Does WiFiNINA.h have a problem with WiFi.begin()?
Apple Mac OS
Arduino IDE 2.2.1,
Arduino Uno WiFi rev 2,
Arduino Motor Shield rev3
WiFiNINA.h version 1.8.14
Please take a look at the following, pretty much identical, files, and their respective outputs;
Program 1:
#include <WiFiNINA.h>
#define STD_WiFiBegin_Delay 10000
//char ssid = "abc";
//char wifiPassword = "12345";
  Serial.println("entering clientConnect.ino");
  Serial.print("pre-network scan= ");
  Serial.print(millis());
  Serial.println(" milliseconds");
  Serial.print("number of networks scanned = ");
  Serial.println(WiFi.scanNetworks());  //Scans for available WiFi networks and returns the discovered number
      /*Syntax
          WiFi.scanNetworks()
        Parameters
          None
        Returns
          byte : number of discovered networks
  Serial.print("Pre WiFi.begin  ");
    WiFi.begin("abc", "12345");
    //WiFi.begin(ssid, wifiPassword);
    /*Initializes the WiFiNINA library’s network settings and provides the current status.
      (Apparently it does not create the IP connection.)
      Syntax
        WiFi.begin(ssid);
        WiFi.begin(ssid, pass);
        WiFi.begin(ssid, keyIndex, key);
      Parameters
        ssid: the SSID (Service Set Identifier) is the name of the WiFi network you want to connect to.
        keyIndex: WEP encrypted networks can hold up to 4 different keys. This identifies which key you are going to use.
        key: a hexadecimal string used as a security code for WEP encrypted networks.
        pass: WPA encrypted networks use a password in the form of a string for security.
      Returns
        WL_CONNECTED when connected to a network
        WL_IDLE_STATUS when not connected to a network, but powered on
  delay(STD_WiFiBegin_Delay);
  Serial.print("clientConnect.ino  Post WiFi.begin  ");
  //Serial.print("number of networks scanned = ");
  //Serial.println(WiFi.scanNetworks());  //Scans for available WiFi networks and returns the discovered number
      /*Syntax
          WiFi.scanNetworks()
        Parameters
          None
        Returns
  while (WiFi.status() != WL_CONNECTED) {//Return the connection status
  //                                  || !delay10sTimer.check()
    /* WL_CONNECTED(3): assigned when connected to a WiFi network;
    WL_AP_CONNECTED(8): assigned when a device is connected in Access Point mode;
    WL_AP_LISTENING(7): assigned when the listening for connections in Access Point mode;
    WL_NO_SHIELD(255): assigned when no WiFi shield is present;
    WL_NO_MODULE(255): assigned when the communication with an integrated WiFi module fails;
    WL_IDLE_STATUS(0): it is a temporary status assigned when WiFi.begin() is called and
                    remains active until the number of attempts expires (resulting
                    in WL_CONNECT_FAILED) or a connection is established (resulting in WL_CONNECTED);
    WL_NO_SSID_AVAIL(1): assigned when no SSID are available;
    WL_SCAN_COMPLETED(2): assigned when the scan networks is completed;
    WL_CONNECT_FAILED(4): assigned when the connection fails for all the attempts;
    WL_CONNECTION_LOST(5): assigned when the connection is lost;
    WL_DISCONNECTED(6): assigned when disconnected from a network;
    //Serial.print(".");
    Serial.print(WiFi.status());
    Serial.print(" ");
  } //while (WiFi.status() != WL_CONNECTED)
  Serial.println("");
  Serial.println("WiFi connected");
number of networks scanned = 7
Pre WiFi.begin
5259 milliseconds
clientConnect.ino Post WiFi.begin 16571 milliseconds
WiFi connected
Ln 93, Col 1
Arduino Uno WiFi Rev2
on /dev/cu.usbmodem221402
Program 2:
char ssid = "abc";
      /*Syntax
          WiFi.scanNetworks()
        Parameters
          None
        Returns
    //WiFi.begin("abc", "12345");
      Syntax
        WiFi.begin(ssid);
      Parameters
      Returns
      /*Syntax
          WiFi.scanNetworks()
        Parameters
          None
        Returns
    Serial.print(" ");
  Serial.println("");
pre-network scan= 0 milliseconds
Pre WiFi.begin
5264 milliseconds
clientConnect.ino Post WiFi.begin 17679 milliseconds
4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4
Ln 93, Col 1
on /dev/cu.usbmodem221402 [not connected]
As you can see, the only difference between these programs is which lines I've commented out. In the first, I specify ssid and wifiPassword explicitly, and I get a connection. In the second, ssid and wifiPassword are passed as global variables, and WiFi.begin() won't make the connection.
Is this a problem with WiFiNINA.h?
I found a way to make it work correctly. It still doesn't make any sense, but it works.
char ssid = "abc";
was changed to;
#define ssid "abc"
#define wifiPassword "12345"
I still say this is a bug in WiFi.begin() WiFiNINA.h.
char ssid = "abc";
should be
char *ssid = "abc";
char *wifiPassword = "12345";
or
char ssid[] = {"abc"};
char wifiPassword[] = {"12345"};
It works fine now. Thank you!
