Does the Portenta H7 5V pin work with a 3.7 V battery?
Hello,
i want to know when the board Portenta H7 is powered only by a Lipo 3.7V battery does the 5V pin still deliver 5V ?
Because i'm planning on putting the board into a box I don't want to use extra hardware so as not to take up too much space.
Thanks .
No!
is this the case even when using the 3 pin port dedicated to a battery?
To get 5V out of a 3.7 battery, you need a "boost converter" which I believe the Portenta does not have.
Correct, even when using that connector, or any connector! The 5V pin is connected to a step down regulator and nothing else.
Ok, thank you for your answers.
I thought the Portenta had a built-in boost converter.
Thanks you for clarifying this point
