Does anything excluded by #ifdef #ifndef #endif etc. take up memory resources?
Hi, I'm dealing with regular crashes at a certain part of my code.
I did some research and some suggested it might be issues with the serial connection and memory, so I tried to comment out all the debugging information, but this didn't cause any joy.
// #define DEBUG
// Scare control UNO
#include <AltSoftSerial.h> // Alt serial library, see library folder in dropbox
#include <Wire.h>
#include <MD_YX5300.h> // See library folder in dropbox
#include <Bounce2.h> // For debouncing button input. See https://github.com/thomasfredericks/Bounce2
// Tunable variables - These are so you can sync up sounds and scares easily
// #ifdef DEBUG
// int vaDelay = 5000; // violent attack delay. Debug 5000. Live 60000.
// int cbDelay1 = 5000; // first crying delay. Debug 5000. Live 10000.
// int cbDelay2 = 5000; // second cry delay. Debug 5000. Live  5000.
// int FHdim = 1500; // Time for the spotlight to dim after the MP3 has been triggered
// int FHrelay = 2500; // Time for relay to hit
// int BYdelay1 = 2000; // Time for first behind you after reed trigger
// int BYdelay2 = 4000; // Time for second behind you after first behind you
// int BYflicker1 = 2000; // Time for first flicker pulse
// int BYflicker2 = 3000; // Time for second flicker pulse
// int fadeAmount = 5;  // how many points to fade the spotlight by
// int fadeinTime = 50; // how quickly to fade the spotlight up (this is slower)
// int fadeoutTime = 20; // how quickly to fade the spotlight up (this is quick)
// int postScareTime = 5000;
// #endif
//#ifndef DEBUG
// int vaDelay = 45000; // violent attack delay. Debug 5000. Live 60000.
// int cbDelay2 = 1000; // second cry delay. Debug 5000. Live  5000.
int FHdim = 1000; // Time for the spotlight to dim after the MP3 has been triggered
int FHrelay = 2200; // Time for relay to hit
int FYflicker = 50; // Time for the flicker to pulse after facehugger has dropped
// int BYdelay1 = 120000; // Time for first behind you after reed trigger
int BYdelay2 = 20000; // Time for second behind you after first behind you
int fadeoutTime = 10; // how quickly to fade the spotlight up (this is quick)
int postScareTime =2500;
// #endif
// Input pins
int hiss = 12; // Yellow cable connected to office
int hissSelect = 0; // Number to cycle which hiss mp3 to select
int flicker = 6; // Orange cable connected to office
int exhale = 10; // White cable connected to office
int baby = 11; // Yellow cable connected to office
// Output pins
int megaFlicker = A5; // THIS IS NOW ATTACHED TO A red LED
// int megavolumeDown = 2;
// Input triggers
int circsqtriPin = A0; // CHANGED Trigger for 1612 and starts violet attack countdown
int circsqtriLev;
int rfidPin = A1; // CHANGED Trigger the facehugger sequence
int rfidLev;
int jump7Pin= A2; // CHANGED Trigger the window opening sounds
int jump7Lev;
int reedPin = A3; // CHANGED Trigger any behind you sequence
int reedLev;
int plugPin = A4; // Trigger the scare
// int ultrasoundPin = 7;
int threshold = 800; // Threshold for detecting the LED flashes
// Pins for scare switch
int scareSwitch = 13; // This is pulled low when scares are being turned on.
int switchState; //
bool scaresOn = false; // bool to keep track of if scares are on
int switchBuffer = 0; // a buffer to help with switch interference.
int bufferThreshold = 500; // threshold to control how much interference is allowed. More sensitive = smaller number.
