by means of a push button on the master, the master should give a command to one of the slaves, which should make a pin high or low on a slave ( mega or uno )
maybe, i can find out by myself, to what slave the master will send the commando.
this is the sketch for the slave
type or paste code here
I2C Slave Control Demo
i2c-slave-demo-control.ino
Demonstrate use of I2C bus
Receives potentimeter position data
Controls LED blink rate
DroneBot Workshop 2019
https://dronebotworkshop.com
// Include Arduino Wire library for I2C
#include <Wire.h>
// Define Slave I2C Address
#define SLAVE_ADDR 8
// Define LED Pin
int LED = 13;
// Variable for received data
int rd;
// Variable for blink rate
int br;
pinMode(LED, OUTPUT);
// Initialize I2C communications as Slave
Wire.begin(SLAVE_ADDR);
// Function to run when data received from master
Wire.onReceive(receiveEvent);
// Setup Serial Monitor
Serial.println("I2C Slave Demonstration");
void receiveEvent() {
// read one character from the I2C
rd = Wire.read();
// Print value of incoming data
Serial.println(rd);
delay(50);
// Calculate blink value
br = map(rd, 1, 255, 100, 2000);
digitalWrite(LED, HIGH);
delay(br);
digitalWrite(LED, LOW);
delay(br);
> Blockquote
this for the master
Blockquote
I2C Master Control Demo
i2c-master-demo-control.ino
Master sends potentimeter position data
#include <Wire.h>
// Analog pin for potentiometer
int analogPin = 0;
// Integer to hold potentiometer value
int val = 0;
// Initialize I2C communications as Master
Wire.begin();
delay(50);
// Read pot value
// Map to range of 1-255 for flash rate
val = map(analogRead(analogPin), 0, 1023, 255, 1);
// Write a charatre to the Slave
Wire.beginTransmission(SLAVE_ADDR);
Wire.write(val);
Wire.endTransmission();
Blockquote
