Can someone please explain what is happening here?
Whenever I manipulate any bit in the ADCSRA register using bitmask, the interrupt flag gets reset to 0.
Datasheet states that the only way to reset the flag is to write a 1 to it.
Moreover. If I rewrite the entire register without bitmask, the interrupt flag remains.. as it should.
The only thing I can think of is that during the process of bitmasking operation the entire register is written with ones.... thus resetting the interrupt flag. Is that true? I don't think so.
So what is the explanation?
See the sketch below.
Serial.begin(57600);
Serial.print("ADCSRA Before aRead = ");Serial.println(ADCSRA,BIN);
Serial.print("analogRead(A0) = ");Serial.println(analogRead(A0));
Serial.print("ADCSRA AFTER aRead = ");Serial.println(ADCSRA,BIN);
Serial.println("NOTICE interrupt flag (bit 4) is set.");
Serial.println("Flag should remain set forever or until a binary 1 is written to it.");
Serial.println("Now....let's turn off one bit (bit0) using bit mask MASK");
Serial.println("ADCSRA &= ~(bit(ADPS0)) Turn off ONLY |ADPS0|");
ADCSRA &= ~(bit(ADPS0));
Serial.print("ADCSRA AFTER bit0 is turned off = ");Serial.println(ADCSRA,BIN);
Serial.println("NOTICE bit0 was turned off BUT interrupt flag was ALSO RESET... WHY??.");
Serial.println("Let's try doing aRead and then directly turning off a bit");
Serial.println("by rewriting the entire register");
Serial.println("Now....let's turn off one bit (bit1) using bit mask MASK");
Serial.println("ADCSRA=0b10000100");
ADCSRA=0b10000100;
Serial.print("ADCSRA AFTER bit1 is turned off = ");Serial.println(ADCSRA,BIN);
Serial.println("NOTICE bit1 was turned off BUT interrupt flag REMAINS SET AS IT SHOULD");
Serial output:
ADCSRA Before aRead = 10000111
analogRead(A0) = 389
ADCSRA AFTER aRead = 10010111
ADCSRA AFTER bit0 is turned off = 10000110
ADCSRA Before aRead = 10000110
analogRead(A0) = 384
ADCSRA AFTER aRead = 10010110
ADCSRA=0b10000100
ADCSRA AFTER bit1 is turned off = 10010100
