JeromeAriola:
I have some LM1117 3v3 regulators sitting in my Robotics lab at school and since I asked if the amount of F matters, can i just run around the class, pick two caps and put it in a circuit with the regs?
The datasheet for those says that two caps must be used -- it says one 0.1uF and the other 10uF. But are tjose values saying I need at least those values? Like in order for the regs to work, I need caps that exceed those vals?
Choosing capacitors is different from something like choosing resistors, in which case crossing on with higher ohms will weaken your volts, I assume.
Regulators are picky about the specifics of the cap used - I'd never just seat-of-the-pants' it like one typically does for picking caps for extra power supply filtering; the 1117 regs, which are made by everyone with a semiconductor foundry, while pin-compatible, do NOT have the same requirements for external caps (surprisingly)
The datasheet I am looking at for the Texas Instruments LM1117 specs a 10uF tant on the input and output; while their app notes show 10uF tant on input, and often a 100uF electrolytic on the output, and they have a minimum ESR spec on the output cap (so you can't use cheap abundant non explosive (tants have a - somewhat undeserved - reputation for exploding) ceramic caps).
On the other hand, the ZLDO1117 (From Diodes Inc - also the best of the 1117 regs) wants 4.7uF ceramic or tant on the output and input.
Some only spec a 0.1 on input (though you should put a larger one in parallel with that if wires from the power supply to the regulator are long)
Different regulators have different requirements, and they are often rather picky - those values are necessary to meet the specs in the datasheet - depending on the regulator and how inappropriate the caps are, incorrect caps can either result in worse transient response, more noise, or the output voltage oscillating. The capacitance requirement is a minimum (within reason), but the capacitor type (or ESR) requirement is no joke.
