DMX library for Arduino WIFI MKR1010
Hey folks!
I want to control my Arduino WIFI MKR1010 via a DMX setup, however most of the common DMX Librarys do not work for this Arduino. I read some articles that suggest it might be related to another type of chip used for the Arduino WIFI. The error code states that the "avr/io.h" file does not exist.
Do you know any other DMX Librarys (only to receive) a DMX Signal with a RS485 Shield? So far DMXSerial.h and ArdunoDMX for example do not work.
I have tried a workaround without a library, however this code does not work, do you know why?
Thanks for your help in advance :slight_smile:
#define DMX_SERIAL Serial
#define LED_PIN1 1
#define LED_PIN2 2
  pinMode(LED_PIN1, OUTPUT);
  pinMode(LED_PIN2, OUTPUT);
  DMX_SERIAL.begin(250000);
  if (DMX_SERIAL.available() > 0) {
    int startByte = DMX_SERIAL.read();
    if (startByte == 0x00) {
      for (int i = 1; i <= 192; i++) {
        int value = DMX_SERIAL.read();
        if (i == 8 && value > 100) {
            digitalWrite(LED_PIN1, HIGH);
            digitalWrite(LED_PIN2, LOW);
            digitalWrite(LED_PIN1, LOW);
            digitalWrite(LED_PIN2, HIGH);
I moved your topic to an appropriate forum category @alex_artox.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
