Hello i want to do a smart home: control like 20 light/plug, to do this i've think to use a arduino mega with an W5100 ethernet shield, some relay but to activated a relay with the mega but i would not wire between the relay and the mega, can i use some esp-8266 and if yes how many esp-8266 can connect to the same mega+shield?
Thanks to your response and sorry for the spelling i don't speak very well english
I've choose to DIY because i'm student and i've no lots of money and it's more fun to do it myself, do you know a module who can fulfill the same function but witch i can connect nearly 20 modules on one mega ? And yes then i must change the ethernet shield to a wifi shield.
You might be able to make a remote relay cheaply, but I doubt you could build a "nice" remote switch for the price of an [u]X-10 Dimmer-switch[/u]. I'm not sure I could build that at all! It works locally/manually or remotely, it doesn't require any re-wiring of the house, and it all fits into a regular switch-box.
You might want to consider building the transmitter/controller and buying the switches & outlets.
I've had an X-10 system for more than 20 years (it's now a combination X-10 & Insteon*). I've got about 10 controlled lights/outlets, a master timer-controller, and a few manual remote controllers around the house, plus a motion sensor that just controls one of the light switches.. I didn't build any of it. My system isn't controlled over the Internet or with a cell phone, but since it uses a standard protocol I could add those features. And if I want to add another switch or outlet, I just order it and once I get it, it takes about 10 minutes to install it.
[u]Insteon[/u] switches/dimmers (X-10 compatible) are about twice the price. Or, there are a few other home automation standards/protocols. And for some reason, Wi-Fi doesn't seem to dominate... at least not yet... You might need a router/bridge between Wi-Fi and your home automation network.
