does random() not generate decimals?
hello,
been trying to get a fairly simple RNG up and running.
Currently I need to generate 2 random numbers. The 1st should ideally be an int between 1 and 7, inclusive. The 2nd should be a float (with random decimals!) between 0.01 and 4.00 (ex. 2.76, 3.01, 0.44, etc), also inclusive.
I'm not sure what the problem is, but I cannot get random() to generate decimals for the 2nd value. in the serial monitor, the float is always y.00.
float x;
float y;
int z;
  randomSeed(analogRead(0));
    x = random(1, 8);
    y = random(0.01, 5);
    z = (int)x;
    Serial.println(z);
    Serial.println(y);
So my question is:
How do I get random() (or some function) to generate random decimals??
any help would be greatly appreciated!
Create the decimal by generating a random number between 0-99
Divide by 100.
Add it to a random integer number.
Why not just divide the random number by something? That will generate the integer and fraction in one step.
   y = random(1, 500) / 100.0
Just in case you wanted the decimal part to do something else with it.
I did not think about your method :wink:
  y = random(1, 401) / 100.0
:wink:
How many decimals do you need?
Or better, how many different values between 0.01 and 4.00 do you want?
100? 1000? 1 million? more?
The code below will give for datatype float all or almost all possible values,
and for datatype double it will give some 2billion++ different values.
//    FILE: randomDouble.ino
//  AUTHOR: Rob Tillaart
// VERSION: 0.1.00
// PURPOSE: demo
//    DATE: 2016-01-13
//     URL: http://forum.arduino.cc/index.php?topic=371564.0
// Released to the public domain
  Serial.print("Start ");
  Serial.println(__FILE__);
double randomDouble(double minf, double maxf)
  return minf + random(1UL << 31) * (maxf - minf) / (1UL << 31);  // use 1ULL<<63 for max double values)
  Serial.println(randomDouble(0.01, 4.00), 8);
have fun!
