does not name a type.[ solved]
I have recently purchaced a reflow oven controller shield. I have the very basic experience of programming arduino uno/3, flashing led etc.
after downloading the (proven working software ) for the shield I get the error message PID does not name a type at the following line
PID myPID(&Input, &Output, &Setpoint,2,5,1, DIRECT);
The libraries are present and the include statement does not generate an error.
The include also has the updated Arduino filename. The file extensions also appear to be correct. I am guessing that it may be something to do with libraries as I have not used them yet. AFAICS there is no syntax error. Many other errors but hoping once I understand this one I can fix the rest
tia
Post your code and a link to the library. Also, please tell us where you installed the library.
How to use this forum
Main sketch.
https://github.com/rocketscream/Reflow-Oven-Controller/blob/master/reflowOvenController.ino
Library files.
https://github.com/br3ttb/Arduino-PID-Library/tree/master/PID_v1
https://github.com/rocketscream/MAX31855/blob/master/MAX31855.cpp
These are placed in the arduino/libraries directory.
Did you start the IDE again after doing that?
Post a screenshot showing where the files really are.
PaulS:
No , that problem is now solved.
I now get the same error with MAX31855 thermocouple(thermocoupleSOPin, thermocoupleCSPin,thermocoupleCLKPin);
I only have a.cpp file though, no .h file for this. Is there a faq on library conventions somewhere ?
I am guessing that .h is a compiled .cpp ? I have tried to compile the .cpp as a sketch but it does not work.
Screen shot > working on that.
No. A .h file [u]defines[/u] a class or set of functions. A .cpp file [u]implements[/u] that class or set of functions.
Then the MAX31855 wasn't downloaded/installed correctly.
Post it.
Then the MAX31855 wasn’t downloaded/installed correctly.
Yes the zip file was incomplete.
.h is here
  This is a library for the Adafruit Thermocouple Sensor w/MAX31855K
  Designed specifically to work with the Adafruit Thermocouple Sensor
  ----> https://www.adafruit.com/products/269
  These displays use SPI to communicate, 3 pins are required to
  interface
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
#if (ARDUINO >= 100)
 #include "Arduino.h"
#else
 #include "WProgram.h"
#endif
class Adafruit_MAX31855 {
 public:
  Adafruit_MAX31855(int8_t SCLK, int8_t CS, int8_t MISO);
  double readInternal(void);
  double readCelsius(void);
  double readFarenheit(void);
  uint8_t readError();
 private:
  int8_t sclk, miso, cs;
  uint32_t spiread32(void);
.cpp is here
  interface
#include "Adafruit_MAX31855.h"
#include <avr/pgmspace.h>
#include <util/delay.h>
#include <stdlib.h>
Adafruit_MAX31855::Adafruit_MAX31855(int8_t SCLK, int8_t CS, int8_t MISO) {
  sclk = SCLK;
  cs = CS;
  miso = MISO;
  //define pin modes
  pinMode(cs, OUTPUT);
  pinMode(sclk, OUTPUT);
  pinMode(miso, INPUT);
  digitalWrite(cs, HIGH);
double Adafruit_MAX31855::readInternal(void) {
  uint32_t v;
  v = spiread32();
  // ignore bottom 4 bits - they're just thermocouple data
  v >>= 4;
  // pull the bottom 11 bits off
  float internal = v & 0x7FF;
  internal *= 0.0625; // LSB = 0.0625 degrees
  // check sign bit!
  if (v & 0x800)
    internal *= -1;
  //Serial.print("\tInternal Temp: "); Serial.println(internal);
  return internal;
double Adafruit_MAX31855::readCelsius(void) {
  int32_t v;
  v = spiread32();
  //Serial.print("0x"); Serial.println(v, HEX);
  float internal = (v >> 4) & 0x7FF;
  internal *= 0.0625;
  if ((v >> 4) & 0x800)
    internal *= -1;
  if (v & 0x7) {
    // uh oh, a serious problem!
