Does LED_USER light up?
I got an Arduino Opta.
But LED_USER does not glow. I took it apart, but there doesn't seem to be any LEDs, or maybe it's just me that doesn't have any LEDs.
cir
No LED here, maybe it's a SMD soldering defect:
I don't know, if it should always have that LED you could ask for a replacement but if you pulled it off I suspect you voided the warranty. In this case, just find a small blue LED and solder it there.
Looks like this part:
needs a resistor+LED like this part:
Is there anyone who got Arduino Opta and LED_USER lights up?
As it looks like the LED is intentionally missing, I googled a bit. If you open the Opta tutorial, you'll read this:
LED_USER: LED above the user button (only available on the Opta™ with connectivity features)
I don't know if Opta comes in different versions and why that LED should miss on some (it can't be a matter of costs...), but I now must think your Opta doesn't have those "connectivity features". Check it out.
EDIT: if it was just hardware that's missing, you could solder a resistor and LED, if you're able to do so without damaging the board (I won't be considered responsible for any damage, anyway, do it at your own risk :wink: )
It does:
https://www.arduino.cc/pro/hardware-arduino-opta/#content-page-56029968
  • Opta Lite: with Ethernet onboard and USB-C programming ports (SKU: AFX00003)
  • Opta RS485: which also adds RS485 half duplex connectivity interface (SKU: AFX00001)
  • Opta WiFi: the most versatile option, featuring also Wi-Fi/Bluetooth® Low Energy connectivity (SKU: AFX00002)
In the documentation, the reference diagram for the opta lite version clearly indicate the user_led.
So to me this is a defect.
Regs
I can confirm my Opta does have led user populated. I have an Opta wifi version
Hello!
For further clarification: LED_USER can only be operated with Arduino Opta WiFi (AFX00002).
The pinouts for the other versions will be updated to avoid confusions.
