I know this isn't really Arduino-related, as I'm using a ESP8266 with CH320G.
Here's my code:
const int LED = D7;
const int button1 = D1;
const int button2 = D2;
pinMode(LED, OUTPUT);
pinMode(button1, INPUT_PULLUP);
pinMode(button2, INPUT_PULLUP);
if(digitalRead(button1) == 0 ){
digitalWrite(LED, LOW);
if(digitalRead(button2) == 0 ){
digitalWrite(LED, HIGH);
Do I put the buttons to make contact from + or - to their pins?
Thanks
PaulRB
2
Connect the buttons from the pins to ground.
It's more correct to put
if(digitalRead(button1) == LOW )
because on this page
it says
Returns
HIGH or LOW
xfpd
3
Keep the INPUT_PULLUP setting, which will have D1 as HIGH when the button is NOT pressed
Change the "if" condition from 1 to 0 (HIGH is NOT pressed, LOW is PRESSED).
Wire your button from the PIN to the open side of the BUTTON to GROUND.
| D1|--|BUTTON1|-+
| GND|------------+
When the button is pressed, the state of D1 will change from HIGH (not pressed) to LOW (pressed).