// Utility
int spotlight = 5; // PWM pin to control the brightness of the light
int spotlightDelay = 0; // Counter to keep track of the delay for the spotlight
int spotlightThreshold = 9000; // Threshold for when to turn on the spotlight
bool spotlightOn = false; // Bool to ensure that the spotlight turns on only once
int brightness = 0;  // how bright the spotlight is
int lightRelay = 3; // Relay attached to light NO is floor NC is hand
int facehuggerRelay = 4; // Relay to release the facehugger scare
bool plugState = false; // Keeps the "waiting for plug" loop going
bool plugConnected; // Bool to test if the plug is connected and warn the user if it is
// GLOBALS
// Create an array of Bounce objects for each input button
//Bounce circsqtriSwitch = Bounce();
//Bounce reedSwitch = Bounce();
//Bounce rfidSwitch = Bounce();
//Bounce jump7Switch = Bounce();
Bounce plugSwitch = Bounce();
//Bounce ultrasoundSwitch = Bounce();
Bounce hissSwitch = Bounce();
Bounce exhaleSwitch = Bounce();
Bounce babySwitch = Bounce();
Bounce flickerSwitch = Bounce();
// Initialise a software serial interface on the approriate Rx/Tx pins (8/9)
AltSoftSerial altSerial;
// And create an MP3 object based on the serial connection
MD_YX5300 mp3(altSerial);
  delay (1000);
  // Initialise a serial connection (used for debugging only)
  Serial.println(__FILE__ __DATE__);
  Serial.println("Serial connection initialised");
  Serial.println ("Setup 2 begun, buffer initiated");
  delay (5000);
  Serial.println ("Buffer 2 complete");
  //reedSwitch.attach(reedPin, INPUT_PULLUP); // REED
  //rfidSwitch.attach(rfidPin, INPUT_PULLUP); // DOOR
  //circsqtriSwitch.attach(circsqtriPin, INPUT_PULLUP);// 16
  //jump7Switch.attach(jump7Pin, INPUT_PULLUP); // J7
  plugSwitch.attach(plugPin, INPUT_PULLUP);
  // ultrasoundSwitch.attach(ultrasoundPin, INPUT_PULLUP);
  // Changes adding the LDRs
  pinMode(reedPin, INPUT);
  pinMode(rfidPin, INPUT);
  pinMode(circsqtriPin, INPUT);
  pinMode(jump7Pin, INPUT);
  hissSwitch.attach(hiss, INPUT_PULLUP);
  flickerSwitch.attach(flicker, INPUT_PULLUP);
  exhaleSwitch.attach(exhale, INPUT_PULLUP);
  babySwitch.attach(baby, INPUT_PULLUP);
  Serial.println("Utility buttons initialised");
  // Scare mode?
  pinMode (scareSwitch, INPUT_PULLUP);
  switchState = digitalRead(scareSwitch);
  Serial.println(switchState);
  // Initialise pins and test
  pinMode(megaFlicker, OUTPUT); // Because this is the LED
  digitalWrite(megaFlicker, LOW); // Make sure it's not on
  //pinMode(megavolumeDown, OUTPUT);
  pinMode(spotlight, OUTPUT);
  pinMode(facehuggerRelay, OUTPUT);
  digitalWrite(facehuggerRelay, LOW);
  pinMode(lightRelay, OUTPUT);
  digitalWrite (lightRelay, HIGH);
  // Test
  // Initialise the serial interface to the MP3 player
  altSerial.begin(9600);
  mp3.begin();
  mp3.volume(30);
  if (switchState == 0){
    scaresOn = true;
    Serial.print(switchState);
    mp3.playTrack(1); // "Horror mode is turned on"
    Serial.println ("Horror mode is turned ON");
  else {
    scaresOn = false;
    mp3.playTrack(2); // "Horror mode is turned off"
    Serial.println ("Horror mode is turned OFF");
  delay(3000);
  plugConnected = digitalRead(plugPin);
  Serial.print ("plugConnected is ");
  Serial.println(plugConnected);
  if (plugConnected == 0)
   mp3.playTrack(14); // Alien hiss
    mp3.playTrack(11); // Exhale
  delay(5000);
  Serial.println("Setup complete");
    scaresOn = true;
    // Serial.println("SPOOKY");
    switchBuffer = 0;
  if (switchState != 0) {
    switchBuffer++;
//    Serial.print(switchBuffer);
//    Serial.println("Safe");
    if(switchBuffer > bufferThreshold)
      scaresOn = false;
  // reedSwitch.update();
  // rfidSwitch.update();
  // circsqtriSwitch.update();
