sending command HELLO 1 \"arduino-cli git-snapshot\" to discovery builtin:serial-discovery","time":"2022-08-19T13:14:45+01:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1","time":"2022-08-19T13:14:45+01:00"}
daemon INFO {"level":"info","msg":"sending command START_SYNC to discovery builtin:serial-discovery","time":"2022-08-19T13:14:45+01:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:serial-discovery received message type: start_sync, message: OK","time":"2022-08-19T13:14:45+01:00"}
{"level":"info","msg":"from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1","time":"2022-08-19T13:14:45+01:00"}
daemon INFO {"level":"info","msg":"sending command START_SYNC to discovery builtin:mdns-discovery","time":"2022-08-19T13:14:45+01:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:mdns-discovery received message type: start_sync, message: OK","time":"2022-08-19T13:14:45+01:00"}
app-state-change >>> new app state <attached_shell was received from sender <1>. current window ID: 1
app-state-change <<< new app state is <attached_shell> for window <1>
root INFO Changed application state from 'started_contributions' to 'attached_shell'.
root INFO >>> Restoring the layout state...
root INFO ------- SERIALIZED LAYOUT DATA -------
root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"kind":"navigatable","uri":"file:///c%3A/Users/scafell/Documents/Arduino/ECM_Water_Level_Monitor_SensorMeanAverage_PeriodicCal_2_Status_/ECM_Water_Level_Monitor_SensorMeanAverage_PeriodicCal_2_Status_.ino","counter":0}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":21,\"column\":37},\"position\":{\"lineNumber\":21,\"column\":37}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":8,\"column\":1},\"firstPositionDeltaTop\":-14},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":551,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"}],"currentIndex":0}},"pinned":[false],"size":232,"expanded":false},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":true,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}],"size":294},"rightPanel":{"type":"sidepanel","items":[]},"activeWidgetId":"code-editor-opener:file:///c%3A/Users/scafell/Documents/Arduino/ECM_Water_Level_Monitor_SensorMeanAverage_PeriodicCal_2_Status_/ECM_Water_Level_Monitor_SensorMeanAverage_PeriodicCal_2_Status_.ino:0"}
root INFO ------- END SERIALIZED LAYOUT DATA -------
root INFO isTemp?
root INFO <<< The layout has been successfully restored.
app-state-change >>> new app state <initialized_layout was received from sender <1>. current window ID: 1
app-state-change <<< new app state is <initialized_layout> for window <1>
root INFO Initialize the workbench layout: 585.9 ms [Finished 28.664 s after frontend start]
root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][marus25.cortex-debug]: Loaded contributions.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][arduino.vscode-arduino-tools]: Loaded contributions.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][vscode.cpp]: Loaded contributions.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][vscode.json]: Loaded contributions.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][vscode.json-language-features]: Loaded contributions.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][ms-ceintl.vscode-language-pack-cs]: Loaded contributions.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][ms-ceintl.vscode-language-pack-de]: Loaded contributions.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][ms-ceintl.vscode-language-pack-es]: Loaded contributions.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][ms-ceintl.vscode-language-pack-fr]: Loaded contributions.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][ms-ceintl.vscode-language-pack-it]: Loaded contributions.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][ms-ceintl.vscode-language-pack-ja]: Loaded contributions.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][ms-ceintl.vscode-language-pack-nl]: Loaded contributions.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][ms-ceintl.vscode-language-pack-pt-br]: Loaded contributions.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][ms-ceintl.vscode-language-pack-ru]: Loaded contributions.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][ms-ceintl.vscode-language-pack-tr]: Loaded contributions.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][ms-ceintl.vscode-language-pack-zh-hans]: Loaded contributions.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8] Load contributions of 16 plugins: 236.0 ms [Finished 28.904 s after frontend start]
root WARN Frontend T.onDidInitializeLayout took longer than the expected maximum 100 milliseconds: 242.8 ms [Finished 28.908 s after frontend start]
root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
root WARN a registered grammar configuration for 'cpp' language is overridden
root INFO isTemp?