    return NAN;
  // get rid of internal temp data, and any fault bits
  v >>= 18;
  //Serial.println(v, HEX);
  // pull the bottom 13 bits off
  int16_t temp = v & 0x3FFF;
  // check sign bit
  if (v & 0x2000)
    temp |= 0xC000;
  //Serial.println(temp);
  double centigrade = v;
  // LSB = 0.25 degrees C
  centigrade *= 0.25;
  return centigrade;
uint8_t Adafruit_MAX31855::readError() {
  return spiread32() & 0x7;
double Adafruit_MAX31855::readFarenheit(void) {
  float f = readCelsius();
  f *= 9.0;
  f /= 5.0;
  f += 32;
  return f;
uint32_t Adafruit_MAX31855::spiread32(void) {
  int i;
  uint32_t d = 0;
  digitalWrite(sclk, LOW);
  _delay_ms(1);
  digitalWrite(cs, LOW);
  _delay_ms(1);
  for (i=31; i>=0; i--)
    _delay_ms(1);
    d <<= 1;
    if (digitalRead(miso)) {
      d |= 1;
    digitalWrite(sclk, HIGH);
    _delay_ms(1);
  //Serial.println(d, HEX);
  return d;
Does it compile now that you have the .h file ?
No , I have the same error msg. I have compared it to the pid library which now works but can see no difference in file types/locations.
What exactly are the names of the MAX31855 .h and .cpp files and what is the name of the folder that they are in ?
in libraries/max31855
max31855.h
max31855.cpp
and in libraries/adafruit_max31855
adafruit_31855.h
adafruit_31855.cpp
The most recent ino file from rocketscream at github only seems to reference the max31855 library though.
max31855.h
  interface
#else
#endif
 public:
 private:
max31855.cpp
  interface
#include <stdlib.h>
  sclk = SCLK;
  cs = CS;
  miso = MISO;
  //define pin modes
  uint32_t v;
  v = spiread32();
  v >>= 4;
  // check sign bit!
  if (v & 0x800)
    internal *= -1;
  return internal;
  int32_t v;
  v = spiread32();
  internal *= 0.0625;
    internal *= -1;
  if (v & 0x7) {
    return NAN;
  v >>= 18;
  // check sign bit
  if (v & 0x2000)
    temp |= 0xC000;
  centigrade *= 0.25;
  return centigrade;
  f *= 9.0;
  f /= 5.0;
  f += 32;
  return f;
  int i;
  uint32_t d = 0;
  _delay_ms(1);
  _delay_ms(1);
    _delay_ms(1);
    d <<= 1;
      d |= 1;
    _delay_ms(1);
  return d;
I have tried going through the ino file and changing MAX31855.h to adafruit_MAX31855.h but to no avail.
all the above came in the same zip file and are said to work together.
ok
Now I read my last post and understand. The ino uses the max31855 library but the one I have appears to be a renamed copy of the addafruitmax31855 library. I would have spotted this much earlier but the ide will not open cpp or h files and my text editor would not display the properly,cr/lf missing causes the file to be displayed as one line.
I was using notepad, any suggestions ?
notepad++
http://notepad-plus-plus.org/download/v6.3.2.html
Awesome program and free!
Another vote for Notepad++ It can be set to understand C++ source files so that functions and for/while loops etc are recognised and highlighted and can be collapsed to make better use of screen space.
Very nice to use
Many thanks. That looks to be an excellent editor.
Found the libraries now and compiles, however I now get
avrdude: stk500_getsync(): not in sync: resp=0x00
Thos is a uno and not a mega, I have previously run small sketches though. Should I be starting a new topic for this ?
Have you changed the target Arduino in the IDE ?
Do you have the right board selected under 'Tools'?
Edit: Bob beat me to it.
yes i remebered this particular machine has a history of flaky usb behavior, borrowed a laptop and it worked ok.