  // jump7Switch.update();
  // ultrasoundSwitch.update();
  // Read the light levels
  circsqtriLev = analogRead (circsqtriPin);
  rfidLev = analogRead (rfidPin);
  jump7Lev = analogRead (jump7Pin);
  reedLev = analogRead (reedPin);
  // Print the light levels
//  Serial.print(circsqtriLev);
//  Serial.print("\t");
//  Serial.print(rfidLev);
//  Serial.print(jump7Lev);
//  Serial.print(reedLev);
//  Serial.println("\t");
  // Update the manual switches
  hissSwitch.update();
  flickerSwitch.update();
  exhaleSwitch.update();
  babySwitch.update();
  // Now run through the statements to detect changes
  //if(circsqtriSwitch.fell())
  if (circsqtriLev>threshold)
    Serial.println("1612 complete");
    violentAttack();
  //if(rfidSwitch.fell())
  if (rfidLev>threshold)
    Serial.println("rfid complete");
    if (scaresOn == true)
      Serial.println("SCARES ARE ON");
      jumpScare();
      Serial.println("SCARES ARE OFF");
      noScare();
  //if(jump7Switch.fell())
  if (jump7Lev>threshold)
    Serial.println("jump7 complete");
    cryBabies();
  //if(reedSwitch.fell())
  if (reedLev>threshold)
    Serial.println("reed complete");
    behindYou();
  if(flickerSwitch.fell())
    Serial.println("flicker");
      sendFlicker();
  if(babySwitch.fell())
    Serial.println("baby");
      mp3.playTrack(10);
  if(hissSwitch.fell())
    Serial.println("hiss");
      whataHisser();
  if(exhaleSwitch.fell())
    Serial.println("exhale");
      mp3.playTrack(11);
void violentAttack()
  Serial.println("in function violentAttack");
    Serial.println("playing violent attack");
    delay(45000);
    Serial.println("delay done");
    mp3.playTrack(3);
  Serial.println("returning to loop");
  return;
void jumpScare()
  Serial.println("in jumpScare");
  digitalWrite(lightRelay, LOW);
  mp3.playTrack(7); // Containment cell access granted, warning eteenfeijnfei
  do
    plugSwitch.update();
    spotlightDelay ++;
    // Serial.print("Spotlight delay is ");
    // Serial.println(spotlightDelay);
    if ((spotlightDelay == spotlightThreshold) && (spotlightOn == false))
      mp3.playTrack(6); // Facehugger cry
      // Serial.println ("Facehugger crying");
      brightness = 0;
      do
        analogWrite(spotlight, brightness); // Set current brightness
        // Serial.println (brightness);
        brightness = brightness + fadeAmount; // Increase brightness
        delay(fadeinTime);
      while (brightness <= 225); // Till brightness maxed
      analogWrite(spotlight,225);
      spotlightOn = true;
    if(plugSwitch.fell())
      Serial.println("plug connected");
      mp3.playTrack(9); // Facehugger strike begins
      delay(FHdim); // Delay a bit so people can react to the sound
      do
        //Serial.println (brightness);
        brightness = brightness - fadeAmount; // Decrease brightness
        delay(fadeoutTime);
      while (brightness >= 0); // Till brightness at minimum
      analogWrite(spotlight, 0);
      delay(FHrelay);
      digitalWrite (facehuggerRelay, HIGH);
      delay(300);
      plugState = true;
      delay(2500);
      sendFlicker();
  while (plugState == false);
void noScare()
  Serial.println ("in noScare");
  // mp3.playTrack(8); // THIS IS BROKEN FOR SOME REASON
  return;
void cryBabies ()
    delay(cbDelay1);
    mp3.playTrack(5);
    delay(20000);
    mp3.playTrack(4);
    return;
void behindYou()
  if(scaresOn == true)
    mp3.volume(25);
    delay (100000);
    mp3.playTrack(12);
    delay (BYdelay2);
    sendFlicker();
    delay (BYflicker1);
    mp3.playTrack(13);
    delay (BYflicker2);
    sendFlicker();
    return;
void spotlightOff()
  do
    delay(fadeoutTime);
  return;
void whataHisser()
    // Serial.print ("hissSelect is ");
    // Serial.println (hissSelect);