app-state-change >>> new app state <ready was received from sender <1>. current window ID: 1
app-state-change <<< new app state is <ready> for window <1>
root INFO Frontend application start: 26248.0 ms [Finished 34.192 s after backend start]
root INFO Replace loading indicator with ready workbench UI (animation): 2139.8 ms [Finished 31.051 s after frontend start]
root INFO Changed application state from 'initialized_layout' to 'ready'.
root INFO ---- DURATION: installed took 98.047 ms. Args: [{}] ----
root INFO isTemp?
root INFO Executing startup tasks: []
Checking for update
root ERROR ---- !!!SLOW!!! DURATION: getSketchesNew took 192.816 ms. Args: [{}] ----
root INFO ---- DURATION: installed took 37.085 ms. Args: [{"fqbn":"arduino:avr:nano"}] ----
Update for version 2.0.0-rc9.2.nightly-20220819 is not available (latest version: 2.0.0-rc9.2.nightly-20220819, downgrade is allowed).
root INFO [hosted-plugin: 1248] PLUGIN_HOST(1248): PluginManagerExtImpl/init()
root INFO [hosted-plugin: 1248] PLUGIN_HOST(1248): initializing(cortex-debug@0.3.10 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 1248] Debugger contribution has been registered: cortex-debug
root INFO [hosted-plugin: 1248] PLUGIN_HOST(1248): initializing(vscode-arduino-tools@0.0.2-beta.5 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(1248): initializing(cpp@1.52.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 1248] PLUGIN_HOST(1248): initializing(json@1.46.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(1248): initializing(json-language-features@1.46.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(1248): initializing(vscode-language-pack-cs@1.69.0 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(1248): initializing(vscode-language-pack-de@1.69.0 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(1248): initializing(vscode-language-pack-es@1.69.0 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(1248): initializing(vscode-language-pack-fr@1.69.0 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 1248] PLUGIN_HOST(1248): initializing(vscode-language-pack-it@1.69.0 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(1248): initializing(vscode-language-pack-ja@1.69.0 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(1248): initializing(vscode-language-pack-nl@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 1248] PLUGIN_HOST(1248): initializing(vscode-language-pack-pt-BR@1.69.0 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(1248): initializing(vscode-language-pack-ru@1.69.0 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 1248] PLUGIN_HOST(1248): initializing(vscode-language-pack-tr@1.69.0 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 1248] PLUGIN_HOST(1248): initializing(vscode-language-pack-zh-hans@1.69.0 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 1248] PLUGIN_HOST(1248): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
root INFO [hosted-plugin: 1248] PLUGIN_HOST(1248): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle)
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][marus25.cortex-debug]: Started plugin.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][arduino.vscode-arduino-tools]: Started plugin.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][vscode.cpp]: Started plugin.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][vscode.json]: Started plugin.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][vscode.json-language-features]: Started plugin.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][ms-ceintl.vscode-language-pack-cs]: Started plugin.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][ms-ceintl.vscode-language-pack-de]: Started plugin.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][ms-ceintl.vscode-language-pack-es]: Started plugin.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][ms-ceintl.vscode-language-pack-fr]: Started plugin.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][ms-ceintl.vscode-language-pack-it]: Started plugin.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][ms-ceintl.vscode-language-pack-ja]: Started plugin.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][ms-ceintl.vscode-language-pack-nl]: Started plugin.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][ms-ceintl.vscode-language-pack-pt-br]: Started plugin.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][ms-ceintl.vscode-language-pack-ru]: Started plugin.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][ms-ceintl.vscode-language-pack-tr]: Started plugin.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8][ms-ceintl.vscode-language-pack-zh-hans]: Started plugin.
