Does SPIFFS resulted ESP32 repeated restarts?
Hi everyone.
this is a simple sketch that should just list the files in SPIFFS, but it repeated list and restarts ? why?
Thanks
Adam
#include "SPIFFS.h"
void listAllFiles(){
  File root = SPIFFS.open("/");
  File file = root.openNextFile();
  while(file){
      Serial.print("FILE: ");
      Serial.println(file.name());
  if (!SPIFFS.begin(true)) {
    Serial.println("An Error has occurred while mounting SPIFFS");
    return;
  File file = SPIFFS.open("/test.txt", FILE_WRITE);
  if (!file) {
    Serial.println("There was an error opening the file for writing");
    return;
  if (file.print("some content")) {
    Serial.println("File was written");
    Serial.println("File write failed");
  file.close();
  Serial.println("\n\n---BEFORE RENAMING---");
  listAllFiles();
  SPIFFS.rename("/test.txt", "/renamed.txt");
  Serial.println("\n\n---AFTER RENAMING---");
  listAllFiles();
void loop() {}
ERROR:
12:49:57.010 -> ELF file SHA256: 0000000000000000
12:49:57.010 ->
12:49:57.010 -> Rebooting...
12:49:57.010 -> ets Jul 29 2019 12:21:46
12:49:57.010 ->
12:49:57.010 -> rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
12:49:57.010 -> configsip: 0, SPIWP:0xee
12:49:57.010 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
12:49:57.010 -> mode:DIO, clock div:2
12:49:57.010 -> load:0x3fff0030,len:1344
12:49:57.010 -> load:0x40078000,len:13836
12:49:57.010 -> load:0x40080400,len:3608
12:49:57.010 -> entry 0x400805f0
12:49:57.247 -> File was written
12:49:57.247 ->
12:49:57.247 ->
12:49:57.247 -> ---BEFORE RENAMING---
12:49:57.315 -> FILE: hello.txt
12:49:57.349 -> FILE: renamed.txt
12:49:57.349 -> FILE: test.txt
12:49:57.383 ->
12:49:57.383 ->
12:49:57.383 -> ---AFTER RENAMING---
12:49:57.485 -> FILE: hello.txt
12:49:57.485 -> FILE: renamed.txt
12:49:57.485 -> FILE: test.txt
They could, depending upon your partition scheme.
Did you put the debug info into the ESP Exception Decoder and post the results here?
did you try this
#include "SPIFFS.h"
  while(file){
    return;
  //File file = SPIFFS.open("/test.txt", FILE_WRITE);
  //if (!file) {
  //  Serial.println("There was an error opening the file for writing");
   // return;
  //if (file.print("some content")) {
   // Serial.println("File was written");
  //} else {
    //Serial.println("File write failed");
  //file.close();
//  Serial.println("\n\n---BEFORE RENAMING---");
 // listAllFiles();
 // SPIFFS.rename("/test.txt", "/renamed.txt");
//  Serial.println("\n\n---AFTER RENAMING---");
  //listAllFiles();
void loop() {}
Did it work?
then try this
#include "SPIFFS.h"
  while(file){
    return;
  //if (!file) {
   // return;
  //} else {
  //file.close();
 // listAllFiles();
  //listAllFiles();
void loop() {}
If that worked did you try this
#include "SPIFFS.h"
  while(file){
    return;
  if (!file) {
   // return;
  //} else {
  //file.close();
 // listAllFiles();
  //listAllFiles();
void loop() {}
? did it work?
You caught on to what I'm doing?
Thank you Idahowalker.
I tested the first sketch and got that rebooting again.
the Exception Decoder debug info:
0x400833d5: panic_abort at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp_system/panic.c line 402
does this reboot?
#include "SPIFFS.h"
//void listAllFiles(){
//  File root = SPIFFS.open("/");
 // File file = root.openNextFile();
 // while(file){
    //  Serial.print("FILE: ");
//      Serial.println(file.name());
  //    file = root.openNextFile();
  //Serial.begin(115200);
  //if (!SPIFFS.begin(true)) {
  //  Serial.println("An Error has occurred while mounting SPIFFS");
  //  return;
  //if (!file) {
   // return;
  //} else {
  //file.close();
 // listAllFiles();
  //listAllFiles();
void loop() {}
still.
disconnect everything but power/gnd. upload a blank sketch. does it reboot? If you post an image of your project wall wired up and not working.
Thanks.
a blank sketch still rebooting.
nothing wiring on, just USB power cable, and also tried extra 5V/GND to Vin/GND some time.
uploaded example Blink with LED redefine to 2 works well, without reboot.
Maybe try this
#include "SPIFFS.h"
    Serial.println("ERROR");
    return;
  SPIFFS.remove("/renamed.txt");
Great!
Sorry, this sketch works well itself.
made rebooting again when moved to the post#1 sketch. actually added the line: SPIFFS.remove("/renamed.txt");