	  // Serial.println("Debug pause");
	  delay(5000);
  if (hissSelect == 0)
    mp3.playTrack(14);
    hissSelect=1;
  else if (hissSelect == 1)
    mp3.playTrack(15);
    hissSelect=2;
  else if (hissSelect == 2)
    mp3.playTrack(16);
    hissSelect=0;
void sendFlicker()
    digitalWrite(megaFlicker, HIGH);
    delay(200);
    mp3.playTrack(18);
The program properly executes properly, but when it moves into jumpScare() (below) it only works until a relay triggers a mag lock to release a prop from the ceiling, but doesn't then execute sendFlicker() and resets the program, running through the setup. Here's the relevant parts of the code;
void jumpScare()
  do
    spotlightDelay ++;
      brightness = 0;
      do
        delay(fadeinTime);
      spotlightOn = true;
      do
        delay(fadeoutTime);
      delay(FHrelay);
      delay(300);
      plugState = true;
      delay(2500);
      sendFlicker();
void sendFlicker()
    delay(200);
    mp3.playTrack(18);
Can anyone suggest why it is resetting? I'm thinking it could also be a power issue and I might have better luck giving the UNO it's own power supply? (currently it shares a power supply with other components and microcontrollers, but I'm pretty sure the rated current isn't being exceeded)
Screenshot of the layout (sorry this is poorly organised, I've been adding and taking away from this for a while now trying to keep track of this thing)
It's pretty much indecipherable, like one of those mazes from a puzzle magazine. Can you post a schematic?
What memory usage stats do you see when you compile the code?
Power or circuit design problem. Unfortunately the wiring diagram is incomprehensible.
Get the relay/mag lock working on its own before adding it to the rest of the project.
if you are concerned about memory you should read about the Arduino F-Makro and apply it for printing fix text to Serial, LCD and similar objects which inherit from Print.h
I don't know why I didn't think of this
"Sketch uses 8210 bytes (25%) of program storage space. Maximum is 32256 bytes.
Global variables use 1219 bytes (59%) of dynamic memory, leaving 829 bytes for local variables. Maximum is 2048 bytes."
Seems there's plenty of leftover memory
Yes, you're correct, it's a monstrosity that has evolved over the past year as I've added fixes and functionality. I'm an amateur at this trying to save money by keeping the number of microcontrollers low. Its caused me more problems than money saved I am now realising.
When you say "power coming through the arduino" are you saying a pin might be connected to 5v?
Good shout, will do
"brightness = brightness + fadeAmount; // Increase brightness"
Maybe I'm misunderstanding your question
I did this so I could tweak how quickly the led comes on (it slowly lights up an alien in the corner of a dark room)
Some. Not plenty.
The total dynamic memory used can be misleading because it only includes memory known to be allocated before the code starts running. Once the code begins running, more memory can be allocated, and if that takes the total over about 80%, there will be problems.
It's good to see that the total known allocated memory isn't over 80%. But it is almost 60%, so there's not much remaining. If only another 20% is allocated when the code is running, you are in the danger zone.
Reviewing your code again, I can't see anything that would allocate any large amounts of memory when the code is running.
But if you want to try to reduce that 59% down a little to see if it makes any difference, one easy way to do that is to look at all code lines that print to serial monitor like this example:
and change them like this:
Serial.println(F("plug connected"));
That should shave a few % off the allocated dynamic memory.
