Hello
I have a problem with my project and I just couldn't go any further, I restrained your help.
About the project:
On one side an Anrduino Nano with NRF24L01 receives DMX data, evaluates it / converts it into PWM signals. These are then sent to the recipient via radio and an NRF.
The receiver board (Nano + NRF24L01) converts this data back into PWM signals and controls / dims some LEDs with it.
My code also works great with one Nano + NRF24L01 on each side - RX and TX. Now I would like to use a nano RF as RX for reasons of space. As far as I know, the RX code only differs in the order of the CE / CSN pins. This is the only difference, in my opinion.
However, I can't get the whole thing to work with the Nano-RF.
As I said, it works with 2 normal nanos + NRF24L01.
What am I doing wrong or where is my mistake?
TX Code
// Transmitter - Nana + NRF24L01 //
#include <TM1637.h> // display TM1637 lib
#include <EEPROM.h> // EEPROM lib
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <Wire.h>
#include <DMXSerial.h>// Constants for demo program
TM1637 tm1637(2,4); // CLK & DIO input pin from TM1637
#define MODEPIN 3 // mode input pin
#define UPPIN 5 // increment DMX address input pin
#define DOWNPIN 6 // decrement DMX address input pin
#define SETPIN 7 // set input pin#define KEYSPEED 100 // buttons action trheshold, ms
#define KEEPDMXDISP 30 // keep DMX address on screen, sec//const int RedPin = 9; // PWM output pin for Red Light.
//const int GreenPin = 6; // PWM output pin for Green Light.
//const int Pin = 5 ; // PWM output pin for LED Light.
//const int dmxaddress =1;
//const int RFChannel =115;boolean setaddr=false, // DMX process/set address flag
btn_up=true, // button flags
btn_down=true,
btn_set=true,
btn_mode=true;
unsigned long last_btn; // buttons press timestamps
// last_disp=millis(); // last screen update timestamp
byte ticks, // movement buttons handled actions
deltadmx; // movement step
int dmxaddr=1, // DMX address
mult=0; // all channels light multiplicator
uint8_t dmxh,dmxl; // EEPROM DMX record
int8_t brightness=2; // screen brightness levelvoid dmxdisp(){
int tmp; // temp
int8_t digit[3]; // address output
tmp=dmxaddr-(dmxaddr%100);
digit[0]=tmp/100;
tmp=dmxaddr-(dmxaddr%10)-(digit[0]*100);
digit[1]=tmp/10;
digit[2]=dmxaddr-(digit[0]*100)-(digit[1]*10);
if(setaddr){
tm1637.display(0,0x0A); // setup address
tm1637.display(1,digit[0]);
tm1637.display(2,digit[1]);
tm1637.display(3,digit[2]);
}else{
tm1637.display(1,digit[0]); // display address
}void processmovestep(){
ticks++;
if(ticks>10) deltadmx=10; // increase step
if(ticks>20) deltadmx=50;
if(ticks>30){ // reset step
deltadmx=1;
ticks=0;
dmxdisp();
}RF24 radio(9,10); /* Creating instance 'radio' ( CE , CSN ) CE -> D9 | CSN -> D10 /
//const byte Address[6] = " 00009 " ; / Address to which data to be transmitted*/
const uint64_t pipe = 0xE8E8F0F0E1LL;
//int data;//int value1=DMXSerial.read(dmxaddr);
//int value2=DMXSerial.read(dmxaddr+1);//int value[2];
int data[2];
void setup () {
pinMode(SETPIN,INPUT_PULLUP); // init input key pins
pinMode(MODEPIN,INPUT_PULLUP);
pinMode(UPPIN,INPUT_PULLUP);
pinMode(DOWNPIN,INPUT_PULLUP);
tm1637.init(); // LDM init
tm1637.set(brightness);
DMXSerial.init(DMXReceiver);
SPI.begin();
dmxh=EEPROM.read(0x00); // restore DMX
dmxl=EEPROM.read(0x01);
if(dmxh!=0xFF) dmxaddr=(dmxh*256)+dmxl;
dmxdisp();radio.begin (); /* Activate the modem*/
radio.openWritingPipe (pipe); /* Sets the address of transmitter to which program will send the data */
//radio.setChannel(RFChannel);
radio.setPALevel(RF24_PA_HIGH);
radio.setDataRate(RF24_250KBPS);
radio.stopListening();// set some default values
//DMXSerial.write(1, 80);
//DMXSerial.write(2, 0);
//DMXSerial.write(3, 0);// enable pwm outputs
//pinMode(RedPin, OUTPUT); // sets the digital pin as output
//pinMode(GreenPin, OUTPUT);
// pinMode(Pin, OUTPUT);
}void loop() {
// Calculate how long no data backet was received
radio.stopListening ();
if(setaddr){
if(btn_up && btn_down && btn_set && btn_mode){ // read movement keys from idle mode
btn_up=digitalRead(UPPIN);
btn_down=digitalRead(DOWNPIN);
btn_set=digitalRead(SETPIN);
btn_mode=digitalRead(MODEPIN);
last_btn=millis();
ticks=0;
deltadmx=1;
if(!btn_up && !btn_down) btn_down=true;
if(!btn_mode){ // back to DMX process mode
btn_mode=true; // change mode
setaddr=false;
tm1637.init(); // reset screen
dmxdisp();
if(!btn_set){ // store DMX
if(dmxaddr>255){
if(EEPROM.read(0x00)!=0x01) EEPROM.write(0x00,0x01);
dmxl=dmxaddr-256;
}else{
if(EEPROM.read(0x00)!=0x00) EEPROM.write(0x00,0x00);
dmxl=dmxaddr;
if(EEPROM.read(0x01)!=dmxl) EEPROM.write(0x01,dmxl);
btn_set=true; // change mode
setaddr=false;
dmxdisp();
if(!btn_up) btn_up=digitalRead(UPPIN); // read movement keys from moving mode
if(!btn_down) btn_down=digitalRead(DOWNPIN);
if(!btn_up && millis()-last_btn>=KEYSPEED){ // move DMX up
last_btn=millis();
dmxaddr+=deltadmx;
if(dmxaddr>512) dmxaddr=1;
processmovestep();
if(!btn_down && millis()-last_btn>=KEYSPEED){ // move DMX down
last_btn=millis();
dmxaddr-=deltadmx;
if(dmxaddr<1) dmxaddr=512;
processmovestep();
}else{
if (digitalRead(MODEPIN)==0){ // вход в установку адреса
setaddr=true; // флаг установки адреса
tm1637.init(); // очистка дисплея
delay(200); // задержка
dmxdisp(); // переход к функции dmxdisp
//seting_address(); // переход к функции seting_adres
else{
byte data[2];
//value[1] = map (DMXSerial.read(dmxaddr), 0, 1023, 0, 255);
//value[2] = map (DMXSerial.read(dmxaddr+1), 0, 1023, 0, 255);
//data[0] = map (DMXSerial.read(dmxaddr), 0, 1023, 0, 255);
//data[1] = map (DMXSerial.read(dmxaddr+1), 0, 255, 0, 1024); // convert 8bit DMX to 10bit
data[0] = DMXSerial.read(dmxaddr);
data[1] = DMXSerial.read(dmxaddr+1);
//data[2] = DMXSerial.read(dmxaddr+2);radio.stopListening ();
unsigned long lastPacket = DMXSerial.noDataSince();
//int DMXvalue1 = DMXSerial.read(1);
//analogWrite(Pin, DMXvalue1);
radio.write(&data, sizeof(data));
// End.