root INFO [673c3a57-8467-447d-b1c3-c6a2b20d41f8] Start of 16 plugins: 8948.1 ms [Finished 37.874 s after frontend start]
root INFO Starting language server: arduino:avr:nano
daemon INFO {"level":"info","msg":"Searching tools required for board arduino:avr:nano","time":"2022-08-19T13:15:06+01:00"}
daemon INFO {"level":"info","msg":"Required tool","time":"2022-08-19T13:15:06+01:00","tool":{"ToolName":"arduinoOTA","ToolVersion":"1.3.0","ToolPackager":"arduino"}}
{"level":"info","msg":"Required tool","time":"2022-08-19T13:15:06+01:00","tool":{"ToolName":"avr-gcc","ToolVersion":"7.3.0-atmel3.6.1-arduino7","ToolPackager":"arduino"}}
daemon INFO {"level":"info","msg":"Required tool","time":"2022-08-19T13:15:06+01:00","tool":{"ToolName":"avrdude","ToolVersion":"6.3.0-arduino17","ToolPackager":"arduino"}}
{"dir":"C:\\Program Files (x86)\\Arduino\\libraries","level":"info","location":"ide","msg":"Adding libraries dir","time":"2022-08-19T13:15:06+01:00"}
{"dir":"C:\\Users\\scafell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-08-19T13:15:06+01:00"}
daemon INFO {"dir":"c:\\Users\\scafell\\Documents\\Arduino\\libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2022-08-19T13:15:06+01:00"}
daemon INFO {"level":"info","msg":"Resolving include Wire.h for arch avr","time":"2022-08-19T13:15:08+01:00"}
daemon INFO {"level":"info","lib":"Wire","msg":" found better lib","prio":"64C","time":"2022-08-19T13:15:08+01:00"}
daemon INFO {"level":"info","msg":"Resolving include Average.h for arch avr","time":"2022-08-19T13:15:08+01:00"}
{"level":"info","lib":"Average","msg":" found better lib","prio":"643","time":"2022-08-19T13:15:08+01:00"}
daemon INFO {"level":"info","msg":"Resolving include VL53L0X.h for arch avr","time":"2022-08-19T13:15:08+01:00"}
{"level":"info","lib":"VL53L0X","msg":" found better lib","prio":"643","time":"2022-08-19T13:15:08+01:00"}
daemon INFO {"level":"info","msg":"Resolving include Adafruit_GFX.h for arch avr","time":"2022-08-19T13:15:08+01:00"}
daemon INFO {"level":"info","lib":"Adafruit_GFX_Library","msg":" found better lib","prio":"517","time":"2022-08-19T13:15:08+01:00"}
daemon INFO {"level":"info","msg":"Resolving include Adafruit_I2CDevice.h for arch avr","time":"2022-08-19T13:15:08+01:00"}
daemon INFO {"level":"info","lib":"Adafruit_BusIO","msg":" found better lib","prio":"3EB","time":"2022-08-19T13:15:08+01:00"}
daemon INFO {"level":"info","msg":"Resolving include SPI.h for arch avr","time":"2022-08-19T13:15:08+01:00"}
{"level":"info","lib":"SPI","msg":" found better lib","prio":"64C","time":"2022-08-19T13:15:08+01:00"}
daemon INFO {"level":"info","msg":"Resolving include Adafruit_SSD1306.h for arch avr","time":"2022-08-19T13:15:08+01:00"}
daemon INFO {"level":"info","lib":"Adafruit_SSD1306","msg":" found better lib","prio":"643","time":"2022-08-19T13:15:08+01:00"}
daemon INFO {"level":"info","msg":"Searching tools required for board arduino:avr:nano","time":"2022-08-19T13:15:11+01:00"}
daemon INFO {"level":"info","msg":"Required tool","time":"2022-08-19T13:15:11+01:00","tool":{"ToolName":"arduinoOTA","ToolVersion":"1.3.0","ToolPackager":"arduino"}}
{"level":"info","msg":"Required tool","time":"2022-08-19T13:15:11+01:00","tool":{"ToolName":"avr-gcc","ToolVersion":"7.3.0-atmel3.6.1-arduino7","ToolPackager":"arduino"}}
{"level":"info","msg":"Required tool","time":"2022-08-19T13:15:11+01:00","tool":{"ToolName":"avrdude","ToolVersion":"6.3.0-arduino17","ToolPackager":"arduino"}}
Everything in the logs looks perfectly normal. If the IDE is now working as expected, I would recommend not worrying about the events in the log. The reference link I shared in my previous reply indicates that it is normal to see these events in some cases and action only needs to be taken when the current permissions for the application are interfering with its functionality.
Thanks for the feedback. Now that the IDE is opening in a respectable time I think we can close this one so you can concentrate on more important issues.
