Hello I'm trying to use Arduino Nano 33 BLE Sense REV2 to make Smart Glasses and I can't use a breadboard so can I use just a GND pin and SW pin?
Thanks,
zm476
Thanks,
zm476
The SW connections on a rotary encoder can be used like any other switch.
Yes but I dson't have any other switch and will it work without the 5v pin
Set the input pin that the SW terminal to pinMode INPUT_PULLUP. Connect the com termial to ground. There is then no need for 5V to the encoder.
Switch pin will read HIGH when not pressed and LOW when pressed.
Okay thanks
